41.22 Kill Switch Install
thanks EOD, what about the error messages if I turn off/on the kill-switch and attempt to turn on the engine.. will the eco see a problem and keep a permanent error on the dash until cleared manually ?
On mine if the relay is in the Off position and you try and start the engine , several error messages are displayed on the dash. However If I then turn the relay On and try to start the engine, it starts like normal and the error messages may or may not appear on the dash display.......... if they are displayed, I shut the engine off and wait 30 seconds and restart and the error messges do not reappear.
my install for the wireless switch..
few points:-
1- the trunk refuses to close after reconnecting the negative battery, I had to manually shut the door and then it opened and closed normal
2- when the Switch is on OFF and I attempt to switch on the ignition there is no error messages on the dash at all, It just do not turn on the engine which is super good (is that the experience with others or I am missing something here ?)
3- I found a better place to tuck the box, there is a place to screw the box in there and hide the extra cables
4- I used 2x 10a fuzes, the original install instruction do not specify exactly that part.
5- you need to wait more seconds to change to ON position.. and give it few sec when changing from ON/OFF.
overall I rate this 10/10 and many thanks to EOD Guy for the support.. I
I hope the remote battery will last ,I do plan to keep extra battery in the glove box anyway. and a small screw driver..
