The issue
On Toyota's current multimedia system (internally "21MM," used across most Toyota models since 2022), the passenger-side microphone does not appear to work through Apple CarPlay. Nothing from the passenger seat is picked up — "Hey Siri," voice input for navigation, text dictation, or being heard during an in-progress call.
Important: the passenger mic does work with Toyota's own native system. Say "Hey Toyota" from the passenger seat and it responds normally. The failure is specific to the CarPlay audio path.
Why you might think yours works when it doesn't
This is the part that tripped me up for a while. Normal-volume conversation from the passenger seat often still gets through on a call — but that's the driver-side mic picking up the passenger by proximity, not the passenger mic working. Depending on how far apart your mics are, this can look completely fine in everyday use. Note: The mics are far apart on my 2024 Land Cruiser - so the passenger voice is not detected in my case.
The 2-minute test that settles it
Voice commands are a bad test because recognition failures have lots of possible causes. Use a physical signal instead:
What I've found so far
Four vehicles, four models, four model years — all the same result. Driver side clear, passenger side nothing:
The last two are notable: Toyota's own people replicated the failure and put it in writing. Their conclusion was that because it happens on every 21MM vehicle they checked, it must be normal operation. I'd argue the opposite — a fault that appears uniformly across an entire software platform looks like a platform-wide defect, not a design choice. I've been unable to find it disclosed anywhere: the owner's manual documents passenger-seat limitations for the native voice assistant but says nothing about CarPlay, and Toyota's own materials describe the dual-mic setup as serving both front-seat occupants for phone use.
I went through the dealer and opened a case with the Toyota Brand Engagement Center. They determined it's not a warranty issue.
What would help
If you have a 2022+ Toyota, please run the test and reply with:
Also worth filing at nhtsa.gov/report-a-problem if you confirm it. It's free and takes fifteen minutes. Complaint volume is what triggers investigations.
- Place a phone call through CarPlay to someone who can tell you what they hear.
- Driver seat: lightly scratch or tap right at the driver-side mic (near the rearview mirror / headliner area) for 2–3 seconds. Confirm the other party hears it clearly.
- Pause a few seconds.
- Passenger seat: same scratch/tap at the passenger-side mic, same duration.
- For a clean result, have the driver step out of the vehicle with the door closed during step 4, so there's no chance the driver mic is picking it up.
- 2024 Land Cruiser (mine, tested)
- 2023 Highlander (tested)
- 2025 Tacoma (reproduced by a Toyota dealership shop foreman)
- 2026 Sienna (reproduced by a Toyota Field Technical Specialist)
What would help
- Model and model year
- Driver-side result (detected / not detected)
- Passenger-side result (detected / not detected)
- Whether the driver was in the vehicle during the passenger test
- Optional: your software version from Settings → Software Update → Model Info
![[PLOMOR] Share Your Journey: LC250 Scenery & Builds Showcase](https://www.landcruiserforum.com/data/files/featured_images/47/featuredimages_6b79e9b7744cbd73.webp)
