I ordered the below, is this no longer correct?Hey guys, Im sure the dealer will help you out but the muffler P/N has changed to PTR03-60250 (Hardware Kit PTR03-60250-AA). The hardware kit is included with the muffler, taped on to the foam protector that on the hanger. you probably wont see this change across the board until they deplete their stock, however I would assume you can order it.
The P/N changed (this time) because the front donut gasket is now included in the hardware kit (they used to have you reuse the existing).
The P/N will change again in probably 6 moths or so for a new muff outlet/tailpipe inlet flange (obviously the tailpipe P/N will change at that time as well). Glad you like the exhaust, it also fits the Taco (930B).
• Toyota (PTR03-60240)
• Toyota (PTR03-60243)
