๐Ÿ› ๏ธ Member Build Yanu's Build
Member Build
RideWithYanu
๐Ÿ“› Founding Member
๐Ÿ† LC of the Month
โญ Supporting Member
PNW
2025 TJH250L-GNZAZA
I recently completed a suspension overhaul on my truck, and decided it would be worth memorializing my modifications. I don't present these as the best or superior modifications, but rather as the modifications that prioritize specific capabilities that are important to me. I've tried to describe not just what each change is, but what it is meant to achieve, and share details on why each works for my use case. I will update this first post over time with additional modifications and photos, and will add new comments to indicate when it has changed.
2025 TJH250L-GNZAZA Land Cruiser with Premium Package - Wilderness Access Build​
The platform is modified to prioritize capabilities that enable it to access places maintenance has abandoned. Old logging spurs reclaimed by alder. Abandoned forest service roads. Slide-covered routes into wilderness boundary areas.
SUSPENSION​
Lift improves approach, departure, and breakover angles at the cost of a higher center of gravity. Extended travel with diff drop and corrected UCA geometry lets each wheel find ground independently by improving upon factory droop.
Front
  • Dobinsons IMS59-60660. 2.6" IMS monotube front struts with internal floating piston. Droop spacer installed below strut mount for extended-travel configuration.
  • Dobinsons C59-818. Front coil springs. Provides 3" lift at stock weight, 2.5" with 110-220 lbs added.
  • Dobinsons UCA59-212K. Billet aluminum upper control arms. Sealed maintenance-free ball joints, rubber bushings. Corrects caster at lift height, prevents ball joint bind at full articulation.
  • Dobinsons BS59-560. Adjustable polyurethane front bump stops. Engage earlier than OEM to spread bottom-out forces across longer stroke.
Rear
  • Dobinsons IMS59-60443. IMS monotube rear shocks.
  • Dobinsons C59-817V. Rear coil springs, ~2" lift.
  • Dobinsons PR59-1421. Adjustable panhard rod. Re-centers rear axle laterally after lift.
  • Dobinsons SE59-591. Adjustable rear sway bar links. Restores sway bar geometry so the bar isn't preloaded at static ride height.
Driveline
  • Dobinsons DD59-644K. Differential drop kit. Lowers front diff to correct CV angles. Mandatory with extended-travel struts to prevent CV bind at full droop.
ARMOR​
Steel and frame-mounted only. Still need to reinstall transmission and transfer case skids.
Skid plates
  • Victory 4x4 VC250SD-GN. Engine skid plate. Mounts to frame at front recovery point brackets. Oil filter access port allows service without removal. Covers cam alignment bolts.
  • Victory 4x4 V250SD-TRN. Transmission skid plate. Frame-mounted.
  • Victory 4x4 V250SD-TC. Transfer case skid plate.
Rock protection
  • CAtuned Off-Road Toyota Land Cruiser Rock Sliders. 3/16" steel plate, .095 DOM tubing, flush-mounted design preserves clearance. Frame-mounted, supports vehicle weight as jack point and pivot. ~88 lbs pair. Arrived with finish chipped. CAtuned customer service unresponsive. Product design is excellent, QC and support are not. Will not purchase from CAtuned again.
WHEELS AND TIRES​
Low-pressure operation is the biggest off-road capability multiplier. Bead grip wheels enable it; E-load tires prevent the sidewall punctures that end trips. Fuel economy takes a significant hit.
  • Method Race Wheels 703. 17x8.5, 6x5.5, 0 offset, machined clear coat. Bead Grip knurled bead seat mechanically retains the tire at low pressure. Routinely run sub-10 PSI without losing a bead (knock on wood).
  • Method Hub Rings. (P/N MH-ZH-126-P). 106.25 to 95.25 mm, five pieces. The 703's 106.25 mm bore is multi-fit and sits 11 mm larger than the J250's 95.1 mm hub pilot, which leaves the wheel located by the lug cones alone. These restore hub-centric mounting and cut worst-case eccentricity from over 0.5 mm to roughly 0.075 mm. Eliminated a highway vibration above 65 mph that had survived multiple rebalances and realignments. They carry no load โ€” clamp force still does that โ€” so torque discipline still applies.
  • Mickey Thompson Baja Boss A/T. LT285/70R17, E-load rated, 3-ply sidewall. Extreme sidewall puncture resistance against sharp rock and debris. Significant fuel economy penalty. ~33" diameter. Currently in planning for larger diameter replacements.
  • Polished lug nuts. 21134ETBC. Conical seat to match Method wheels.
  • Apex Design Rapid Precision Valves. Standard length. High-flow brass cores cut deflation time significantly.
TIRE PRESSURE WORKFLOW​
A 30-minute air-down workflow gets skipped; a 5-10 minute workflow becomes routine.
  • Morrflate TenSix PSI Pro. ~10.6 CFM dual-piston portable compressor. Power cable modified with Anderson connector to plug into the cargo-area distribution port (see Electrical).
  • Morrflate 4-Tire Hose Kit. Quad manifold connects all four tires simultaneously. Equalizes pressure and inflates in one operation.
ELECTRICAL​
J250 battery access is through a cargo-area panel, but reaching it requires offloading whatever's stored there and the terminals themselves are awkward to access. A cargo-side distribution point with proper fusing puts power where it's needed without alligator clips on the battery. Anderson connector for the compressor; SAE port for jump battery input and accessory use.
  • Anderson power port (50A fused). Left cargo area near the factory bottle jack compartment. Direct-wired to the 12V battery via 8 AWG marine-grade cabling, protected by a 50A MIDI fuse at the battery. Serves as the primary high-current accessory port; the Morrflate TenSix plugs in here.
  • SAE power port (15A fused). Co-located in the same cargo-area panel. Accepts NOCO Boost jump packs (allowing 12v battery charge without opening the hood) and other SAE-terminated accessories.
COMMUNICATIONS​
Solo operation in no-coverage terrain needs layered, redundant comms. Three independent paths: satellite data, satellite messaging and SOS, and local short-range voice.
  • Starlink Mini. Compact satellite internet terminal. Internally mounted via suction cups on the moonroof glass for sky view from inside the cabin. Provides high-bandwidth data where there is no cellular coverage.
  • TIDRADIO TD-H3 and TD-H8 handhelds (multiple), modified with Nagoya antennas. GMRS handhelds for short-range line-of-sight voice between vehicles or with a ground party. TD-H8 is the higher-power unit. Nagoya antennas replace stock for materially better range.
  • Garmin inReach Mini. Two-way satellite messaging, SOS, and tracking over the Iridium network with no cell coverage. Handheld with its own battery, so it works even if the truck is disabled.
DRIVETRAIN PROTECTION​
  • Fumoto F133N. Quarter-turn oil drain valve with LC-10 lever clip. Makes oil changes a single-lever operation. Especially important with the Victory engine skid installed, where wrench access to the drain bolt is restricted. Lever clip prevents accidental opening from debris.
  • ASR Parts Toyota Diff Breather Extension. Relocates the rear breather from its low-mounted factory position to a high point in the engine bay. Prevents water ingestion during creek crossings. A tube inside of split loom runs along the top side of the driverโ€™s side frame (where other split loom from the factory is already running), then up through to the top of the engine bay, in the aft, top, driverโ€™s side area. Not the most visually impressive work, but it is effective and secure.
CARGO OPTIMIZATION​
Load placement is managed around two constraints: center of gravity and ground clearance. Heavy and frequently-used mass stays low and central. Bulky lightweight gear goes up top in removable carriers. The spare comes off the underbody to reclaim departure angle, and long tools come out of the cabin.
Spare relocation
  • Rigd Supply UltraSwing Multi-Fit Spare Tire Hitch Mount. 6x5.5 Toyota lug. Hitch-mounted swing-out carrier. Installed specifically to recover departure angle lost to the factory under-vehicle spare location. Reverse sensors (including camera) severely impacted.
Roof
  • Atlas Sherpa Roof Rack. Low-profile flat platform. Carries sheets of plywood, drywall, lumber, or cargo boxes flat across the full roof. Arrived with some incorrect parts, but the error was rapidly corrected through excellent customer service. Great company to work with.
  • Yakima TopGrips (multiple). Quick-mount tool holders for axe, long-handled shovel, and other long-handled gear. Mounted in the Sherpa's T-slots.
  • Yakima SpaceBooster 11. Long, narrow 11 cu ft rooftop cargo box. Sometimes equipped for bulky lightweight gear. Removed when not needed to keep weight and CG down.
Interior
  • CAtuned Off-Road Upper Cargo Shelf. LC250/GX550. Aluminum elevated shelf for soft goods and bulky low-weight items above; heavy and frequently-accessed gear stays below. Arrived with areas missing powder coating. Same CAtuned QC and customer service issues as the rock sliders. Will not purchase from CAtuned again.
RECOVERY​
Recovery kit is extensive; full itemization to be added in a future revision.
OPTIMIZATION ENVELOPE​
Optimized for: geometric clearance, articulation, underbody and rocker durability, low-pressure traction, sidewall survival, air-down workflow efficiency, drivetrain failure mode prevention, dimensional material transport, redundant remote comms, solo self-sufficiency.
Not optimized for: rock crawling (no winch or steel bumpers), high-speed desert (mid-tier monotube, not race-valved), overland aesthetic (no awning, RTT, exterior molle panels, etc), daily driver economy (E-load tires and steel armor cost real fuel mileage and ride comfort).
Notes:
  • Additional modifications for vehicle security are intentionally omitted from this list and kept private.
  • This list was compiled with the assistance of AI tools and manually reviewed and corrected for accuracy by the owner.
Some photos and videos added to post 1.
Ordered Jaos Mud Flaps III today to try to reduce the likelihood of flinging rocks at other drivers. Tagging a couple of folks who have installed these to see how youโ€™ve been liking them so far: @Bad1975 @Viktorv1961 @jcdeng @Desertrider1 and anyone else using these - how are they holding up? How obnoxious /prominent are the logos (understanding thatโ€™s a subjective opinion)?
Stock photo or Calokie will hold me down while DubDub rifles through my pockets:
@RideWithYanu , absolutely love mine on the 80 series, I wouldn't say the logo is obnoxious but it gets noticed by others. Mine are the Universal large flaps so the Logo is probably quite a bit larger on mine. The logo also seems to be done really well as mine was getting covered in Soot but hasn't done anything to the logo itself even after vigorous cleaning to get it white again.
I've had quite a few people ask about them and give positive comments. It seems that not even the Land Cruiser community at large has allot of awareness of JAOS.
I have the Land Cruiser (FE style) on the 250 and the JAOS are a much more robust product than the OEM, I recently had to replace a strap (JOAS sells replacement parts so you don't have to buy the whole flap again), no fault of JAOS (Diesel exhaust at 1000 F doesn't agree with them, it caught fire on the interstate and gave up the ghost).
I've remedied that with a modified exhaust tip turn down on the 80 but ran a stainless wire with crimped clamps on the trip to Moab when the Nylon gave up the ghost. Without the strap they move allot which you can hear in the cabin and would likely eventually rip off and or damage the fender flare and it's mounting points, the noise over the Diesel engine at 70 MPH is what clued me into something was going on, so pulled over to have a look.
I venture to say you Love them! Hopefully you don't get tariffed to death! My tariffs resulted in almost double the cost and between the price, tariffs and shipping these are most expensive mud flaps I'll probably ever own, even more so than the custom duraflaps I had made for the Tundra.
Should also look excellent with your color scheme of black with brushed aluminum wheels!
JAOS is just as, if not more synonymous with the Land Cruiser than is ARB. Wear that logo with pride buddy.
Thatโ€™s a glowing review that makes me feel a little better about the price! I was initially looking at the First Edition flaps because I like that they have a proper strap, but doesnโ€™t seem they hold up well and they certainly arenโ€™t cheap. Iโ€™m definitely nervous about what the tariff fees are going to be.
Thanks for taking the time to share your experience, as always!
I shall! I appreciate their legacy - I just dislike company logos on my stuff, whether vehicles, clothing or whatever!
So unfortunately the vendor I ordered these through (Blackhawk Japan) just informed me they donโ€™t actually have these in stock, and have no foreseeable timeline on a restock from JAOS.
@Matthew@LC250Mods - do you stock or order these?
Iโ€™m not laughing at you Yanu, but Iโ€™ve asked @Matthew@LC250Mods a few times about when he is going to stock up on JAOS ๐Ÿ˜‚
I am very happy with this JAOS product. Still look like brand new..
Driveline
@RideWithYanu did you experience any issue installing the Victory 4x4 skid plates with this diff drop? I have the same skid plates and Iโ€™m interested in the diff drop.
Updated to add some photos of the oil drain valve and the rear differential breather relocate.
Love it. Iโ€™ve got the OEM diff breather kit on order, but liking the idea of getting some longer hose and tucking it up there alongside the other breather.
Latest Discussions
