Slee Heavy Duty Radiator Crossmember Reinforcement
Install done. Can confirm the fit for a LCLC with upgraded FE skid plates. Old support/valence piece has to come off (pictured). The front of the beam essentially replaces them. There is no gap between the skid and the new support…
So, to be sure, you are saying that the metal piece and plastic piece, seen above, should not be reinstalled.. as shown below..
Because it sure doesn’t fit very well.. as seen by the angle disparity between the Slee RCR, and the OEM Toyota piece.
EDIT: I took the OEM piece off. All properly torqued. Now to get a pair of those Tacoma TRD recovery thingamajiggers.
Looks like you mounted the angled side facing forward? If so, I believe the flat side with the 2 cutouts faces toward the front of the LC. At least that is how I mounted mine.
I think you are right @Blue Sky - looking at your photo @ultane it should not have that gap under the angled point; spin it 180 and it should be a more “obvious” fit (I don’t mean it should have been obvious what way it goes, rather that when you put it on the other orientation it’ll probably immediately feel correct).
I am sorry for the confusion. I ended up mounting my RCR with the vertical flat side (with two cut outs) toward the front.
That piece in my picture was the OEM piece, which I later removed, and set aside. I can’t believe Toyota would use something so flimsy.
During the mounting of the Slee RCR, there was noticeable gap between the RCR and the frame. It disappeared when I tightened the bolts. Has anyone else seen this gap?
Disregard - order made and being shipped.
The gap is will within what is acceptable and will close up when the tow points are installed. We hold a tolerance between the surface that bolts to the radiator cross member and the tow point surface. We would rather see that than the other way where the radiator section would not touch. We see differences like that all the time with installing products on Toyota Frames.
The factory tie downs go below the Slee RCR?? And the RCR bends up when the mounting bolts are tightened..
Correct?
Or am I missing something??
I installed mine yesterday, I should probably update here. (Details in my build thread.)
As mentioned previously, when I first went to install the Slee crossmember reinforcement I realized my radiator crossmember was already bent up maybe 1/2" on one side -- it's super thin metal, about 2mm. I stopped by a body shop to ask if they could straighten it, they said there was so much delicate stuff next to it they'd probably have to remove the radiator, AC condenser, and bumper to get to it, which would run at least $1k, and advised I should just go ahead and install the Slee part instead since the gap was so small. So I was really pleased (and a little disturbed) that when I installed the Slee part, and installed all six bolts through it into the radiator crossmember, that tightening those bolts with even a small socket wrench easily straitened out the radiator cross member. It's insane that Toyota bolted a skid plate to that thing. I'm very happy the Slee reinforcement is there now!
If you end up wanting or needing to put more bolts into the crossmember like I did, four of them (including the ones holding the skid plate) are M8 x 1.25, but the center two are M10 x 1.25. You probably only want 20 or 25mm long bolts.
If they fit under the Toyota skid plate, I'm going to leave all the bolts in there to hopefully reduce the chances that a hit to the skid plate could pull on the cross member through the reinforcement. Long term I'd like to replace all of it with a skid plate with a beefy protector for the radiator crossmember built in without connecting to it at all.
With the Toyota OEM upgraded / first edition skid plate back on:
X 💯
SMDH… Do better Toyota..
Hi, this is a very informative thread, which gave me the confidence to go this path. I will be getting the Slee skid plate set + the reinforcement bar. I do not plan to do any crazy offsroading, but this will give me a piece of mind. as discussed, fellow members finding their radiator support already bent without them even knowing when/how it happened.
One question that I can answer yet. Do you think this crossmember bar + skid plate bolted to it is a mid way solution compared to an OEM skid versus a skid fully bolted to the frame? Ie, do you still think a frame mounted skid is a much stronger solution then using this crossmember? The answer to this question will not chance my decision to go for this, which is think is more than enough. This solution seems to allow for easy oil change, which is not really clear to me on other implementations.......
thanks,
I haven't had any issues with the HDRCM part. I believe I have the set up correctly. It fits perfectly and matches up with the Toyota upgraded skids perfectly.
thanks,
I believe a radiator-mounted skid with the SLEE support bar is as strong as a recovery-point mounted skid plate. I’m an annoyingly loud advocate for recovery point-mounted skids (Victory 4x4 is the only good option currently), but I think the SLEE support bar makes others just as good.
Thank you! Glad to hear that. Now even more confident with the choice I made.
thanks,
Welcome to the asylum.
Miss Daisy has the steel Toyota skid plate that came on her (OEM on the First Edition). I’m 69 yo, and can easily drop it out of my way to do her oil changes, while on a creeper when she is on a set of ramps. Remove four bolts, and loosen the two remaining bolts in the keyholes. Slide the skid plate over one inch, and it drops into my waiting hands. Pretty easy peasy. Then I slide the clear hose onto the Fumoto valve and drain the oil. Changing the oil filter is also exceedingly easy, though there is some oil to wipe up with the filter..
