Slee Heavy Duty Radiator Crossmember Reinforcement
Well consider this a cautionary tale! I went out to look under the LC at how this would all go together, and my radiator support was already bent! I'm not aware of ever hitting anything that could do that. My Toyota upgraded skid plate has some scuff marks on that side but isn't bent either. That radiator support has got to be flimsy. Flimsier than the upgraded Toyota skid plate apparently. Luckily unlike the catastrophic failures I've seen here, it's just bent a tiny bit, shoved up maybe half an inch? No cracks. And it didn't get shoved far enough to touch the radiator. This is a real fail on Toyota's part., and to me at least really demonstrates the danger of having skid plates attach there.
My plan now it to get the Slee reinforcement, and maybe try to use washers to fill the gap between it and the radiator support on that side if needed? I'm not sure it's a good idea to try and torque it down to make them meet again, but maybe I'll take a closer look, if that cross member has a bolt welded inside that might be the better plan. I am still concerned that with the plate bolted to the radiator support through the Slee brace, a large enough hit could yank back on the radiator support. But that would have to be a large enough hit fold the skid plate between the front bolts and the middle bolts into the frame.
Details: this was the first thing I noticed when I went out to take a look at things:
Yeah, that skid plate is crooked! What is going on? I took off the plate, and the bracket the holds the trim piece, and it was the radiator bracket, nudged up on the driver's side. This is the best pic I could get of it. Luckily there are no cracks in the brace that I can find. It's like something just shoved it up?
Here's the skid plate. I experimented with the lightning to get the scuff marks to show, they're not deep gouges. It doesn't look like hitting a rock (I probably would have noticed that!). Looking at stuff around this that hangs down lower, I'm not sure how this was even possible.
With OEM tire size 265 and without front end lifted or “leveled with spacers” (never a fan of that), the front end / radiator cross member is low which likely will be hit and damaged by rocks, wood logs, etc. on trails
Mine is almost 3” front lifted+1” raised by 35” tires+ centric steel bumper and now + Slee reinforcement bar/plate…That combination gives me more security when hitting rocky trail
Slee reinforcement plate is the MUST for stock height with FE skid plate. Price is very reasonable for the HUGE improvement !
@Blue Bear, what is the source of the info that you mentioned that the OEM hooks are meant as tie downs and shouldn’t be used as recovery points?
I’ve seen this mentioned before and am wondering if it is accurate?
Just to be clear, when I said,OEM I meant manufactured by Toyota. I was not referring to the original tiedown/toe hooks that come stock. I was referring to the red TRD tow hooks.
Maybe parking straight into a spot with a concrete parking block or a curb??
(I’ve ordered a Slee protector but haven’t received it yet.)
I think concrete would have left more of a mark on the skid plate. And I would have noticed. But I get your point about that being able to hit the plate while missing any of the lower hanging stuff to the side. The only thing I can think of is that I drove on some dirt roads in Utah with some pretty washed out sections, and maybe just hit the dirt edge of a rut or washed out part?
Excellent question - it's been some time since I looked into it. I believe the initial information was in a Ronny Dahl video on the LC. However, the owner's manual confirms that these hooks are not intended to be used as off road recovery points (read for yourself below.) Initially I had no plans to replace the OEM attachment points, but Toyota clearly intended them to be used for emergency situations on paved roads. The OEM hooks are better than nothing, but I wouldn't want to depend on them if I was stuck in a bad spot off-road. I also purchased a Reno hitch slider tow point for the rear of the truck. Hope that helps! (BTW - this is all in reference to the OEM towing hooks, not the red TRD tow hooks which I'd think are intended for off road use.)
Thanks, @Blue Bear. Guess I should learn how to RTFM! (It’s longer than Tolstoy’s War and Peace though.)
I think I’ll look into getting the TRD hooks (and then spray painting them black).
Also worth noting, the smaller loops pointing downwards are truly just tie-down points and shouldn’t be used even for emergency towing.
Well consider this a cautionary tale! I went out to look under the LC at how this would all go together, and my radiator support was already bent! I'm not aware of ever hitting anything that could do that. My Toyota upgraded skid plate has some scuff marks on that side but isn't bent either. That radiator support has got to be flimsy. Flimsier than the upgraded Toyota skid plate apparently. Luckily unlike the catastrophic failures I've seen here, it's just bent a tiny bit, shoved up maybe half an inch? No cracks. And it didn't get shoved far enough to touch the radiator. This is a real fail on Toyota's part, and to me at least really demonstrates the danger of having skid plates attach there.
Yeah, that skid plate is crooked! What is going on? I took off the plate, and the bracket that holds the trim piece, and it was the radiator bracket, nudged up on the driver's side. This is the best pic I could get of it. Luckily there are no cracks in the brace that I can find. It's like something just shoved it up?
Geezy peezy. Now I think that I should get one.
EDIT: Does anyone (@sleeoffroad) know if the First Edition skid plate will still work with this brace without have to modify anything?
See my post earlier up. Works great. Easy install, just have to remove two pieces and no modifications... and reversible if you wish!
I agree with t3lcfe... I don't plan on lifting, or changing my suspension at all, just bigger tires. I think this is very cheap insurance. I'm not willing to take the chance of grenading my radiator 30 miles out in the backcountry.
If you do any off roading at all it’s a no brainer. Couldn’t be an easier install (unless you overtighten and break off a skid plate bolt!!). It fits perfectly with FE skid.
Skid plate bolt torque 21 ft-lbs.
I'm realizing now it was in a different thread, but I asked about this and the Slee folks confirmed it works with the Toyota upgraded plate & added a photo to their web page. From photos earlier in this thread, and taking mine apart, you just remove the bracket that holds the trim piece and install the Slee brace.
@ultane
The trim piece. From what I understand, if you got it after market it comes with the metal part, which bolts into the middle of the radiator bracket, to hold the plastic trim piece. I’m not sure how the plastic piece bolted on with the standard metal shield.
This would be your view from below, with up in this photo being the front of the vehicle.
Flipped over, away from the camera is the front of the vehicle. Those screw at the sides hold the plastic trim to the metal bracket, the metal bracket attaches to the radiator bracket. The Slee part more or less replaces all this from what I can see.
@ultane
Thank you very much. I just ordered the Slee product. 🤞🏻
Just an FYI when you do the install.. not sure if the instructions mentioned this? After you take the piece off mentioned above, I used the two skid plate bolts to help align the Slee and hold it in place while you re-install the tow hooks.
