H6 battery is the replacement for the fit on the TLC ??
I'm looking at the Odyssey Performance (ODP-AGM48 H6 L3) some members here have mentioned it's a perfect drop-in for the LC. Should I assume it comes with a vent "port" to connect to the LC? Or maybe it doesn't need one?
The Odyssey Performance is sealed AGM deep cycle, no vent required.
I actually tried to pull the trigger on one today. Almost $700 CDN now 😳
I have (or more accurately had) two Odyssey dealers close to home. One has opted out due to tariffs and dropped Odyssey, and the other's price shot up $200 and can get one in two business days. As much as I appreciated this battery in my Jeep, I may have to go a different way.
Is it a bad idea to order one from Amazon? Currently $283
If not urgent situation might buy online to get exact spec desired versus what brand someone local has in stock.
Shipping is my concern. My boxes arrive pretty beat up, & question how that 50# battery in-transit would be treated by Amazon employees that don’t know better. Batteries aren’t that durable & lead plates really don’t like to be thrown around.
Still, there may be Black-Friday sales coming this month worth chancing.
Most people with gripes (and warranty problems) get a battery delivered through Amazon. Mining reviews confirms that.
Agree with the comments above- the handling of the heavy battery and freshness of stock, as well as manufacturer warranty are my main concerns with ordering one that way.
Went to Walmart and paid $160 for their H6 AGM, made in Korea by Delkor with a four year warranty. There are only a handful of companies left in America that produce batteries.
My Amazon delivery yesterday.
I think an H6 battery may exceed their payload… 🚁!!!
If something goes wrong with your sort of expensive Odyssey battery within 3 years while it is under warranty, attempting a return through Amazon might not be a good time. With a retail store it should be easier.
I was told full throttle is better than odyssey. Only 380 cdn with taxes
I have owned some excellent batteries (including Odyssey, Northstar and old school Optima) but have never heard of Full Throttle. Doing some digging, it seems Full Throttle = Fullriver Batteries, from PROC.
I won't poop on anything I haven't owned or tested personally, so I will wait for feedback from people who have.
I've never owned a Full Throttle battery but a lot of the channels I watch, seem to think they're the bomb!
I'll admit I got a little nervous with all the banter about dead batteries. We go camping a bit so I didn't want to be stranded or even think about jumping the LC. I just put one of these in my LC. I had one in my FJ for 9 years without an issue and did many camping trips with it. Great reviews and a 5 year warranty.
Also, I believe some other posters have stated, these AGM style starting batteries require a slightly higher voltage to fully charge. This X2Power battery states it needs 14.4v to 14.8v to be fully charged. According to my Scangauge, when the LC is running the highest voltage I've seen charging the battery is 14.3v. Typically is hovers around 14.1 to 14.3v. Because of this, I've been putting it on an AGM NOCO Genius trickle charger every 3 or 4 weeks just to top it off.
If I read correctly, this is for alternators that power starting batteries. The 12V in a hybrid LC250 does not provide starting power.
Per the Odyssey (same Enersys mfg as X2) FAQ:
A. If the battery is used in a starting application, the alternator should provide between 14.2 and 14.5 volts at the battery terminals. In cycling applications, the absorb voltage should be between 14.4 and 14.8 volts, while the float setting (if applicable) should be between 13.5 and 13.8 volts.
Not fact, but as I understand, for possibly the first start of the day, & whenever the fuel door is cycled, the 12v battery does engage the 12v engine starter. With the vehicle off, I’ve seen my Ancel BS200 BT readout show a battery & starter cycle after popping the fuel door & starting the LC. Guessing that’s why the stock battery is rated for 760 CCA. It appears maybe it’s a reserve/back-up starting system?
It is the redundant starting system should the hybrid system fail/limp home mode. It is my belief that the fuel door trigger is to keep the 12v starter exercised etc........
Just noticed that there are LiFePO4 drop-in replacement batteries that are starting to really distance themselves from the good ol' lead-acids with an H6 sizes that have 100amp-hour/240 mins reserve capacity, self-heating circuits, app-based monitoring, and self-protection. I thought $1000 60AH Antigravity batteries were pretty good, but it looks like the competition is bringing the heat and batteries are going to get a lot better and cheaper soon....
I came across a house-branded one in H6 size from a local supplier for under $500 CDN, but there is absolutely zero online in terms of reviews, manufacturer, country of origin.
The 12V battery powers the starter motor after a fuel door is cycled to exercise the starter and when it is "very cold" outside (temperature not defined but TCCN suggested below -15C or 5F I believe) because the hybrid traction motor is too aggressive to crank a frozen engine. The starter motor is slower with less torque.
Latest Discussions
