H6 battery is the replacement for the fit on the TLC ??
I feel I have to say for those not in the know... but these "super capacitor"devices are yet another phantom always present constant current draw on the battery, albeit small. I don't think permanently connecting them to the battery is an improvement, it will actually decrease the amount of time your truck can sit unused before the battery voltage drops to worrisome levels... Sure keep them onboard for if/when you need them but having them permanently attached I feel is actually a reliability downgrade... My comment does not apply to monitoring charge in/out devices, only to this style of "combo" monitoring/jumpstart device... Those capacitor based devices are awesome if properly designed but nothing is free and there is no real benefit to having them permanently attached. If/when your battery gets low, attach them, wait a suitable amount of time and then use them to "jump" the truck.
I’ve often wondered the exact same thing..
Partly the reason I opted for a semi permanent (connects with a 12v two prong plug) trickle charger and a "bring along" jump box. Additionally I installed a "el-cheapo" digital voltage meter that's only active when I press the button.
Ancel (if you believe their stats) shows only a 3 milliamp current draw for the BS200 (for example), compared to a video camera that will draw 200 milliamps parked. If you have to chase down every last milliamp of draw, there might be other electrical issues :unsure:
And why I copied your thinking and did the exact same thing because you did 😆
Accurate comment on battery micro current draw
I am a slow adopter (aka slow learner), and plan on installing a Noco charger pigtail when I change out my battery. My charger is the 10A version, and Toyota states that is too much for the OEM battery. I already had a jump box before I had a Land Cruiser, so at least there is that 😆
I would bet Toyota engineering choose the lead acid for reliability, safety, and charging simplicity. BMS for lithium were not ready for reliable mass production yet. I have replaced a couple of failed to recharge Odyssey marine starting AGM batteries with lightweight Banshee BMS llithium. Skiffs/boats are the ultimate testing ground for intermittent use and micro battery drains.
Saw this one @ walmart 10-3-26, has 48month warrentee... AGM $189
This one seems to be a smart buy especially with the warranty. Im going to look into it.
Thanks
Well, went ahead and did the swap so far so good. It is actually holding much better than before when it comes to voltage. One piece of advice remove the small trunk floor compartment right by the battery to reinstall the battery tie down, it will be much easier i guess live and learn. The battery fits perfectly no modifications needed.
Well, went ahead and did the swap so far so good. It is actually holding much better than before when it comes to voltage. One piece of advice remove the small trunk compartments right by the battery to reinstall the battery tie down, it will be much easier live and learn. The battery fits perfectly no modifications needed.
Looking good ^^^ Please elaborate on what you removed ?? Did you mean the retention strap?
The cargo floor trays (under the small removable cover). There is a tab(s) at the bottom of the upper tray that allows the upper tray to be removed. The lower tray is held in place by those white plastic Christmas tree fasteners.
That’s correct, the tie down or retention strap, its pretty bulky and you have to wiggle it back in place. Took about 20 minutes to swap batteries, very easy to do.
Optima Orange top has interesting power specs, plus it’s only 21#, 880CCA, 5yr replacement warranty, BT monitoring & built-in jump starter. $850 may be good value for some, but it’s just not even close to my comfort level.
I’m still leaning when my OE original fails to go back to dealer & upgrade to Toyota H6 EFB w/ 84m coverage, & I’d pay difference.
During extraction/re-installation, there''s just no room for them both to fit through the opening.
(edit) once the battery is back in place there is room to fit the hold down/cage back into position.
Does our stock battery have vent tube attached? I will be changing mine soon.
I replaced mine with an AGM battery, and my OEM Toyota battery had a vent tube. Mine is a 2027 if that matters.
Should be the same on 2024-2027 models, as the manufacturer doesn't want the original flooded lead acid battery venting into the cabin.
Yepper, most, if not all batteries that are located in the interior have a vent tube. Li type may be the exception
I replaced mine with full throttle agm. No vent hose attachment. This one is fully sealed. You were right about leaving the brackets loose till the end. I was struggling then remembered you had mentioned that. Thank you.
I'm looking at the Odyssey Performance (ODP-AGM48 H6 L3) some members here have mentioned it's a perfect drop-in for the LC. Should I assume it comes with a vent "port" to connect to the LC? Or maybe it doesn't need one?
Latest Discussions
