🛠️ Member Build Ice Cap OEM+
Member Build
solagbmw
Orange County, CA
2024 Land Cruiser
Finally did my big upgrades on my LC250. I’m super happy with how it turned out. OEM+ look was my goal. The guys at RPM Garage in Monrovia did an amazing job with the build/install. Here’s my mods list:
Mod List:
  1. OME BP-51 Full Suspension (0-440lb rear spring). About 2.75” front lift and 2” rear lift.
  2. Icon Tubular UCA’s (delta joint pro)
  3. Icon tubular rear adjustable upper control arm links
  4. Icon tubular rear adjustable lower control arm links
  5. Icon Billet rear adjustable track bar
  6. Dr. KDSS B.O.T.C.K
  7. Dobinson adjustable rear sway bar links
  8. Perry Parts Bump Stops
  9. Seal Savers Coilover neoprene covers (front)
  10. ARB Diff Breather Kit with lines from Diff and Transmission relocated to engine bay
  11. Nomad 505 17”x8.5” silver wheels +35mm offset
  12. BFG KO3’s 285/75r17 (34”) tires - Load range E
  13. Dissent Off-road steel step sliders
  14. Greenlane Off-road Aluminum (black powder coat) engine and transmission slid plates
  15. Greenlane off-road red front steel recovery hooks
  16. Rig’d Ultraswing for rear full size spare (not installed yet)
  17. Solid Woodworx Rear Drawer system with fold down bed platform
  18. Seat Jacker - Drivers Seat
  19. Fuel and Fire Sunglasses holder
  20. ZR Tactical black aluminum volume knob
Future remaining mods:
  1. Swap my 34” KO3 Load E tires for 35”x11.5”r17 KO3’s Load C when they come out next May
  2. Center mount slim bumper - maybe C4 or DV8
  3. Superwinch 10K
  4. 20” Amber light bar for bumper
  5. Aluminum Fuel tank skid
  6. Aluminum transfer case skid
The ride on and off-road with the out of the box compression/rebound settings is plush and cushy…..even slightly more soft than OEM ride. I actually just increased compression setting from 0 (softest) to 4 (out of 10) yesterday and it feels really good now (similar to OEM). With the new slightly firmer compression settings it now feels more planted at highway speeds. With the out of the box 0 compression the handling was a bit more wandery at highway speeds, but now at the 4 setting it feels more solid and planted. I’m gonna keep playing around with the compression and rebound, but right now seems like a great balance. Handling overall feels slightly less planted at highway speeds vs OEM, but I think that’s mostly due to the fact that the vehicle is lifted 3” and my new tires are E load (vs previous Rubitrek SL load) and I have a lot more sidewall than my old 20” wheels so overall the the vehicle is taller with more sidewall so gets a bit more body lean. I can always try firming up compression and rebound for more control. But overall the handling is still very good, just slightly more lean.
I’m really happy with the ride and handling. The main thing I didn’t want to lose was the plushness of the OEM suspension and I definitely didn’t lose that. Very impressed with the BP-51 suspension.
