πŸ› οΈ Member Build Blue 250 TRD/OEM+ build
Member Build
The TRD Pro knob snaps into place and functions correctly, the shift boot doesn't snap back onto rhe knob though.
I wonder if I get the 4runner shift boot, maybe I can get the plastic pieces off of it and make it work.
Did you end up swapping out your rear coils for the TRDs?
No, stock rear coil springs.
I only wanted the front level with the rear, hence the 1.5" from the TRD front coils and .625" from my 8mm top hat spacer.
Fyi
Some dealers are having a weekend sale and the trd pro shocks appear to get an additional 40% off.
Front Fox TRD Pro shocks
PTR61-89250-RF
PTR61-89250-LF
Rear Fox TRD Pro shocks
PTR61-89250-RR
PTR61-89250-LR
This is from Tuscaloosa Toyota
And for all 4 shocks
I may have missed it. Do the TRD shocks provide any lift over the stock setup?
The front coilovers raised the ride height up by 1.5". Rears are just shocks, so no ride height increase.
I'm not sure where you would be able to buy these from as it looks like you are in Kuwait. I got my parts from www.toyotapartsdeals.com
These are the part numbers I ordered for the TRD Pro parts:
PTR61-89250-RF
PTR61-89250-LF
PTR61-89250-RR
PTR61-89250-LR
Front TRD upper arms (still need to check these fit)
48630-0W010
48610-0W010
I believe these are the TrailHunter part numbers, but do you own research.
Front OME\ARB TrailHunter shock (I think this works on the left or right side)
PTR13-89250-FR
Rear OME\ARB TrailHunter shocks
PTR13-89250-RR
PTR13-89250-RL
Front TrailHunter upper arms
48630-0W020
48610-0W020
What is the difference between this upper arm number and PT901-89250-RD?
I'm not sure, who recommended that part number? I'm wondering if those might be for the upcoming TRD lift kit for the 4runner.
I saw that part number on Ed Martin Toyota YouTube. It looks like they come in silver, red, and Trailhunter….
@turbo8 It looks like there is a second video that is a duplicate. In one of the comments, he says it is from the Tacoma TRD factory lift….. with the 25% off parts, I wanted to go ahead and order the red ones you used.
I see, I believe they will work and it is a kit, so it will include both upper arms.
I paid~$540 for my upper arms, not sure why that kit is so much more, especially when they look to be the exact same arms.
Interesting video from Toyota
According to Toyota the upper arms are stiffer, stronger, gives further adjustability towards caster and camber and allows longer suspension travel
The part #s you listed are ~$440 shipped right now. I think I’ll go with those. Do I need to get anything else? I plan on taking it to a shop to swap because I don’t have the time or room to do it at home.
That is a no brainer then. I didn't need anything else, it is a pretty straight forward swap. The upper balljoint cotter pin is even the reusable type.
I wonder if I get the 4runner shift boot, maybe I can get the plastic pieces off of it and make it work.View attachment 58785
Did you ever fix the boot issue?
I did not. After thinking about it, i didn't want any TRD logos inside and the TRD knob didn't feel as good as the stock shift knob.
