Remove iForceMax Circle ONLY?
Personally I like the Chrome Toyota lettering on the front grill, I'm on the verge of removing this Iforcemax badge though, Heat gun and dental floss all I need? how about the left over goo how can I remove that?
To be honest, just lift one end of the badge and lift with a super slow steady motion. Once it comes off, rub any remaining adhesive with a micro fiber towel (or something soft) or your finger and it'll ball up and come off.
If the vehicle is new, it’ll probably just peel off with the heat gun. Mine was only a month or so old when I did it, came right off! No goo gone or fishing line, I was prepared but didn’t need them
Start with mild remover. Like bug and tag remover, sold at autoparts. Use a cotton rag. if not, 2nd , try... 1/2 and 1/2 mix of wqter and alcohol. Use rag or foam applicator. if not , 3rd ... Meguiars fine cut cleaner, with a foam applicator. Remove with clean rag.
Hopefully the first one will work. Good luck
The 2024 iforcemax badge is designed to be removable. If you don't mind it breaking it you can just pull it off. The glue is also easily removable.
I used "paint safe" Goo remover. Just wash the area well afterwards.
Thanks for the suggestions, took it off this morning, Heat Gun + peeling off slowly most the goo came off with the badge cleaned the area afterwards no go gone needed but had it on hand just in case, looks much better without it imo
I took mine off this morning. It snapped off letter by letter and took all the adhesive with it.
