Thank you for the walk through. I could not find any info the way you described. Very useful for me and the community. I do not plan on doing the oil changes my self, but also don't want extra charges when doing them.
It’s so easy. Especially with a Fumoto oil valve. You don’t even need a torque wrench to install one, or ever again to do an oil change.Thank you for the walk through. I could not find any info the way you described. Very useful for me and the community. I do not plan on doing the oil changes my self, but also don't want extra charges when doing them.
I second this, I've taken that plate off and put it back on so many times now.Welcome to the asylum.
Miss Daisy has the steel Toyota skid plate that came on her (OEM on the First Edition). I’m 69 yo, and can easily drop it out of my way to do her oil changes, while on a creeper when she is on a set of ramps. Remove four bolts, and loosen the two remaining bolts in the keyholes. Slide the skid plate over one inch, and it drops into my waiting hands. Pretty easy peasy. Then I slide the clear hose onto the Fumoto valve and drain the oil. Changing the oil filter is also exceedingly easy, though there is some oil to wipe up with the filter..
Do you still take the full plate off to do your oil change with the valve?It’s so easy. Especially with a Fumoto oil valve. You don’t even need a torque wrench to install one, or ever again to do an oil change.
After the ‘dealership’ service experiences that I have had in my life, and with Miss Daisy, I want them NOT touching her AT ALL. Hopefully you won’t experience a bad dealership.
I do not think you can reach the valve without removing the skid plate. In any event, you will still need to remove the skid to access the oil filter.If the hose is left attached to the Fumoto and is long enough to reach over the side of the skid plate, is it possible to reach the Fumoto valve to remove the clip, open the valve, close the valve and replace the clip - all without taking the skid plate off?
Yes.Do you still take the full plate off to do your oil change with the valve?
Super Old Thread - Victor 4x4 recovery points come with more robust and longer bolts.I was wondering this as well. I have the CAtuned Brush bar already mounted on the tow points with the OEM hooks under it. I want to add this radiator bracket but I am afraid having now 3 items (OEM tow hooks, Brush Bar and Slee radiator bracket) will compromise the strength of the tow hooks because the OEM bolts are not long enough. So now im wondering which aftermarket tow hooks I can order that come with longer bolts and will also fit with all of that on it. @sleeoffroad any insight?
