Good lord this topic has been beaten to death a thousand times.
It's a very simple answer, but people just want to believe in conspiracy theories (Premium gas for Premium vehicles! It's the Government!).
Modern vehicles with cam and knock sensors adjust timing to reduce/eliminate early detonation of the fuel/air mix in the combustion chamber.
Why is this important? Because early detonation can harm your engine and late detonation is not efficent.
Lower octane gas has a lower ignition point (pressure/temperature) and higher octane is higher - it has nothing to do with "power" or "performance."
High efficiency engines (to meet CAFE requirements) use turbo charging and higher compression ratios to be more fuel efficient. What does turbo charging and higher compression ratios get you? Higher temperature/pressures in the combustion chamber. What prevents early detonation of the fuel? Higher octane gas.
So, if you use lower octane fuel, the cam/knock sensors will advance the timing and ignite the fuel before it self-ignites. However, this is further away from top dead center, which translates into less compression and less power - ie, it's less fuel efficient/power producing.
So, yes - your vehicle can run just fine on 87 octane fuel. But it will be less efficent than if it ran on 91+.
That's it. That's why Toyota recommends premium (91+). If you want to be less efficient, than go ahead an use 87 octane.
(As a side note, this is why Land Rover recommended premium fuel in the 4.6L Discovery D2 (higher compression) even though the motor was a 1950s Buick design)
