LC250 CV joints - Should I consider upgrading
Certainly looks like it, the brown looks like heat has been induced into the metal from use.
If you ordered those from a dealer, I'd send the photos ask for the boot kits, seals and dust caps and rebuild them if you're up for that, completely free of charge of course. Along with 50% off the original price.
Boot kits and all required replacement parts in this thread: Tacoma Trail Hunter CV Upgrade
I went the Lexus route, but it's maybe an illusion, I have the impression that the shaft between joints is largeur, I measured 1,25 inch at the smallest section or 31,6mm. I also don't understand why there is portion with a largeur diameter on that shaft?
Did you ever get these installed? Any guesses as to what makes it different to the Taco or OE shafts?
Not yet, but it' doesn't look good.
I'm still deep in the process of cross-referencing part numbers for the CV section. I don't think the Lexus CVs are directly interchangeable, and keep in mind I have the diesel version, so I work with diesel's VIN from Europe and Gulf market.
For example on the outboard side, the hubs have different part numbers, as do the hub seals, and I don't yet know what the actual difference is, so I've ordered the parts to find out. :)
On the inboard side, the differentials are completely different. The only possibility I see is that the Lexus spline axle looks larger, 35 splines on roughly a 36mm diameter, and it might be machinable and hardenable to fit. But again, I ordered an inboard tripod joints so with the parts in hands I will measure the actual differences. Don't worry I will keep all parts as spares.
I do not have USA Tacoma VIN, I already looks for parts but I never find a platform code who use DOJ, this is something made by Toyota USA, so I ignore if the Lexus DOJ CV's may fit an US LC250
I'm amaze by the minute differences in parts between platforms for same vehicle sold in various markets. For example front brakes why a less powered car has bigger (3mm in diameter) rotors as an US market? this implies to change the calipers, rotors and disc heat/dust shield. But guess what, the brakes pads are identical. This is crazy.
I ordered both
43410-AK020 SHAFT ASSY, FR DRIVE RH
43420-AK020 SHAFT ASSY, FR DRIVE LH
And this is how they arrived. I feel like they are used. What are yall thoughts?
That's usually how poor packaged cvs arrive. Where did you get yours from? I just got some that came in the same shape.
I ordered both
Mine looked similar, i spent some time straigthening up the bent sheilds before install. I chalked up the discoloration to the manufacturing process? Just make sure your boots don't have any cuts!
I ordered both
Take offs. At the minimum damaged.
My theory is that the Driver Side CV doesn't have the advantage of a longer axle, "Diff to CV" as the passenger side does. Maybe this shorter driver side delivers higher peak torque values when things start binding up. Kinda like using an impact gun with an exstension vs not. With the rubber Diff mounts and such a tight clearance to the upper oil pan, i would imagine that the diff must jolt upwards when a cv breaks? Also my theory is that a diff drop and properly torqued mounts should decrease the odds of this happening. But again, all theories...
Buy an extra oil pan if you are so concerned and carry a case of oil. I put my money on it not being an issue.......unless you are some You Tube yahoo looking for subscriptions. That's my theory.
Do it then.
Tell me you don't understand the 250 oil pan situation without telling me you don't understand.
A CV can be replaced on the trail.
A lower oil pan could technically be replaced on the trail, but would suck.
An upper oil pan (the one that's being damaged), I dare say would be an impossible trail fix.
You know, now that you explain it that way, I admit I am confused. Lower and upper oil pan??? Drain plug in lower one, but there is an upper also? really? new one for me. My bad.....Cuse. Pic could provide clarity.
But what % of these have broken? How common is it?
Upper oil pan cradle is cast aluminum.
Lower oil pan is stamped steel.
My theory is that the new, longer passenger side axle means that side inner joint is at less of an angle and less extended for the same amount of suspension droop, so that side is not ever in its weakest state.
The shorter axle on the driver side at full droop is at more of an angle and the inner joint extended farther (the tripod out at the edge of the cup) and therefore more likely to break.
I'm considering upgrading only the driver side axle, but that might bug me too much to not have them match.
I think if the axle doesn't break, there's not the shock release that's causing the oil pan to get hit.
I like your theory better than mine!
Nobody knows except Toyota and anyone who claims otherwise is full of it. There are a relatively small number of reports of these failures. That confirms that the issue exists. It does not confirm that the issue is remotely widespread. It is not known whether there is a design failure.
I love seeing all of the experimentation that everyone is doing to figure out what is going on and how to improve the truck to address any deficiencies, but onlookers shouldn’t see those efforts and conclude that they need to be worried about their Land Cruiser.
I'd recommend against that, good way to make the passenger side break very easily. I'd rather fab up a protection plate that could mount to the engine vibration dampener to prevent the axle from having that possibility.
IME it's quite easy to avoid CV failure, don't spin at your front tires too fast in any possible low to high traction scenario. So soft sand, all mud, all snow (knowing there is nothing below the snow that will cause sudden grip) all ice is ok. Anything else your at risk. If it starts hopping immediately back off slowly, never instantly back off a front tire spin situation unless they have already fully grabbed.
Low range, MTS whatever for the situation, Sway bar disconnected (if available), center and rear locked and crawl control being used in those types of situations will eliminate 99% of the possible failures to a CV axle.
Controlled constant slow wheel slip with no bouncing is fine, if doing so back off the slip easily though. This isn't an end all be all by any means though.
The reality is you will break something eventually if you're doing harder trails no matter what you do, serious off roaders bring spares. Even solid axles get broke on the trail. For my 80 which is converted to part-time for the sole purpose of moving the failure point to the locking hub which is a quick and easy trail repair (which I carry spares for), I also carry front axles, belts, fluids, grease, key replacement buttons for the lockers and center diff switch (since that is what allows 4WD in a part-time conversion) this is just part of my trail kit for the 80. Also the part time conversion affords me not having to fix the front to be able to drive home and if I were to break the rear I can drive home on the front by removing the rear drive shaft. My next parts to track down for spare is replacment front and rear diff locking mechanisms for the 80.
The 250 doesn't have that option currently, if I were going to wheel it hard, I'd carry a CV boot kit, both CV axles, grease, seals and hardware and tools to replace all of it on trail. I'd also probably fab up and install said upper oil pan protection.
The 200-300 series is known for breaking CV axles on the regular and it usually breaks at the inner splines (diff) and gets somewhat stuck in the diff. Would be great if the 250 had a part-time conversion but I don't see that happening, you also can't drive safely without the front axles installed. So short of having a way to have the inner axle stay put and have a way to seal the diff on the broken side you still can't remove the front drive shaft and just drive home in RWD with even 1 CV axle being toast.
If someone were to make an inner axle with flange and carrier bearing that would allow the hub bearing bolt holes to hold that in place (with longer bolts) that would solve the dead axle issue and allow for the removal of the front drive shaft for RWD to get back to civilization after removing the other CV axle and draining the front diff of course, so you'd need two of those made.
Passenger side axle failures would be quite easy to make a plate for the diff side to replace the axle clutch housing assembly and allow for 3WD operation (would probably need a carrier bearing and short shaft to hold that side of the diff), but you'd still need the hub side addressed. Drivers side looks like a special carrier bearing assembly would be needed with provisions to bolt that onto the diff bolts where it splits at the middle. None of this is feasible IMO on 250 as it will never be a serious offroad warrior like a solid axle setup, and to be cost effective you'd have to be able to DIY all this and have a spare set of axles to sacrifice to accommodate. Otherwise, you'd be better of going with Portals which is the only way these will ever be serious while maintaining the factory items IMO. It would be far easier to just put a solid axle up front and be done with it.
Would love to see a solid locking front axle from a 70 or 80 series adapted to work on the 250! If the gears exist this wouldn't be that difficult outside of SWD (if equip'd) and figuring out how to disable MTS/CRAWL/HDC without upsetting the nannies and in the end would be cheaper and much more practical than portals from a maintenance, width and cost perspective!
All great stuff. Again, I have learned something today...at the same time Toyota has a 50-60yr history with these and I , IMHO, doubt they would under engineer a component so close to a major source of damage....how many of these breakages are the result of careless, clueless, skill less, blatant abuse might be a better way to put it.
I can say for at least my own anecdotal experience, when I broke my CV I was NOT being gentle on the vehicle. I wouldn’t characterize what I was doing exactly the way you did, but I’m agreeing with you in principle for sure.
