H6 battery is the replacement for the fit on the TLC ??
While we are talking about batteries, I am going to leave my 2025 TLC for about 6 months in my garage in Colorado. It will probably get down to about 35 degrees in the garage occasionally. I will leave the 12 volt on a battery tender. Any suggestions about the hybrid battery?
The Toyota engineers have frequently pointed out that they chose lower performance NiMH main batteries for the US market hybrid LC250 instead of the more common and higher performance lithium-ion batteries, because of durability in extreme conditions. I would be confident that normal vehicle storage procedures would be OK. You could look up the Prius community's experience that has been using these types of Toyota hybrid batteries for 25+ years for more insight.
I am considering either a sodium ion or solid state replacement in the future. (There are limited options now, but I'm waiting a bit). These don't have the temperature charging issue of LiFePo4. Sodium ion provides about the same amp hour rating, but, unlike AGM can be completely drained without doing damage. Solid state is an open field I really think this is the future of high performance battery tech.
-Curtiss
The lithium battery makers also point out that their batteries can be deeply discharged and always give full rated output while discharging. Recent models have similar temp range as AGM and can self protect, which is probably why Optima has started marketing their Orangetop towards the off road community. More new tech sounds exciting though , we may be in the final years of lead acid batteries
I will confess that I did look into Optima's Orange Top. $1285 Canadian. That's about where my research ended :(
I don’t think you’d want the orange tops in a TJH250 anyway. Perhaps a good option for one of the non-hybrids (TJA, GDJ, or TRJ250), but since the 12v battery doesn’t crank the engine in our TJH’s the major value proposition of the orange top (high amp cranking power and a built-in jump start) is unusable in our trucks.
Not wanting one for the Land Cruiser was exactly the conclusion I came to upon seeing the MSRP 😆
As an aside, if the 12V battery is discharged to the point it won't light up the ECU, I believe opening and closing the fuel door (provided there is enough juice remaining to do so) will force a start with the actual starter rather than the traction battery if you were to use the built-in jump start feature in the Orange Top.
I replaced my stock 12v (produced in March of 2026) on my 2027 that I have owned for 3 months and it has died about 5 times....
Went with Odyssey H6 AGM, replacing the battery is easy, but not quick, getting they cage/hold down out adds a few minutes.
According to their mfgs, lithium ion phosphate batteries like the Orangetop even with relatively low amp hour ratings will offer longer life than lead acid based batteries because they can be deeply discharged and quickly recharged without issue. As we see on this forum, quite a few LC250s are killing their stock flooded batteries with unexplained discharges. Exotics and sports cars can suffer similar battery problems that LC250s and other 4x4s, with more frequent deep discharges. The exotics have had success with these types of batteries because they can eliminate need for constant trickle charge/tendering (plus they save weight).
According to their mfgs, lithium ion phosphate batteries like the Orangetop even with relatively low amp hour ratings will offer longer life than lead acid based batteries because they can be deeply discharged and quickly recharged without issue. As we see on this forum, quite a few LC250s are killing their stock flooded batteries with unexplained discharges. Exotics and sports cars can suffer similar battery problems that LC250s and other 4x4s ave with more frequent deep discharges and have had success with these types of batteries because they can eliminate need for constant trickle charge/tendering (plus they save weight).
Yeah, agreed that there’s value in the LFP aspect of the battery, but the other features I mentioned, which Optima asserts as the value proposition for the batteries, are a waste of money for this use case.
-Curtiss
Sodium is a worse choice for portable power/battery applications. By definition, a sodium ion (molecular weight = 23) battery will be heavier than a lithium ion (MW = 7) battery with the same power (ie, lower power density for sodium vs lithium), so why make that choice?
The fire hazard is basically the same, and dependent on the cathode/electrolyte used; there's no magic non-flammable electrolyte for these batteries yet. LiFePO4 is an improvement over the other Li-ion batteries simply because the FePO4 doesn't decompose and release oxygen like the manganese, Ni, NiMn, Co versions do (removing one of the three components of the fire triangle).
Solid state is just the use of a different electrolyte (a solid) and is pretty much still hype and investor bait. You'll be waiting a long time for solid state (and sodium) batteries.
The discussion on the threads of battery issues. Leads to some reco's for the H6 sizing to fit the rather tight spot in the back for replacing the stock unit...
There are a world of different types of batteries to choose from. Even in the H6 style. Lead Acid, the old standard. Gel types, and some new gen things on and under the radar like Iron development research types.
So the questions for the failed battery TLC users are... For any # of users.
-Have you found a good replacement to recommend?
-Have you upsized to a larger battery then the H6 as a better upgrade? How did you fit it in??
-Have you done a gel type with any success and reco's?
-If your stock OEM battery failed in the warrantee period. What success in a free replacement?
Lots of questions, but many are asking for ideas on this topic.
RE: Battery Warranty Question - My '25 LC original battery developed a weak/dead cell, which was found during a routine maintenance check at ~7K miles this May after 8-9 months of use. The Toyota warranty replaced it the same day with a new original battery...I was told that that was the only option Toyota offered at the time.
The dealer told you correctly, they may or may not offered the OEM better battery that you would have had to pay the difference in price (stock vs upgrade). A few have taken advantage of that upgrade but I haven't seen/read if it lasted any longer than the stock etc...... I chose to go after-market from the jump as I haven't had much luck with stock Toyota batteries.
For Cold Environments 12V Battery Mod
12V Battery warmers can be an option when wrapped around the battery, or as simple as a plate the battery sits on. Check out eBay.
- The TC2 Cube is made by Farm Innovators & you can get them online, or @ Ace, Lowe’s, H/Depot. It’s just a 120v switch you plug into outlet & it thermostatically provides power at a specific temp, TC2 triggers @ 20 degrees & shuts off over 30 degrees F.
- I use the TC3 version (35/50 degrees) on heat tape & heat lamps in my well house on our ranch. Also use the TC3 with heat lamps in the engine bay of our jet ski & wake board boat that sit inside my shop for the winter, & use one on my F250 7.3L block heater.
Reactions: SJR
I'd agree that cold cranking amps are not that relevant for modern gas engines and motor oils. Interestingly the Prius overlanding and camping community has been using these batteries for the last few years and now there are several options.
I'd hate to sound totally ignorant on this subject but being brand new to hybrids and even more unfamiliar with my 2 month old 27 LCP, I've experienced a dead battery 3 times already and just purchased a NOCO jump starter, to keep me out of touble. I do want to come up with a more permanent solution, but with what I do know about battery types and styles and charging systems (which I still have more research to do) I'm concerned about going to a superior AGM with the higher ampere hours and voltage for fear for that the charging system on the LC won't deliver the proper voltage to the battery, thereby doing damage to it and not getting the full life out of this. Am I way off?
I think… that AGM’s require a certain charging profile to maintain it.
Some here put a pig tail on their AGM battery, and go to the trouble to periodically charge it with the correct AGM rated charger.
AGM’s are known to last 10 years.
My 2015 Ford Transit 350 twin turbo, has OEM dual AGM’s, and BOTH are still the original AGM’s. I’m guessing Ford took that into account when they designed and built the charging system for the beast. You could also buy the 2015 Transit set up with a regular flooded lead acid battery.
Many in the Adventure riding community (ADVRider.com) switched over to AGM’s for their motorcycles going back to 2007 (when I entered that realm), My 2007 BMW R1200GS Adventure has never had anything but AGM’s. I typically get 4-5 years of very reliable life out of them. I am assuming that is because the charging system is set up for the OEM ‘GEL’ (whatever that is) battery, And not an AGM. Then i replace them with an AGM from Batteries Plus Bulbs.
Thanks for that tidbit. After reading yet even more forums here on that subject I found @katekebo gave some great insight. I'm determined to come up with the perfect solution, if there is such a thing. Thanks again.
Those Gels are a lead-acid battery, but designed w/ a silica mixed into the electrolyte making it gelatin-like. Very good in tip/roll-overs so acid doesn’t come out as easily. Read they had good performance on ATV & motorcycles. Sealed AGM seemed to take over for a while in the Polaris UTV world, now cheap $ lithiums (Amazon) seem to be the rage being lighter & good @ bridging both starting & deep cycle performance.
The battery mfgs with decades of experience will show they have proven their products to work with stock charging systems but many Internet based experts and influencers will talk about reasons why AGMs need special care and feeding.
Agree the battery manufacturers probably have a thing or two figured out for conventional charging systems.
Thinking the issue is that we aren’t in Kansas anymore.
The new Toyota charging systems are not a constant charge rate like we have had around for years. Those were simple systems where engine turns an alternator, creating current sent through a voltage regulator, feeding a battery. Now we have a ECU controlling a variable rate charging system.
As LC hybrid owners we have a DC-DC battery system charging our 12v battery with no alternator. Ive read in several places that in READY mode, the DC-DC converter keeps the 12V battery charged from the hybrid battery, whether or not the engine is running. The engine will still kick on periodically if the hybrid battery needs replenishing, but it doesn't have to be running for the 12V to charge.
Why are LC owners having early OE battery failures with old-school conventional lead acid batteries?
  • Simply batch of defective batteries?
  • Could the sense signal logic on the negative side of the battery be calibrated incorrectly in reading parameters?
  • Maybe the ECU is ‘safeguarding’ the DC hybrid battery from low voltage & selecting to not charge the 12v battery?
  • Maybe we need a different type of 12v battery - like a deep cycle profile vs a starting battery profile w/ high CCA?
Struggling how to go forward w/ the questions. I don’t know if it is really an issue, or just our new LC paradigm.
