Well consider this a cautionary tale! I went out to look under the LC at how this would all go together, and my radiator support was already bent! I'm not aware of ever hitting anything that could do that. My Toyota upgraded skid plate has some scuff marks on that side but isn't bent either. That radiator support has got to be flimsy. Flimsier than the upgraded Toyota skid plate apparently. Luckily unlike the catastrophic failures I've seen here, it's just bent a tiny bit, shoved up maybe half an inch? No cracks. And it didn't get shoved far enough to touch the radiator. This is a real fail on Toyota's part, and to me at least really demonstrates the danger of having skid plates attach there.
My plan now it to get the Slee reinforcement, and maybe try to use washers to fill the gap between it and the radiator support on that side if needed? I'm not sure it's a good idea to try and torque it down to make them meet again, but maybe I'll take a closer look, if that cross member has a bolt welded inside that might be the better plan. I am still concerned that with the plate bolted to the radiator support through the Slee brace, a large enough hit could yank back on the radiator support. But that would have to be a large enough hit fold the skid plate between the front bolts and the middle bolts into the frame.
Details: this was the first thing I noticed when I went out to take a look at things:
Yeah, that skid plate is crooked! What is going on? I took off the plate, and the bracket that holds the trim piece, and it was the radiator bracket, nudged up on the driver's side. This is the best pic I could get of it. Luckily there are no cracks in the brace that I can find. It's like something just shoved it up?
Here's the skid plate. I experimented with the lightning to get the scuff marks to show, they're not deep gouges. It doesn't look like hitting a rock (I probably would have noticed that!). Looking at stuff around this that hangs down lower, I'm not sure how this was even possible.
