TRD performance exhaust installed.
It says reduce weight, any way to quantify, actual weight numbers?
Thsat s a big deal by itself its its enough. Even though down low, weight matters.
Pictures above shows the clearance around the tire someone requested. Also, the stock muffler is so much bigger if that tells you anything about the weight.
Having had the performance exhaust for a while now, I am absolutely loving it. For me it completely transforms the driving experience. This with the KO3s is perfection.
Every time I drive this machine I am delighted.
It’s a truck based feel so it’s different but similar to the enjoyment that I derived driving the Macan GTS.
This may be irresistible, just cuz. Who cares about the bigger/ aux. tank possible conflicts.
Just got my LC LC Premium today. Had them install the TRD exhaust before the stock exhaust even got warmed up. Thought I’d show a pic of how big the stock muffler is for anyone who is interested.
Absolutely love the sound, fairly mellow doesn’t sound like it’s trying to be something that it isn’t. Very nice.
I’m really thinking about doing this exhaust or the Apollo GT. Just curious what would you say the weight of that exhaust is since it’s off the car.
Got it. The TRD exhaust is the only one I can’t find with a driving/ drive by video. Does anyone know of one. For example outside of the car.
Quick bump to see if anyone has this?
Thank you. Appreciate this.
Have you or anyone found an exhaust tip for this TRD Exhaust? I have the all Black 1958 and would love to put an black exhaust tip on my TRD exhaust. Have tried the Tundra and Tacoma ones and they do not fit. I'm sure I could modify something but just wondering if anyone was able to find one that fit.
PTR03-60240LC250 Land Cruiser TRD Performance Exhaust$700.601$700.60
PTR03-60243LC250 Land Cruiser HV Tail Pipe Seat$381.901$381.90
ptr0360240aa4RUN Exhst Hardware$37.811$37.81
Hey guys, Im sure the dealer will help you out but the muffler P/N has changed to PTR03-60250 (Hardware Kit PTR03-60250-AA). The hardware kit is included with the muffler, taped on to the foam protector that on the hanger. you probably wont see this change across the board until they deplete their stock, however I would assume you can order it.
The P/N changed (this time) because the front donut gasket is now included in the hardware kit (they used to have you reuse the existing).
The P/N will change again in probably 6 moths or so for a new muff outlet/tailpipe inlet flange (obviously the tailpipe P/N will change at that time as well). Glad you like the exhaust, it also fits the Taco (930B).
Look into the 2019ish Taco tip. Its a bolt on. Obviously it will be pointing down and the length of it could effect your departure angle.
(I googled while posting...)
PT932-35180-02 Black Chrome Exhaust Tip for Toyota Tacoma (2018-2022) OEM - Toyota (PT932-35180-02)​
Canvasback
