For the past several months I've been researching suspension options for the ideal sub 2" lift for the LC250. Including digging through discussions here, reviewing technical specifications, comparing owner experiences, and communicating directly with manufacturers Dobinsons and ARB.
I've narrowed things down to a relatively modest 1.5–1.75" Dobinsons IMS lift, but before ordering, I wanted to share what I've learned, and hopefully get some feedback from owners who have firsthand experience with these systems.
I'm certainly not a suspension engineer, so I welcome any corrections or contradictory experiences.
Driving conditions:
My priorities, in order:
My goal is essentially an OEM+ suspension, prioritizing ride quality and refinement rather than maximum off-road performance.
For example, there's positive owner feedback in:
King shocks suspension build, give me your .02
However, what ultimately moved King down my list was the combination of expense, maintenance considerations, and intended use.
King's rebuildable performance-shock design is an advantage for owners who need that capability, but rebuilding and maintaining high-performance shocks is something I'd prefer to minimize on a vehicle spending almost all its time on pavement.
I'm also unconvinced that I'd take meaningful advantage of the additional heat capacity and performance potential of a King 2.5 compared with a properly selected monotube system.
Conclusion: An excellent option, but the cost and long-term maintenance tradeoffs don't appear justified for my driving.
It has a relatively straightforward monotube design and seemed like a logical alternative to the IMS, without going to the complexity of an adjustable remote-reservoir system.
Unfortunately, I've come across several firsthand reports of clicking, knocking, and front shock/bushing issues with LC250 MT64 installations.
Some particularly relevant discussions:
Old Man Emu MT64 — Awareness Thread
My opinion of ARB is shifting, what's your experience?
These include reports of owners receiving replacement shocks and, in some instances, continuing to experience noises after replacement.
To be fair, there are also owners reporting trouble-free MT64 installations, excellent ride quality, and positive experiences with ARB warranty support. These discussions don't establish that the MT64 is generally unreliable.
However, when comparing two otherwise appealing monotube systems, these experiences made me somewhat more comfortable choosing the IMS. And when I reached out to ARB USA and Dobinsons USA with specific questions, Dobinsons went above and beyond to answer my questions while ARB failed to even respond.
Conclusion: Still a capable option, but the reported issues and my positive experience dealing directly with Dobinsons pushed me toward the IMS.
The internal bypass design is particularly interesting because it allows different damping characteristics throughout the shock's stroke, with independent compression and rebound adjustment.
In theory, the ability to provide comfortable damping around normal ride height while increasing control nearer the ends of travel could be very beneficial for the exact combination of highway comfort and occasional rough-road driving I'm seeking.
There are also firsthand reports of excellent ride quality from LC250 owners.
2" front lift and Caster Correction
The concerns that moved me away from the BP-51 were:
Conclusion: I still think the BP-51 could potentially deliver the best combination of small-bump comfort and control. What I haven't found is convincing evidence that it would provide a meaningful enough improvement over the IMS to justify the additional expense and complexity for my usage.
I'd welcome any direct comparisons from owners who have driven both.
I spent considerable time researching the system and corresponding directly with Dobinsons USA about its configurations, travel characteristics, and suitability for my intended lift height.
The MRR's primary advantages over IMS are its remote reservoirs and independent high-speed compression, low-speed compression, and rebound adjustments.
These features are appealing, particularly when trying to balance everyday pavement comfort with improved damping on rough, washboard roads.
However, Dobinsons USA specifically advised me that they do not recommend the MRR for lifts under 2".
This was one of the most significant factors in eliminating the MRR from consideration.
My target lift is only 1.5–1.75".
While that recommendation doesn't necessarily mean it's physically impossible to configure an MRR at a lower lift height, I'm reluctant to choose a configuration that the manufacturer specifically advises against for my application.
I also investigated the standard- and extended-travel MRR configurations. Based on Dobinsons' guidance, the extended-travel configuration I was considering introduces additional UCA and differential-drop considerations that I'd prefer to avoid.
Beyond those technical considerations, I came across firsthand accounts suggesting that getting the MRR dialed in can take considerable experimentation.
For example:
Ice Cap 1958 Build in VA — Page 2
Several owners describe significant changes in ride quality after experimenting with the adjustments, with excellent results once properly dialed in. Some were considerably less impressed with the initially recommended settings.
I don't view that as a defect. Adjustability is one of the MRR's strengths, but it also means that achieving the best ride may require additional effort.
This left me with three considerations:
I'd still be interested in hearing from anyone successfully running MRRs at less than 2" of lift, especially regarding actual ride height, available travel, and alignment.
It provides a substantial monotube shock design with an internal floating piston, better heat-management potential than a conventional smaller twin-tube system, and application-specific valving and spring options.
Unlike the MRR, it doesn't have external reservoirs or multiple damping adjustments.
The appeal is having a well-matched, fixed-damping suspension that I can install and largely leave alone.
Importantly, Dobinsons USA confirmed that the IMS could be configured for the 1.5–1.75" lift I'm targeting, whereas they specifically discouraged using the MRR at that height.
That distinction carries considerable weight in my decision.
There have also been encouraging firsthand experiences here.
Relevant owner reports:
2026 Trail Dust LCLC Camping Build
Member @sprnkls installed Dobinsons IMS and reported smoother ride quality, particularly off-road, and satisfaction with the system after comparing options including King.
Yanu's Build
@RideWithYanu documented an IMS setup with Dobinsons UCAs and an extended-travel configuration. Although his lift and intended off-road use differ from mine, it's a helpful example of how these components can be configured.
Also includes positive feedback from IMS and MRR owners.
Of course, ride quality is subjective, and many of these owners are running different spring rates, tire constructions, pressures, and lift heights.
I don't take these reports as proof that IMS will ride more comfortably than the other systems. But they provide enough encouragement, combined with Dobinsons' technical guidance, to make it my leading choice.
Dobinsons also publishes a useful technical comparison of its shock designs:
Dobinsons — Twin Tube vs. IMS vs. MRR
Front suspension:
Dobinsons USA — Land Cruiser 250 IMS Suspension
One important detail is the rear spring selection. I've found that Dobinsons part numbers and advertised lift heights differ between some international applications and the U.S.-spec vehicle.
For my U.S. LC250, Dobinsons identifies C59-885V as the approximately 12mm/0.5" stock-load spring.
I'd rather use that spring, potentially combined with the small spacer, than a significantly taller or heavier-rate rear spring when most of my additional cargo weight is temporary.
Their answers were particularly helpful because my intended lift height is lower than the standard 2" configuration generally advertised for the C59-882 spring.
Front lift height and spring-seat adjustment
Dobinsons confirmed the following approximate relationship between spring-seat setting and lift height:
Actual achieved lift will obviously depend on vehicle weight and configuration.
This was important because I initially questioned whether the C59-882 spring, advertised for 2" lift, was appropriate for a lower-height build.
Their guidance suggests that I can retain the intended stock-load spring while adjusting the static ride height.
MRR suitability below 2"
One of the clearest distinctions in Dobinsons' guidance was that they specifically did not recommend using the MRR for a lift of less than 2".
By contrast, they confirmed that the IMS could be configured for my 1.5–1.75" target using a lower spring-seat setting.
I consider that an important distinction because I would rather select a suspension that the manufacturer considers appropriate for my intended ride height than try to adapt a more elaborate system to an application outside its recommendation.
Standard versus extended travel
Dobinsons recommended the standard-travel IMS configuration for my desired height.
My understanding is that the placement of the IMS front strut's droop spacer determines the standard- versus extended-travel configuration.
For standard travel, the spacer is installed above the strut mount rather than below it.
That arrangement is also discussed in this thread, where Exit Offroad provided a recommended IMS setup using the same front struts and springs:
King shocks suspension build, give me your .02 — Page 3
Exit Offroad's recommendation included:
This closely mirrors the setup I've independently arrived at.
UCAs and differential drop
Dobinsons advised that neither an aftermarket UCA nor a differential drop is required at approximately 1.5–1.75" lift with standard-travel IMS struts.
They also advised that their fixed-correction UCAs add approximately 3° of caster correction, which may be excessive at this modest lift height and could create alignment difficulties.
That guidance is one of the main reasons I've intentionally stayed below 2" and avoided the extended-travel configuration.
My interpretation is that I can achieve the desired height while retaining most of Toyota's factory suspension geometry and avoiding additional components.
However, I recognize that being able to align a vehicle within specification doesn't necessarily mean the alignment is optimal for steering feel and highway stability.
Which brings me to my biggest remaining question.
The argument for retaining factory UCAs:
Should I get UCAs for 2" lift?
The argument for aftermarket UCAs:
There are also firsthand reports of owners struggling to achieve desirable caster settings after lifting their LC250s.
This thread was particularly relevant:
Alignment Issues after 2" lift
The owner reported light, flighty steering following a Dobinsons installation. The discussion raised questions about the caster achieved, the limited available adjustment with factory UCAs, and whether the shop was using the correct LC250 alignment specifications.
That doesn't establish that aftermarket UCAs are necessary at 1.5–1.75", particularly since alignment quality appears to have been an issue in that case.
However, it reinforces my concern about preserving steering stability.
SPC 35475 adjustable UCAs
For a time I considered SPC 35475 UCAs as an option because it offers more flexible caster/camber adjustment than a fixed 3° correction arm.
The advantage, as I see it, would be the ability to achieve an optimal alignment for my actual lift height rather than accepting whatever caster the factory adjustment range permits.
There's also an interesting discussion here:
The most beautifull UCA on earth — SPC 35475
Some owners praise the adjustability and design, while others report concerns about long-term SPC corrosion resistance and durability based on earlier Toyota platforms.
Given my coastal South Florida environment, those concerns are important.
I'm also reluctant to introduce additional ball-joint or bushing maintenance unless there's a tangible handling or alignment benefit.
I've also discovered several posts across reddit and ih8mud detailing issues with the SPC UCAs on different vehicles.
My current thinking:
If the factory UCAs can achieve an alignment that preserves factory-like steering stability, return-to-center, and predictable handling, I can retain them.
But if aftermarket UCAs would noticeably improve those characteristics, even at only 1.5–1.75" lift, I'd rather install them from the beginning.
I don't want to confuse getting alignment numbers into the acceptable range with getting the best possible driving characteristics.
Differential drop: Dobinsons indicates this isn't necessary at my lift height and travel configuration.
Rear panhard bar: At approximately 0.5–1" rear lift, I wouldn't expect enough axle displacement to justify an adjustable panhard bar, although I'm open to correction.
Rear sway-bar links: I initially considered the Dobinsons SE59-591 adjustable links but am now leaning toward retaining the factory links unless there's a demonstrable geometry or handling benefit.
Full droop clearance: I'd want the installer to verify UCA-to-coil clearance, ball-joint articulation, CV angles, and brake-line clearance at full extension rather than relying solely on nominal lift height.
Again, the objective isn't to avoid necessary upgrades. It's to avoid adding components that don't meaningfully improve this particular setup.
1. Dobinsons IMS appears to be the best overall fit for my intended use.
It offers a meaningful suspension upgrade without the complexity and adjustability of a remote-reservoir system that I may not need. Dobinsons also explicitly confirmed its suitability for my targeted lift height.
2. A 1.5–1.75" front lift seems like the best compromise.
It offers a modest clearance and appearance improvement while reducing the suspension-geometry changes associated with taller lifts.
3. C59-882 stock-load springs with the IMS spring seat set at approximately 230–234mm appear to be the correct front configuration.
This is based on direct guidance from Dobinsons, although I'd still like to see actual owner measurements.
4. C59-885V with an optional 15mm spacer seems appropriate for the rear.
It should provide a modest rear lift without selecting springs intended for significant permanent additional weight.
5. Standard travel is preferable to extended travel for this build.
I value reliability, useful suspension movement, and factory-like behavior more than increasing droop however I don't want to decrease droop. Dobinsons also recommended that I install the Diff drop with the extended travel, and I'm looking to avoid that.
6. The MRR is no longer a serious contender for my intended lift height.
While the MRR offers greater adjustment and performance potential, Dobinsons USA specifically advised against using it below 2" without a diff drop. I don't see a compelling reason to disregard that recommendation given my priorities.
7. Aftermarket UCAs may be beneficial, but I haven't established that they're necessary or worth the tradeoffs.
This is the last major decision I need to make.
My overarching goal is a Land Cruiser that is more comfortable and composed than stock, maintains excellent highway manners, performs better on rough roads, and remains mechanically straightforward and reliable.
I'd rather put together the right 1.5–1.75" suspension than install a more elaborate 2.5–3" system whose capability I rarely use.
Thanks to everyone who's shared their builds, technical knowledge, and experiences here. A number of those discussions have been instrumental in narrowing down this setup.
1. Intended Use & Priorities
Current tires: Toyo Open Country AT III P285/70R17 SLDriving conditions:
- Approximately 99% paved roads, including highway driving and imperfect urban pavement.
- One or two extended overlanding/off-road trips per year, typically lasting 1–2 weeks.
- Off-road terrain includes washboards, rocky roads, moderate trails, and occasional more challenging obstacles.
- Not building for high-speed desert running, rock crawling, or 35"+ tires.
- Vehicle lives in South Florida, where salt air, humidity, and corrosion are legitimate long-term considerations.
- Centric Front Bumper w/center-mounted winch
- Currently has CBI Rock Sliders, considering skid plates
- Roof rack
- Occasional RTT, refrigerator, drawers, and other camping gear
- Ride comfort: Ideally, improve on the factory suspension's response to sharp pavement imperfections, expansion joints, and washboards without introducing unnecessary harshness.
- Highway handling: Maintain predictable steering, good straight-line stability, controlled body motion, and factory-like handling.
- Off-road performance: Improve wheel control, damping, and ground clearance without unnecessarily sacrificing suspension travel.
- Reliability and maintenance: Favor durable components that don't require frequent servicing, adjustment, or rebuilding.
- Appearance: A modest lift that reduces the factory rake without completely eliminating it.
2. Suspension Systems Considered — And Why I've Narrowed It Down
I spent considerable time looking into King 2.5, OME MT64, OME BP-51, Dobinsons MRR, and Dobinsons IMS.King 2.5 — Excellent Performance, but More Than I Need
King was initially high on my list. Owners have reported excellent ride quality and improvements in body control, and there's no question that a properly configured King system is capable of substantially more than my intended off-road use.For example, there's positive owner feedback in:
OME MT64 — A Strong IMS Competitor, but Some Reliability Concerns
The MT64 was another serious contender.It has a relatively straightforward monotube design and seemed like a logical alternative to the IMS, without going to the complexity of an adjustable remote-reservoir system.
OME BP-51 — Possibly the Strongest Alternative for Ride Comfort
Of all the alternatives, the BP-51 has been the hardest for me to eliminate.The internal bypass design is particularly interesting because it allows different damping characteristics throughout the shock's stroke, with independent compression and rebound adjustment.
- Additional complexity associated with the remote reservoirs and adjustment mechanisms.
- Uncertainty about whether I would actually benefit from adjusting compression and rebound for occasional off-road trips.
- Commonly advertised lift configurations are taller than my desired 1.5–1.75", although owners have achieved more modest heights.
- My experience communicating with ARB USA was considerably less useful than the technical guidance I received from Dobinsons.
Dobinsons MRR — Excellent Adjustability, but Not Recommended by Dobinsons USA for My Lift Height
The MRR was initially one of my leading candidates, particularly because of its adjustability and potential to fine-tune ride quality.I spent considerable time researching the system and corresponding directly with Dobinsons USA about its configurations, travel characteristics, and suitability for my intended lift height.
For example:
- Dobinsons USA expressly recommends against the MRR at my intended sub-2" lift height.
- The MRR's additional travel and adjustability may provide relatively little benefit for a vehicle driven 99% on pavement.
- The added cost, maintenance considerations, and tuning complexity are difficult to justify if the IMS can deliver the ride characteristics I'm after.
3. Why I've Settled on Dobinsons IMS
The IMS seems to occupy the middle ground I was looking for.It provides a substantial monotube shock design with an internal floating piston, better heat-management potential than a conventional smaller twin-tube system, and application-specific valving and spring options.
Yanu's Build
4. The Exact IMS Setup I'm Planning
After researching the available options and communicating directly with Dobinsons USA, I've arrived at the following proposed component list.Front suspension:
- IMS59-60660 — 2.6" IMS front struts
- C59-882 — Stock-load front coil springs
- Target spring-seat setting: 230–234mm
- Estimated lift: 1.5–1.75"
- Standard-travel configuration
- IMS59-60441 — IMS rear shocks
- C59-885V — Stock-load rear coil springs, approximately 0.5" lift on the U.S.-spec LC250
- Possibly PS59-4035 — 15mm rear coil spacers, targeting approximately 1" total rear lift
- Retain the factory front differential position
- Retain factory rear panhard rod and suspension links
- Retain factory sway-bar links unless actual lift height or geometry makes replacement beneficial
- Upper control arms: Still undecided
5. What Dobinsons Told Me Directly
I exchanged a number of emails with Dobinsons USA regarding the IMS and MRR, lift height, suspension travel, alignment, and additional required components.Their answers were particularly helpful because my intended lift height is lower than the standard 2" configuration generally advertised for the C59-882 spring.
- 237mm — approximately 2" lift
- 234mm — approximately 1.75" lift
- 230mm — approximately 1.5" lift
- IMS59-60660
- C59-882
- IMS59-60441
- C59-885V
- Standard-travel droop-spacer positioning
- Optional 15mm rear spacers
6. The Unresolved Question: Do I Really Want to Retain the Factory UCAs?
This is the one area where the research has left me somewhat conflicted.The argument for retaining factory UCAs:
- Dobinsons says they're sufficient at my lift height.
- The standard-travel configuration is specifically intended to work without additional geometry modifications.
- Factory Toyota arms and joints are already proven for daily driving.
- Retaining OEM parts avoids introducing new maintenance, corrosion, noise, or durability considerations.
- My lift will be lower than the 2" threshold where many owners start recommending aftermarket arms.
7. Other Suspension Geometry Considerations
My assumption is that a modest lift using the standard-travel IMS setup should minimize the need for additional geometry correction.Differential drop: Dobinsons indicates this isn't necessary at my lift height and travel configuration.
8. Where I've Landed — And What I'm Hoping to Validate
After all this research, the conclusions I've reached are:1. Dobinsons IMS appears to be the best overall fit for my intended use.
Questions for LC250 Owners
I'd particularly appreciate feedback on the following:- Dobinsons IMS ride quality: For those who have the IMS, how does it compare with stock over broken pavement, expansion joints, and washboards? Is it noticeably more compliant, firmer but better controlled, or roughly equivalent? Any owners who've directly compared IMS with BP-51 or MRR?
- Spring-seat settings: Has anyone installed C59-882 springs with the IMS59-60660 spring seat set at 230–234mm? What actual lift did you achieve after settling?
- Factory UCA alignment: Has anyone achieved approximately 1.5–1.75" lift while retaining factory UCAs? I'd be especially interested in before/after caster, camber, and toe measurements, along with your impressions of steering feel.
- Adtermarket UCAs: For those running the aftermarket UCAs on a 2" or less lift on the LC250, what UCAs are you running? What caster settings have you achieved? Any improvements in steering feel? Any longer-term concerns involving ball joints, bushings, corrosion, or maintenance?
- Rear suspension: Any experience with C59-885V springs and the 15mm spacers? Would you recommend that combination for maintaining a modest amount of rake?
- Additional components: Has anyone found that an adjustable panhard rod, sway-bar links, or a diff drop provided a measurable benefit or are required at a lift this modest?
- Long-term IMS durability: For owners with significant mileage, have the shocks remained quiet, consistent, and trouble-free?
- MRR below 2": Dobinsons USA specifically recommended against the MRR at my intended ride height. Has anyone received similar guidance or successfully run an MRR setup at less than 2"? If so, what actual lift height and available travel did you achieve? And did you utilize a diff drop or any other components?
