Just want to share with you a brief story of why I don't trust "free alignment check" offers (and alignment places in general).
For starters, LC250 1958 alignment specs are:
Toe-in: 0.17 +/-0.16 deg
Camber: 0.25 +/-0.75 deg
Caster: 4.3 deg
Note that these numbers apply to 1958 (TJH250L-GNZUZA) trim only with 18" wheels and stock tires. If you have different trim and wheels/tires you need to check TIS Service Data for your numbers.
Between 20k and 22k miles I took the LC to 3 different places that advertise "free alignment checks". Here are the readings.
As you can see, they are all over the place.
So I decided to take measurements myself using simple, manual, reliable tools. I won't go into lengthy explanation here, but I'm quite familiar with alignment, and if somebody wants to know how I took the measurements, shoot me a DM. Here are the photos.
Long story short, the alignment is nearly perfect as per factory spec (as I would expect based on my previous experience with 10 different Toyotas).
Toe-in is 3/32" corresponding to 0.16 deg (almost spot on spec of 0.17 deg), left camber is ~0.25 deg, right camber is ~0.20 deg (vs. 0.25 deg spec).
Conclusion: it's very easy to adulterate the measurements during a "free alignment checks" to convince the customer that alignment is necessary. Don't fall for the scam.
Caster: 4.3 deg
