J250 Wind Noise, Upgrading to the GX 550's acoustic front door glass (yes, you can!)
Any idea what the decibel difference is?
i didn't do a before and after, but the side mirror wind noise that you start hearing at 45MPH is completely gone. you will of course hear wind noise at 65+, but it is a major improvement and was worth it for me
Is the wind noise at 65+ from the side mirrors still, or just general wind noise?
Hey guys appreciate the tip on the clips. After getting them installed and examining how they operate, they make mechanical sense as to why they cut down on the noise as reported on numerous occasions. It's essentially a wedge, forcing the glass against the inner door seal, preventing rattles, wind noise and general looseness of the window pane in the closed position.
Probably not needed, but I did add a small strip of 1mm 3M trim tape so it never has a chance of coming loose or sliding up or down. You'll see that the bottom of the clip has a recess which allows for the tape.
I used a trim tool so I wouldn't butcher it on install, pressing on the inner edge until it locked into place.
One more tip. These are adjustable. Make sure that the pane actually makes contact with the wedge so it's pressed against the seal. Bending it further in increases the wedge's force against the glass, but don't over do it that the glass no longer slides into the seal channel. My passenger side clip initially didn't make contact with the glass. Easy adjustment post-install.
I probably made that sound more technical than it needed to be, but it isn't.
My wife's old E90 had these. 20 years later I finally know what they're for, haha.
What is your view of the noise reduction?
Hello,
New here but I am gathering all the parts to do the glass replacement as well. There is another seal located on the front part of the rear doors, right where they meet the front door. The part number on a Lexus is 67896-60070 / 67895-60070.
My question is, I havent received my LC yet (still in transit), so I dont have access to see one up close and see if the rear doors have the holes in place for this seal. If any of you would be kind enough to take some pictures of this specific area on their Land Cruiser and post it, I would truly appreciate it. If there are no holes at all I will probably skip adding this seal since I dont want to drill on the door. Hopefully I made it clear of the area I need a picture of. Thanks in advance.
Btw, for those that dont want to spend the money on OEM glass, you could always source out the glass from a glass company. Thats what I did because the price for OEM is crazy. (and I work at Lexus).
Welcome to the asylum @CruiserGuy81.
Could you be more specific about sourcing the glass from a glass company? Are referring to the double pane Lexus GX550 front door glass for the single pain LC250 front door glass?
I mean, contact a company that sources glass for vehicles in your area and see if they offer aftermarket glass. Tell them you are looking for the double pane glass (acoustic) for a late model GX550. I paid $500 from a local vendor, but I work at a Lexus bodyshop and i deal with the company regularly so I get better pricing.
Hello,
Bump!
Latest Discussions
