Adding brake bleed procedure, when not using TechStream (GTS).
If you allow air to get into the actuator or booster you have to use GTS to bleed that, so do not let that reservoir get empty!
BLEED BRAKE LINE (When Not Using the GTS)
NOTICE:
- Performing the following procedure enters ECB (Electronically Controlled Brake system) Deactivate Mode without using the GTS.
- ECB (Electronically Controlled Brake system) Deactivate Mode allows the brake lines to be bled without using the GTS.
- The brake warning light blinks (yellow) to indicate that ECB (Electronically Controlled Brake system) Deactivate Mode is selected.
- Be sure to confirm that the brake warning light is blinking (yellow) throughout the brake line bleeding procedure.
- If any of the following conditions are met, ECB (Electronically Controlled Brake system) Deactivate Mode is canceled and the brake warning light (yellow) turns off. Do not allow ECB (Electronically Controlled Brake system) Deactivate Mode to be canceled while bleeding the brake lines or DTCs may be stored.
| A shift state other than park (P) is selected. |
| The ignition switch is turned to ON (READY). |
| The ignition switch is turned off. |
| The parking brake is released. |
| The vehicle speed is more than 0 km/h (0 mph). |
- Do not rotate any brake disc while ECB (Electronically Controlled Brake system) Deactivate Mode is selected.
- Although the brake warning light (yellow) will blink and a buzzer will sound while performing brake line bleeding, this is not a malfunction.
(a) Remove all 4 wheels.
(b) Enter ECB (Electronically Controlled Brake system) Deactivate Mode.
(1) Perform the procedure listed below within 1 minute.
- Turn the ignition switch to ON with park (P) selected and parking brake applied.
- Select neutral (N) and then depress the brake pedal more than 8 times within 5 seconds.
- Push the P position switch and then depress the brake pedal more than 8 times within 5 seconds.
- Push the P position switch.
| (2) Check that the brake warning light is blinking (yellow). |
| Brake Warning Light (Yellow) |
(c) Fill the reservoir with brake fluid.
(1) Remove the brake master cylinder reservoir filler cap assembly.
(2) Add brake fluid to the reservoir until the fluid level is between the MAX and MIN lines on the brake fluid reservoir.
Brake Fluid:
SAE J1703 or FMVSS No. 116 DOT3
SAE J1704 or FMVSS No. 116 DOT4
(d) Bleed the brake lines.
(1) Connect a vinyl tube to the bleeder plug of the front disc brake cylinder assembly RH.
(2) Depress the brake pedal several times with approximately 1 second between each depression, and then loosen the bleeder plug with the pedal depressed.*1
(3) When brake fluid stops coming out, tighten the bleeder plug and then release the brake pedal for 1 second or more.*2
HINT:
When the brake pedal is released, the piston inside the master cylinder may take longer than the brake pedal to return to its original position. Therefore, make sure to wait for 1 second or more between each depression of the brake pedal.
(4) Repeat steps *1 and *2 until all the air in the brake fluid is completely bled out.
(5) Tighten the bleeder plug completely.
Torque:
10.8 N·m {110 kgf·cm, 8 ft·lbf}
(6) Bleed the brake lines from the front disc brake cylinder assembly LH using the same procedure as for the RH side.
(7) Connect a vinyl tube to the bleeder plug of the rear disc brake cylinder assembly LH.
(8) Depress the brake pedal several times with approximately 1 second between each depression, and then loosen the bleeder plug with the pedal depressed.*3
(9) When brake fluid stops coming out, tighten the bleeder plug and then release the brake pedal for 1 second or more.*4
HINT:
(10) Repeat steps *3 and *4 until all the air in the brake fluid is completely bled out.
(11) Tighten the bleeder plug completely.
Torque:
(12) Bleed the brake lines from the rear disc brake cylinder assembly RH using the same procedure as for the LH side.
(13) Turn the ignition switch off.
(e) Inspect for brake fluid leaks.
(f) Adjust the brake fluid level in the reservoir.
(g) Install the brake master cylinder reservoir filler cap assembly.
(h) Install all 4 wheels.
