Lazy and unacceptable design choices from the biggest autocompany on the planet
Sorta - On a motor vehicle often hitting a specific RPM band where a resonant frequency in the exhaust system matches the pulse frequency of the engine's firing order causes drone. On new V6 Tundra its hell hole is 2100rpm (72-74mph) in 10th gear. Never notice it w/ stock exhaust - Toyita engineered the drone out. That Tundra doesn’t drone revving engine to 2100 sitting still. Doesn’t do it accelerating through the gears. Usually doesn’t do it @ cruise too bad. But load the vehicle up holding gear up a hill & it’s there. Tow @ 72 & it’s there. Can’t do much about the firing order of the engine pulses, but you can chamber the acoustic frequency with methods spoken about before. Throwing a rig on a dyno & then saying it doesn’t drone - like many aftermarket exhaust companies - is where the junk comes from. Better engineered systems can very much reduce or eliminate the perceived drone.
Consider me corrected, I didn’t know much of that. Thanks!
It's a fairly easy process, to tune with a Hemholtz, just need to find the frequency range where the exhaust is producing the annoyance and install the proper Hemholtz in the correct location to cancel that range of frequency out.
They work much like noise cancelling headphones.
I have a custom Hemholtz all stainless 3" system on my 40 series Inline six 2F engine with a header, no drone with great full throttle note, nothing too drastic, sounds stock unless getting into it. I also have a Hemoltz all stainless 3" system on my Tundra V8 that is much the same, with no drone, both made by the same exhaust wizard who knows how tune an exhaust.
This exhaust wizard is so good, I called him up to make an exhaust for my 40, my design his tuning and slight layout modification, a couple of sound recordings, knowing the engine type and talking back in forth for about 2 hours was all he needed to make the perfect setup that he had never done before.
Neither system cost more (all were less in fact) than the not properly tuned systems from TRD (in some cases), AFE, Borla, Magna flow and the like and allot of those come in Aluminized steel rather than stainless for the same price point.
Also running a full custom 3" stainless system with a universal aftermarket muffler setup on the 80 that has no drone either, but that is likely luck as there is no resonator on that setup at all, and my exhaust wizard had no hand in this one.
I ran no mufflers and just CATs on my Dodge Dakota V8, sounded sweet on throttle but droned something terrible (worse than my Camaro with glass packs, things you do when you're young!
It's all about whether it's designed properly!
If anyone really wanted a well-designed custom setup for the 250, look no further than Keith Carty of Dirtydeeds industries in Escondido CA.
If there were enough interest, I'm sure he would stock them after making a setup if he had someone local to use their vehicle to develop a system. He is quite popular in the Tacoma and Tundra exhaust crowd but does systems for more than just Toyotas.
It’s amazing what engineers do these days chasing frequency out with bigger fan jet engines. Get that wrong & maybe a compressor stall, worse case they let go.
God bless those noise cancelling headsets!
If you install an exhaust that’s designed to let more engine sound through, tuned or otherwise, it’s going to let the sound through in totality, not selectively. You get the WOT wail you want, you also get a louder exhaust at highway RPM.
Whether you call it a drone or just ā€œlouder exhaust than stockā€ I guess depends on how you feel about it. But it’s there regardless.
@Altitude I wonder how my installed system don't do what you describe!?
Agree poorly designed exhaust does exactly that, properly designed doesn't.
It probably just doesn’t bother you. Which is great.
Loudness & Frequency are two entirely different, but intertwined events. Drone is very frequency-specific.
Bad - You speak the truth!
Keith has a doctorate in using a gas wrench to cure exhaust drone, & is legendary fixer in the 2G & 3G Tundra world.
Yeah, when I flip it to the side and slide the extension out, it does 2 things:
  1. Absolutely nothing to block the late afternoon or early morning son due to the large gap (see picture)
  2. Is less than 2 inches from my nose when I turn my head to TRY and see the mirror.
Upgraded to the GX visor awhile back. It’s not 100% coverage, but it’s close way better than the oem. I haven’t had the sun get in my eyes or on my face once. There is a very small gap where sunlight could potentially peek through, but I haven’t had any issues with it. Other than that it’s a massive improvement imo. The coverage shown in the image is just a rough estimate give or take.
I've been wanting to ask someone who has the GX sun visors, do those visors extend farther also?
I'm hoping it would cover that vertical gap between the B-pillar and the 250 visors
Most of these issues are shared across both lc250 and the gx. I just can’t fathom how Toyota has gotten these designs so wrong with so much RD budget and almost 2 decades of development time. Some of the issues are not even acceptable from a young startup :
1. Rock rails that can’t be used as steps- wth is going on here. Did the designers ever put their damn first articles into use before it went to production ? The answer has to be a no because nobody would find this acceptable
2. Heads-up display sun reflection on the windshield- again around 2-3 pm I get a super distracting magnify type glare reflected from the hud glass on to the windshield. It is to a point that I want to cover the hud completely
3. Noisy crossbars - these crossbars haul at any speed over 45. My bmw and Volvo that have cross bars don’t make any noise.
4. Extremely noisy gx roofrack- the roofrack is flat out undeliverable . It shakes the whole roof over 55mph. At almost 2k price point every gx owner immediately takes them off at the time of delivery
5. Lc FE roofrack- the plastic front wind deflector is flimsy and will make contact with the roof making constant banging noise on the freeway. I had to stick a 3M tape between the plastic and the roof to dampen the noise
6. Trd exhaust - gx trd exhaust at 2k plus is drony and flat out unbearable
7. Capacitive sensing interior lights - good luck opening the sunroof without accidentally turning on the lights. This could have been easily mitigated by debounce timing
8. Ac - the gx has something called the s flow which directs air to occupied passenger seats however for some reason it doesn’t detect a toddler in the child seat, despite the child seat being secured by the seatbelt - now every time I’m driving with my kid I have to reach out to make sure the events have flow
I can understand ( to some degree) the design choices that led to small gas tanks and annoying Nannies due regulations etc but none of the above fall in that category and it is nothing but lazy engineering.
Being in charge of RD in a midsize startup , usability testing , limited market release ,and voice of customer is an essential part of every product release which makes me believe that these damn engineers never cared to test their own product.
We have gotten very soft as a society.
Decades ago, it was 'do you want AC and power windows as an option', today, it's 'I leave my space age climate control that'll keep me cool in 110° weather on Auto, because manual control is too physically demanding'.
Sit lower and the gap is less of an issue
As a driving enthusiast, I'm sure you know seating position is more important than sitting awkwardly to keep the sun out of your eyes.
I agree, we're all going to survive this major hardship of the visors not being perfect, but for some, these little changes are part of the fun and make a noticeable improvement in everyday life.
Agreed. Choosing resiliency over all other options is akin to trying to explain to your aging parent that their willingness to give text messaging a try is directly proportional to their levels of interaction with their grandkids. You don’t have to rely on features to appreciate and incorporate their benefits, and you’ll be no less tough (or old) in doing so.
I think the OEM one extends slightly farther but provides less overall coverage
