Slee Heavy Duty Radiator Crossmember Reinforcement
Thanks for doing that so quickly, it is much more clear now.
Installed today, no issues with the install. The OEM support bracket that was removed is ludicrously inconsequential, not even sure what Toyota thought that piece of metal would do.
I'm not even really sure it was for radiator support as much as a bracket to attach the valence piece to? It didn't even attach to either side of the frame, just bolted into the bottom of the radiator cross member. I can see after pulling that stuff off how a good hit to the front area of the skid would detach the radiator from the mounts because that's all that is supporting the front of the skid plate. I seem to remember a Dissent vid where one of the first things they addressed in their build was this area and the potential for grenading the radiator.
Again, the Slee bracket is pretty damn beefy and addresses the above mentioned issues. Well worth the $150 for peace of mind and the added protection.
*** I'm in no way paid by or compensated by Slee for the above review!
It’s crazy to me how many companies are making skid plates that mount to the factory location on the radiator bracket.
We have updated the instructions to reference the FE skid plate as well.
As for ARB tow points, the issue that I can see is that if you installed them under the HD RCR then you are lowering it by the material thickness (0.18") and the side bolts may or may not have enough slop in the holes to line up. We have not installed a set of those, but based on the instructions it is a pretty elaborate piece.
Also the leg that goes inboard to capture the radiator cross member may or may not work with the HD RCR due to the angle.
When we have an opportunity to test fit we will.
Thanks, Christo for the quick response on the ARB recovery points. Your right having a bracket with bolt coming in from so many opposing planes probably isn't going to work. I think the smarter upgrade would be to install the Slee HD RCR. I think it has much higher likelihood of preventing catastrophic damage than the I would get from the bomb proof recovery points. I think I would prefer the combo of HD RCR and a recovery point like they use on the Trail hunter or TRD Pros.
Are you saying that installing the recovery points is going to be a problem with this Slee piece? My plan is to install the Slee piece and put the recovery points back in the same spot under the new bracket. If I can’t do that then the radiator bracket has to go back because I need the recovery points and have to roll the dice on the radiator. I have the Victory recovery points https://www.victory4x4.com/product/V250-BRP.html and they come with robust hardware compared to stock and I was planning on putting them back in the same spot after installing the radiator bracket from Slee.
No. The only issue we can see would be when using the recovery point made by ARB. The ARB unit is very heavy duty and has more mounting points than the normal two that you used and some of them feed in horizontally. Squeezing in the HD RCR isn’t an issue when your only shooting bolts up but it will potentially move the horizontal holes down. I ordered the SLEE RCR yesterday and plan to skip the ARB recovery points for the OEM TRD Pro forged.
In my picture two posts above, you can see the ZR Overland recovery points re-installed after installation of Slee's radiator bracket (you can just barely see it immediately right of the bolts). The Victory offering looks like it would mount up similarly, with no issues.
Anyone know if the RCI engine skid will work with this?
I would like to know as well. I was at RCI yesterday and they said they are aware that it is a weak spot but don't have any plans on making anything similar. They did say hat some people have reworked the support they make for the Tacoma.
Base on the information in your website and my observation of my DV8 Centric bumper installed (see attached photo). I think your Radiator Crossmember Reinforcement still works in my situation but I need to modify a bit as attached photos because of DV8 bumper. More works for me but it is what it is 😜 looks like the front end of FE skid plate will be dropped down a bit because the reinforcement piece sitting between the radiator cross member and the FE skid plate. Overall, your product is very helpful !
I Just placed an order (order number 68045) ! And ready to work / experiment with it 😜
As stated in earlier post about modification needed in order to install with DV8 Centric bumper, today the plan is “executed” successfully 😜
Attached are photos of that
This radiator crossmember reinforcement piece is very strong to ensure to protect the radiator.
I am very happy with this product which I had waited for 1.5 years
I installed the Slee RCR today. For an added data point on recovery point fitment, The Bonobo Products Front Recovery Points fit just fine, and they are one of the chunkier recovery point options. I went with the BP because I like the gunmetal color and they look like it would be easy to get a soft shackle through. Since the RCR lowers your recovery points by 0.2 inches I might consider a more svelte option if I were buying recovery points with the RCR in mind and wanted to minimize any loss of approach angle.
I weighed the RCR to be 14.2 lbs with a crappy bathroom scale, and the OEM pieces it replaced to be 2.2 lbs, so the RCR only added 12 lbs. I guess I don't have an excuse to upgrade my front suspension yet. :sneaky:
I'm very pleased with the Slee RCR. I have been on the lookout for a solution ever since installing the skid plates and the RCR is exactly what is needed. I was worried if the front of the skid impacting a rock during a descent or just cruising, the factory radiator support could deform or crack a weld. The RCR was easy to install and offers significant protection over the factory support - totally worth it.
@sleeoffroad how long you think it will be before you have stock replenished for this radiator crossmember reinforcement bar? Really hoping to order soon.
We have a batch at powder coat. Should be in the next week or so. You can sign up on the website and will be notified via email as soon as they go live.
First batch went a little faster than what we thought they would.
Bet you a center section-only winch compatible bumper would do the same. ;)
Still wondering about the compatibility with the RCI engine Skid...
Picked mine up a few days ago. Solid product with a perfect fit. Would like to see a center section only winch compatible bumper as well with a bull bar to guard against all these deer in my area.
