How is the engine air filter removed from the airbox structure? I don't see any tabs that lock it in. Does just the paper portion come out? The paper seems to be bonded to some black plastic.
Not sure what you are asking, but if you're referring to the square paper element, it's just a friction fit in the housing. To gain access, open the top of the housing, there are several silver metal buckles that clamp the top to the bottom.How is the engine air filter removed from the airbox structure? I don't see any tabs that lock it in. Does just the paper portion come out? The paper seems to be bonded to some black plastic.
Tell me more.. please.I've seen some aftermarket addons that are stainless steel fine grills that go outside of the cowl cover on top of the air intakes there, but not sure they would deal with the critter issue.
Those are very interesting!!Amazon.com: Front Hood Air Vent Cover Compatible with Toyota Land Cruiser 250 Prado 2024-2026, Engine Vent Protection Cover, Auto Exterior Hood Air Vent Trim Grille Accessories 2Pcs (Black) : Automotive
Buy Front Hood Air Vent Cover Compatible with Toyota Land Cruiser 250 Prado 2024-2026, Engine Vent Protection Cover, Auto Exterior Hood Air Vent Trim Grille Accessories 2Pcs (Black): Hood Vents - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Amazon.com: Heutamo Exterior Hood Vent Air Outlet Cover Trim Compatible with Toyota Land Cruiser 250 Prado J250 LC250 2024 2025 2026 Stainless Steel Car Front Hood Air Vent Dust Protective Cover (Black) : Automotive
Buy Heutamo Exterior Hood Vent Air Outlet Cover Trim Compatible with Toyota Land Cruiser 250 Prado J250 LC250 2024 2025 2026 Stainless Steel Car Front Hood Air Vent Dust Protective Cover (Black): Hood Vents - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Would these have any critter protection benefit?
When the temps warm up some, I am gong to remove the cowling (yes, there is a YouTube video on how to do it), and put some hardware screen under there to keep them out of the cabin air filter box. It will be easier than fitting screen to those hinge areas.Probably impossible and likely futile, but maybe there's a way to get some sort of physical barrier in that hinge area.
100% on where critters are gaining access to the cabin filter intake. I researched the cowl grill covers, but after looking carefully, I determined those covers wouldn't even slow a critter down........ Additional research reviled the intake Channel/void/sump in my picture. I determined there are too many places critters could gain access to that void and decided the best course of action would be to screen it.Those are very interesting!!
I don’t think so, unless the rodents have chewed there way through those plastic grills on the cowling.
Two different Toyota service managers have told me that the rodents get into the cabin air filter compartment by crawling into the space where the hood ‘hinges’ go under the cowling.
Drivers side:
Passenger side:
So, I regularly spray this rodent repellent in those locations..
I bought it on Bezoar’s site.
Has it warmed up enough for you to attempt this? Dealer found a nest behind the cabin air filter (and had previous infestation in my 4runner) so I need step up my mouse proofing game. thx100% on where critters are gaining access to the cabin filter intake. I researched the cowl grill covers, but after looking carefully, I determined those covers wouldn't even slow a critter down........ Additional research reviled the intake Channel/void/sump in my picture. I determined there are too many places critters could gain access to that void and decided the best course of action would be to screen it.
Haven't gotten to it yet, current project is my "fuel pump" disconnect and a 12 gal aux tank. Maybe after that I'll tackle it.Has it warmed up enough for you to attempt this? Dealer found a nest behind the cabin air filter (and had previous infestation in my 4runner) so I need step up my mouse proofing game. thx
Not sure if the hinge pockets are but the cabin inlet vent is.......I sprayed the hood hinge pockets with peppermint oil as a temporary measure. And that's clearly connected to the cabin air as my commute this morning was very minty.
How difficult was it to safely get the cowling off?
I spray those weekly, and a few other places.I sprayed the hood hinge pockets with peppermint oil as a temporary measure. And that's clearly connected to the cabin air as my commute this morning was very minty.
video of removal:How difficult was it to safely get the cowling off?
I need to do this very soon, but my plate is full for the next 4-5 days.
(Maybe I am asking the wrong person as to the degree of difficulty….)
Where?Would love to see your picture once the adhesive has cured. You always dial in really good professional solutions! Also, curious specifically what adhesive you used as there are lots of options out there and I’ve never used any of them.
I’ve taken out over 20 rats trying to enter our cars since August. I usually trap them outside by the wheels…and they are big and abundant here!
San Francisco Bay AreaWhere?
