The Stealers are comical, I'm not quite sure what part of the warranty would be voided by removing the striker for a look see. Even if you were to remove it, weld it on the back side or place a shim under it or whatever it takes, the only thing even remotely affected would be the electric lock mechanism. The body shop angle would be for them to adjust the striker.
In my way of thinking, if the striker is solid (no point in welding the back side) and it rattles, whether you adjust it or the body shop adjusts it, it has to be adjusted and in no way would that void any part of the warranty.
