RESOLVED - BeatSonic Issue - Entertainment system won't shut off/reboot (ENA-3T3 installed)
You’re correct. The side of the glove box closest to the driver is open a fraction more than it should when closed. Doesn’t rattle. But I may try to reinstall the finisher for that side of the latch.
Good catch…no pun intended
When you were routing the cable through, did you notice if there is room to cut out a separate hole near the door latch hole you used? Also, is there enough cable included to set the amp fully on the glove box shelf? The picture you provided shows the amp half on it and half off.
The harness can be snug or loose depending how it’s routed & LCs equipment. I have the larger NAV screen & pulled it out for the install. I could have run it different & had a bit more length. The unit will sit flat on Velcro on the table in the glove box. Yes, there is a way to run the harness in if you wanted to make a hole & use grommet.
