Then there should be more aluminum body panels (besides the hood) like the LC300/Lexus LX have. This would save a lot more than 50 pounds.
Also, without the engineering data or analysis on how the tanks are crash tested, we probably don't know what other safety issues there are for alternative fuel tank designs. This is probably why there aren't plenty of US market aftermarket fuel tanks to choose from almost a year after the LC250 was introduced if there is an easy/obvious solution that Toyota's team of engineers missed. I'm no engineer, but I'm guessing since the main high voltage battery and 12v battery are both in the rear of the vehicle, the fuel tank needs to be well protected.
They cut until it affects safety, but yeah it’s juggling all the items to make it work for usa market. I guess we will never known if small gas tank is a result of just targeting specific milage or toyota was forced to make it smaller because of safety or other factors.
In a few years if there is a high quality auxiliary tank or replacement tank available I will buy one.
I’m not going to pretend like I’m going to be over landing this rig, frankly if I wanted to overland in the US (not rock crawl) I would look to acquire a 3/4 to 1 ton diesel pickup, either Ford or Ram for the solid front axles, and build that up because those will have sufficient payload and axle ratings to load down with a thousand plus pounds of skid plates, bumpers, lights, roof top tent, winch etc etc. Plus a 6.7L turbo diesel is not going to be especially stressed propelling it all, even on 35” or 37” E load all terrain tires; furthermore the transmissions on those trucks are already equipped with big stand alone transmission coolers to tolerate low speed off road driving and operations under continuous load.
That said a decent set of all terrains on the 18” or 20” wheels even if you stay with a P Metric tire are going to ding fuel efficiency by 1-2 MPG. We are already dealing with a small fuel tank, on top of that the fuel gauge is laughably conservative to hold fuel in reserve to keep the fuel pump submerged at all times. When we stack these up with the fact that real world speed limits and driving conditions are generally higher than the EPA test cycle, we end up with a fuel capacity that is borderline unacceptable for day to day week to week use.
On a road trip after a couple of hours someone in the vehicle wants to take a leak, get a beverage, stretch their legs etc. So stopping every 200-250 miles to take on more fuel isn’t a deal breaker, but it sure as hell can be inconvenient depending on where or when you would prefer to stop! More range gives you more options, in the middle of nowhere South Dakota where everyone is friendly and it’s pretty safe (outside of reservations) it’s maybe not as big of a deal, but there are plenty of places that it’s not advisable to bail off of the highway at 23:45 on a Saturday night to piss and get gas.
Then as mentioned there’s the issue of exploratory day trips. Sometimes they get sideways, you don’t realize how slow and rugged things will get, and your fuel economy is going to suffer. A small tank adds anxiety, limits opportunities, and generally makes things less fun.
Long Range America is working on a solution, maybe two, that will hopefully address this. One of them involves an exhaust modification, the other involves relocating the spare tire. I’m personally more interested in the side saddle auxiliary tank and the exhaust modification. It’s supposedly about 16 gallons of fuel, which would give 33.9 gallons total on board. If a guy can average 23 MPG highway, which is close to what I’ve been getting, you would have about 650 miles of highway range holding 3 gallons in reserve in each tank to keep the pumps happy. Guaranteed I will need to take a leak way way before I run through all that fuel.
Even if you’re out doing low speed wheeling and you’re getting all of 8 MPG you’d get over 220 miles out of the tanks. If that describes your use case I would suggest you better have a sat phone/starkink, lots of recovery gear, a second spare tire, tire repair equipment, air compressor, lots of water, food, camping gear, and of course appropriate clothing and footwear. That’s quite a trek, and good planning, skill, and gear are mandatory. Frankly you shouldn’t be undertaking that kind of thing solo anyway, that’s a 2-3 vehicle mutual support effort in my opinion.
Well said!!
EODguy would you maybe entertain christening a new dedicated replacement/upgrade fuel tank thread?
I think you have officially confirmed the GX550 tank will not fit the J250?
Maybe even start a “the fuel tank is perfectly adequate for my needs” thread for the naysayers? Just kidding…
The GX 550 tank is not a direct swap to the LC. After Easter I plan on trying to use a heat gun and see if I can mold a dip/dent/void in the GX tank to accommodate the LC's link mount.
It wouldn't do any good.......LOL. People go down so many rabbit holes on any given thread, it would be a full time job moving posts etc........ and there would be those that when you moved their post, would complain that why was "my" post moved etc........
Good luck on that heat gun mold. Not that you’ll need it. I’d expect you aren’t one to rush things and have a steady pair hands. It’s going to work!
PS. If that molding a void in works, if it were me I might try and expand put out some of those other random voids taking up volume. Bet there’s at least another gallon of lost volume.
My plan is to make a wooden buck for inside the tank with the female form, brace that in with whatever holds it in place. use a baseball bat for the male form, heat the plastic until soft then slowly and carefully push the male form in. I have and old YJ plastic tank that I'll experiment on and try and identify temp, pressure etc...... I should have marked the GX tank when I had it on the lift...... now it's a guessing game.
Well, if anyone can successfully do it, I think it would be you..
Jus sayin..
Longrangeamerica now has a waitlist for one of two tanks for the j250. 16ga saddle with exhaust mod or 28 replace the spare tire option. No word on price or timing.
great, now I'm wondering how to get the TRD exhaust and this saddle lol
Any updates per chance?
Any news on aftermarket gas tank availability?
The introduced the Additional Sub Tank(30L) capacity in the Middle East. The previous year Prado model had the subtank behind the rear wheel axle and Spare tire at the Tail Gate door mounted
Does it fill up through the same spout , or is it split? Do you have to hit a button/switch to switch tanks or do they operate as one?
No, Same Spout, The fuel tank pressure valve opens up upon Main Tank (22 Gallon) going Empty and the sub tank(8 Gallon Reservoir) Activates and the ODO indicates SUB. And the ( Gas Pump sign) Amber lit as the Warning light
Wow! Good information.
Was the previous year model you refer to the prior generation model?
Believe Toyota produces this vehicle in Chengdu in addition to the Japanese plants.
But they have a very high demand in the local Market. Hybrids Cars and Ancillary components are exported in large volumes for Toyota plants across the globe and Car Models Prius, Corolla Cross are mfr and exported out. But surely No Large SUV are exported.
Looks like Browne Davis is installing those new sub tanks over in Australia. Those are all diesel I believe. I have not heard anything from long range America. Anybody else heard anything of Note?
