Thanks!Just an FYI when you do the install.. not sure if the instructions mentioned this? After you take the piece off mentioned above, I used the two skid plate bolts to help align the Slee and hold it in place while you re-install the tow hooks.
So, it looks like the First Edition skid plate screws directly to the Slee RCR(?)…
Kinda.. they go thru slots in the RCR back into the original holes on the radiator cross member.So, it looks like the First Edition skid plate screws directly to the Slee RCR(?)…
Thank you Blue Bear!
Ohhhhhh!! Got it!!!..Kinda.. they go thru slots in the RCR back into the original holes on the radiator cross member.
yay!!! Now i don't have to order the China version! NiceWe have released a new HD Radiator Crossmember Reinforcement.
View attachment 56654 View attachment 56655
Features
- Compatible with OE Skid Plate (Some trimming required)
- Compatible with Toyota Updated Skid Plate (except for front trim piece)
- Compatible with Slee LC250 Skid Plate System [SOK2116 & SOK2117]
- Compatible with Slee LC250 Front Bumper [SOK2103]
- Produced from Grade 50 High Strength Alloy Steel – 7 Gauge Steel
- Weight 17.5 lbs
- Factory mounting points for easy installation
- Black Textured Powder Coated Finish
SLEE- Heavy Duty Radiator Crossmember Reinforcement - High Strength STEEL - Land Cruiser LC250 / 4th Gen Tacoma / 6th Gen 4Runner - Slee Off Road
Features Compatible with OE Skid Plate (Some trimming required) Compatible with Toyota Updated Skid Plate (except for front plastic trim piece, as seen on LC 250 First Edition and Trail Hunter 4Runner) Compatible with Slee LC250 Skid Plate System [SOK2116 & SOK2117] Compatible with Slee LC250...sleeoffroad.com
No you do not.might've missed it, but i installed Toyota's OEM skid plates (all 3) on my LCLC. Do i need to cut/drill to add the Slee crossmember plate? from the photos, it doesn't look like it
Depends which version you have. One yes, one no. See very first post and several replies on page 1 for details.might've missed it, but i installed Toyota's OEM skid plates (all 3) on my LCLC. Do i need to cut/drill to add the Slee crossmember plate? from the photos, it doesn't look like it
appreciate the response...it's the 1st edition skids installed, not the black flimsy one. Had all 3 installed.Depends which version you have. One yes, one no. See very first post and several replies on page 1 for details.
Thanks for the tip! Just installed mine today with the DV8 Centric. Looks great!!!As stated in earlier post about modification needed in order to install with DV8 Centric bumper, today the plan is “executed” successfully
Attached are photos of that
This radiator crossmember reinforcement piece is very strong to ensure to protect the radiator.
I am very happy with this product which I had waited for 1.5 years
After trimmed it, I tested by standing on it: No bend. Not easy to bend U-shape “bar”I used @t3lcfe earlier post as a template and got really lucky with my first cut, then sprayed it with the Rustoleum Hammered Paint + Primer. I had to actually use a feeler gauge to make sure it wasn't touching...so lucky.
Definitely weakens the part but assuming better than stock.
There you go!Thanks for the tip! Just installed mine today with the DV8 Centric. Looks great!!! View attachment 59470View attachment 59471
What trimming is needed?After trimmed it, I tested by standing on it: No bend. Not easy to bend U-shape “bar”
Trim / modify the Slee bar / plate to work with DV8 Centric bumper. See my previous posts for detailsWhat trimming is needed?
Miss Daisy’s RCR just arrived, and I am itching to get it installed.
Oh.. no problem. I still have the OEM bumper..Trim / modify the Slee bar / plate to work with DV8 Centric bumper. See my previous posts for details
