Gas mileage at fill up
It's just a simple algorithm based on past efficiency weighted for more recent result. I'll skip the the long form answer. Just google DTE calculation algorithm used by toyota. Hopefully it doesnt cite this forum.
To add a data point.. my last fill up my DTE read 380. I was getting just over 300 last winter. The higher DTE now seems directly related to me almost doing all highway driving at posted speeds or a little over. I'm on stock 18's with no mods and no roof rack.
I'm at the 15K mark on the ODO and it does seem like the MPG's are better now that it's totally broken in.
I thought this was adequate, but didn't define it explicitly.
DTE (distance to empty) is the number shown above the fuel gauge.
I thought this is what you meant about people saying 300 miles at fillup.
Mine will be 250-270 if I fill up after wheeling all day, or 300+ if I just drove 60mph for a few hours and fill up then.
Appreciate the basic replies, just as bad as Facebook here with the over explanations. I’m glad you select few have figured it out to make the rest of us look like noobs. Main point besides mods or tires, I just don’t see where if we all fill up and have a full tank of gas, the number (dte? That folks keep posting that i have no clue what it is) how does the cruiser calculate how many miles it “thinks” it will get, and thank for saying to use search feature. Maybe don’t add to my quandary then. Was a passing thought y’all are too deep in for me
Don’t be a dweeb.
Every one tried to help you. If you didn’t get the answer that you were looking for, ASK A BETTER QUESTION.
I know, English is hard.
Hope this doesn’t add to your quandary.
So keeping it simple…
Driving your LC, your inputs + any other drivers of the vehicle, are constantly updating a DTE algorithm in the ECU off of driving patterns, drive modes, amount of fuel in tank, miles driven, idle time, etc.
Seeing your perspective a lot on the forum, ‘just tell me what I want to know’. Good luck w/ that..
Add a little bit of “Tell me what I want to hear,” and a healthy amount of “bring that information to me, because I’m a victim and you are all pretentious if showing me how find it myself,” and you’ve hit the nail right on the head.
Can someone please enlighten me on why all these people post on these other groups on Facebook and Reddit about their getting 300+ miles per tank at fill up , can somebody help me out to understand why I think they’re lying and why we all show different miles at fill up when we have a full tank.
2024 LC stock, no mods
2 gallon reserve not factored into range at fill up. It’s only trading for 15.9 gallons. Hope this helps.
That’s not my experience. I’m filling 15.2-15.5 consistently at 0-5 miles DTE. That gets me 360 miles easy with another 2.5gal/58miles of cushion.
I found that the odometer inaccuracy means I am getting about 1/2-mile-per-gallon more than my displayed or calculated mpg. Makes me feel at least a little bit better.
Well, filled up today and saw my very first north of 370 DTE. You know, because I’m prone to “lying” per OP.
Now that I’m around 5k miles in, my DTE is starting to creep up a little. It was 345 at my last fill-up.
This is a screenshot of a Google Drive spreadsheet I update every time I put gas in. A holdover from the old days when my mechanic dad would have me write all this info down in a little notebook that stayed with the truck. Generally, you can tell if something is going wrong with your car if you start noticing a fall-off in efficiency.
‘26 premium with 33” Nitto Ridge Grapplers. I do my best to tell the truth. :)
The LC250 is an amazing vehicle. Depending on a variety of factors (environment, driving style, equipment etc.) it is capable of achieving less than 20mpg or over 30mpg. As a result, there is a wide range of experiences with fuel economy.
The good news is if you need or want to get the higher end of the range it is possible. There is a lot of information on how to do it in this forum.
Short answer:
Drive by tachometer and not speedometer. Stay within 1,500 to 2,000 rpm range and let the transmission do the work. Use pulse and glide technique leveraging battery to maintain speed.
It is easy to test, go on a flat straight highway and cruise at 1,500 rpm and see what gas mileage you get. A stock vehicle should run about 58-60mph at 30mpg. It's a benchmark you can then use to learn how to get better results as you change driving situations.
When im driving highway, I put it on cruise control and drive at 65. Usually on a flatish road, I can get 24-27mpg. With that i can get well over 300 (325+) on a single tank. When I drive to work I can get anywhere from 19-23MPG. Id get more on the work drives, I work with my father at a hospital and he's always leaving last second (which means I have to always be on the gas to make it in time for him). I have to say that I'm very pleased with my MPG.
Thanks. This makes sense.
