I also have this same question. I have an Icon Diff drop in the front. It's small but it's there and want to know before I buy something that won't work lolDoes anyone know if the factory skid plate works with a diff drop?
Nice, haven’t seen this one yet. It mounts to the recovery points, not the radiator bracket, which is critical.
Factory skids kit fine with the ICON Diff drop with plenty of room to spare. At least the real skids, I can't answer if anyone has the thin metal belly pan and plastic whether or not that works?I also have this same question. I have an Icon Diff drop in the front. It's small but it's there and want to know before I buy something that won't work lol
It should fit, as the factory skid is standard on the First Edition. Otherwise Icon would need to list the exception.Factory skids kit fine with the ICON Diff drop with plenty of room to spare. At least the real skids, I can't answer if anyone has the thin metal belly pan and plastic whether or not that works?
FE OEM engine skid plate works well with Dobinsons Diff Drop.It should fit, as the factory skid is standard on the First Edition. Otherwise Icon would need to list the exception.
I'm mystified why many people don't buy the factory skid, which is stamped for the vehicle. Toyota paid for the proper design and tooling to make the factory skis. The aftermarket skids sellers did not go to that expense.
Another question regarding the slee radiator support. I have the rago fabrication front bumper with winch installed. I also have the front skid from rago that comes back to the front of the front axle. Do you think the slee support will work as is? I don't have any tools to be able to modify it as you did.FE OEM engine skid plate works well with Dobinsons Diff Drop.
Added Slee radiator cross member Reinforcement plate to FE OEM skid plat : “perfect” combination
Sorry that I have no Yes / No answer since I don’t have Rago stuffs !Another question regarding the slee radiator support. I have the rago fabrication front bumper with winch installed. I also have the front skid from rago that comes back to the front of the front axle. Do you think the slee support will work as is? I don't have any tools to be able to modify it as you did.
Anyone that purchased the FE OEM skids (front and transfer), did all the necessary hardware come with the new skids? Is there anything else I have to buy?
Plus the Slee Heavy Duty Radiator Crossmember Reinforcement if you don't want to bend the radiator crossmember the first time anything hits your upgraded front skid plate.View attachment 63854
This is all you need if you go OEM. Has it all. I am a BIG OEM guy. that's just me...
for me, if I am bending that, I got problems - so not something i personally need. I am also not doing any serious shit. Mostly dune/beach driving with the occasional trails but no rock crawling for me.Plus the Slee Heavy Duty Radiator Crossmember Reinforcement if you don't want to bend the radiator crossmember the first time anything hits your upgraded front skid plate.
Trust me, the support is so flimsy that adding the upgraded skid plate only increases the chances you'll bend it. The metal that's welded to the frame looks 1/16" thick at most -- I'll measure it next time I'm under there. I don't do any crazy off-roading either, and yet I bent mine. I'm not even sure how or when. The skid plate itself is fine -- it wasn't a rock, maybe dirt or sand?. Especially if you're driving on sand you do not want any strong plate bolted to that cross member. Either stick with the thin factory engine shield or get the Slee reinforcement or a different skid plate that bolts to the frame and protects the cross member.for me, if I am bending that, I got problems - so not something i personally need. I am also not doing any serious shit. Mostly dune/beach driving with the occasional trails but no rock crawling for me.
Taking my LC rock crawling Is like buying a brand new tuxedo… and wearing it to a paintball fight.
Yeah, technically you can do it—but the second it gets hit, you’re questioning every life decision that got you there![]()
Wait for a better sale. I got all of the above for a little over $700. All hardware was included.View attachment 63854
Sheeeet you may have sold me then. Only thing I don’t like is that it requires cutting.Trust me, the support is so flimsy that adding the upgraded skid plate only increases the chances you'll bend it. The metal that's welded to the frame looks 1/16" thick at most -- I'll measure it next time I'm under there. I don't do any crazy off-roading either, and yet I bent mine. I'm not even sure how or when. The skid plate itself is fine -- it wasn't a rock, maybe dirt or sand?. Especially if you're driving on sand you do not want any strong plate bolted to that cross member. Either stick with the thin factory engine shield or get the Slee reinforcement or a different skid plate that bolts to the frame and protects the cross member.
No cutting. It bolts to the recovery point bolts and protects the weak crossmember. It basically replaces the plastic trim piece for the factory upgrade plate.Sheeeet you may have sold me then. Only thing I don’t like is that it requires cutting.
sleeoffroad.com
I confirmed with Rival that their skid plate mounts to the radiator crossmember. It looks like they recently redesigned it based on the photos. I'm guessing there's a good chance it's compatible with the Slee crossmember reinforcement. It would be better of course if skid plate designers just started building a Slee style crossmember protector into their skid plate designs.Rival
Toyota Land Cruiser Skid Plates & Underbody Protection | RIVAL USA
Aluminum skid plates for Toyota Land Cruiser. Precision fitment, no-drill install, lightweight off-road protection.www.rival4x4usa.com
- ????? support mount
- clears diff drop - ??????
