Stolen
With al due respect to Toyota and their dealers lock bars can be cut off with a hacksaw or battery operated blade saw in moments - my bar was cut off and the bar removed in one of the 3 attacks
If you want to deploy a physical deters t then there are two that add value/create delay
Substantial wheel clamp or disc lock that covers the whole steering wheel
Both are capable of being removed but they take longer than cutting out the sections of the steering wheel
Sorry to appear negative but I still have somewhere a section of my old LC steering wheel that was left behind by the thieves
Thsiis from one of the toyota sites, I saw in a video, saw this and took a screen shot - they were sold out the first day. Yes they can be sawed offf, I think it acts as a detrrent, so that they thief knows they will have something else to slow them down. In the second video he discusses, that Toyota, has made improvements with the new Land Cruisers for Security.
Here is athe video link:
Thanks. I was curious specifically which source the content you shared came from - that’s what I’d love to read. It doesn’t seem to come from the link you shared, unless I’m missing something.
Click on the google serach, and expand the window..
little more information:
Advanced Physical & Electronic Safeguards
1. Advanced Digital Immobilizers (CAN-Bus Locks)
Standard engine-kill switches require cutting factory wires, which can void parts of your vehicle warranty. A digital CAN-bus immobilizer represents a cleaner approach:
  • How It Works: A micro-device (such as an IGLA Security system or a Ghost Immobilizer) is spliced seamlessly into the vehicle's interior data lines without cutting factory power lines.
  • The Protection: Even if a thief bypasses the factory security via a CAN injection attack, the car will not shift out of "Park" or allow the engine to stay running unless a unique PIN code sequence is entered using the existing steering wheel or dash buttons.
2. Physical CAN Blockers & Shield Plates
  • Bumper and Wheel Well Barriers: Install aftermarket metal plates or protective steel mesh behind the front wheel liners. These block thieves from physically reaching or unplugging the headlight wiring harness connectors from the outside.
  • Smart Fob Sleep Mode: You can temporarily turn off the radio transmission on your official Toyota key fob. Hold down the Lock button, then press Unlock twice. The LED indicator will flash four times, confirming the fob is asleep and immune to relay attacks. Press any button to wake it up.
3. OBD Port Protection
  • Locking Covers: A heavy-duty, physical metal lock clamp over the OBD-II diagnostic port prevents thieves from plugging in handheld programming tablets to authorize a new key.
4. Mechanical Backups
  • Visible Steering Column Locks: High-quality, physically bright steering wheel club locks act as an immediate visual deterrent. Many car thieves checking a vehicle will skip it entirely if they see a mechanical obstacle that requires loud, time-consuming power tools to remove.
IGLA looks interesting. Do you have it and if so, what did it cost you?
Hey @DJW sorry to hear you had to go through this - based in ON- I installed Igla + other measures - DM me if u wish to discuss - just yesterday one of the bozos tried to steal or even get to my neighbour’s vehicle and before his hand even touched the door handle he triggered my security and was running back to the getaway vehicle faster than forest gump…… 🤣 I keep replaying the video of him getting the surprise shock and sprinting for a laugh !!!
I was trying to find some window stickers like "remotely activated explosives installed" or "sarin gas releases when alarm triggered" etc. No luck, maybe illegal? But i did find this gem, which i think i'll order for my gate.
I know you probably mean well, but I would consider editing your post. We probably don't want to teach a certain subset of thieves to target these vehicles ;)
Understood, im sure they have this information as well, as it is a simple google search.. i'll remove vulnerabilities..
Before buying the Land Cruiser I knew it was a thing for them to be stolen. I went down some pretty deep rabbit holes on the traditional internet and the not so traditional internet in learning the "hows" and what exactly they use. That type of discussion is probably best kept to DM's if someone wants to discuss it with you.
Thanks ☺️
Thank
Thanks ☺️
Sounds good - we can all be sucked down. Unfortunately, the internet helps, but give the thiefs the tools to do what they want.
The AI-summary at the top? Gotcha thanks, I always scroll past that so missed it.
It's wrong most of the time so that's the right thing to do. At most go look at the sources it cites, although those are often just the same thing as the search results below.
I use a Disklok ever since the time a neighbor told me a car pulled up behind my Land Cruiser and a guy jumped out and was looking at the back. That or I park it inside the garage. We're not in a crazy high theft area like London or Ontario, so far I haven't had any further problems. It's big, but it's easier to put on and take off than the useless kind of wheel locks Toyota is selling.
The IGLA Immobilizer runs $1299.00 installed in my area. Has anyone tried it in a '25 LC yet?
i have it on 26 LC ... works great! the downside you'll have to pin in your code every time you after shutting down the vehicle .. ie. after filling up your tank, stores, etc... but that's a minor inconvenience compared to dealing with a stolen vehicle.. :) :)
I put an Igla and a Compustar with Drone on my ‘27. The Igla will keep it from going anywhere unless they flatbed it, and the Compustar will make one hell of a noise if they try to move it. Ideally, Drone will help me find it, but there is also the Toyota tracking and the hidden AirTag. If you get a Compustar, don’t go for the one with the fancy keyfob. That fob won’t work well with Toyotas. It arms and disarms just fine with the OEM fob.
Welcome to the asylum.
