Safety Recall - 26TA23 (Interim Notice 26TB23)
Thank you I was able to find the correct clip and zip tied it like others are doing. But I've got a pretty bad Neck crick from being at a weird angle underneath and doing this.
It's really owners choice.......... some don't seem worried about it and want to wait for the Toyota fix. Others like me have decided an 8 cent zip tie is cheap insurance until Toyota has the fix. I don't have a picture of mine but you basically put a zip tie around the orange clip and pull it tight, then I angled a 2nd one diagonal over the connector to keep the 1st one from slipping off. Post #75 has a pic of the 1st tie wrapped and decided to use foil duct tape to keep it from slipping off.
Thought this might help reduce fuel clip anxiety -
  • Very obvious when the clip releases.
  • Pics 1-3 zoomed in what a released fuel line clip looks like.
  • Pic 4 shows (purple clip) what the male & female fittings look like apart. That ferrel ring on the black fuel tube is what the clip is locking.
  • Super easy to add zip tie or hvac tape to hold in place for extra peace of mind.
Thanks.
For the folks adding a zip tie or tape, are you just reaching up and doing it by feel?
On my list to add one today- based on location, I'll be doing it by feel. That said, clearance around the fitting and clip is adequate so I don't expect it to be difficult... (I know I just said that!)
No. You can see the orange clip and reach up there. It's just a really tight spot.
I'm leaving it alone until Toyota has a fix for it. I'll check it every week to make sure it's still intact.
Slide under passenger side, feet still outside of the vehicle,. Look @ front of the fuel tank & follow heat shield up. You’ll see black metal fuel line. You can push on top of the heat shield (flexible) & you’ll be able to see the fuel line fitting using a flashlight. It moves a bit as well. I used magnetic flashlight & added the zip.
I called Toyota Brand Engagement a couple of times -- because I didn't like the first answer which was "do not drive". The second answer was to have the dealer inspect it and make a safety recommendation. My guess is that nobody at Toyota or at a Toyota dealer will take any responsibility for something that is listed as a safety issue. I took a somewhat half-hearted try at locating the clip and could not find it despite following instructions on the forum. I assume if I locate it that it will be comparatively clear if the retainer is intact and the line is properly secured?
Does anybody think that a dealer service department would inspect it and add a zip tie and/or tape for me? I'm hesitant to mess with it if it's a tight squeeze.
It’s not that tight of an area, it’s just a little awkward to get to.
I tried uploading a video but it was too large, so here are some pics.
First find the crossmember that is located about halfway along the passenger side front door. It sticks down below the frame rails:
The gas tank is just to the rear of the crossmember, shown in this next photo on the left side. The crossmember from the first pic is on the right side of the image.
Follow the angled inside corner at the front of the tank upwards:
If you stick your phone up there a little further you’ll see the fuel line and orange clip:
I found it. Thanks for the guidance. It appears to me that the clip looks undamaged and properly seated. I assume the flange on the tube is in the correct location -- but there is really no way to check that. I assume it would be obvious if the tubing was improperly seated in the connector/clip. There are certainly no leaks. After reading the first five pages of comments -- it appears that most people are either doing nothing until Toyota comes out with a fix, adding 1 or 2 zip ties, or taping it. All just to make to make sure that the orange clip does not come off. I think there was only one mention of somebody parking their car until Toyota implemented a fix. Am I summarizing the recommendations accurately??
On one hand, I would never have even known about it if I hadn't been browsing the forum -- I rarely look at the Toyota app.
Depending on where you're located, I'd be more than happy to put a zip tie on it for you....... You can PM me with your state/town if you'd like.
thanks
I'm still perseverating on this a little bit. Is there any chance of over tightening the zip tie, breaking the clip and actually making it worse? Would just metal tape be a safer and just as adequate fix?
I dont think the dealership's burger flippers will appreciate having to contend with adhesives on the connection. Maybe a velcro strap would cover it with less mess.
Edit: just added a wire tie. Velcro was too difficult to do properly blind and one handed.
Not a chance a zip tie would cause any damage, unless you have metal zip ties and gorilla strength
lol I’m going to see how easy locating this really is. I’m going to attempt it….right before I head to the office for a serious meeting. If I end up looking like my car ran me over, I deserve it for not finding something that should be easy. This should be fun.😀
Latest Discussions
