Tacoma Trail Hunter CV Upgrade
ryanbumps
Portola Valley
2026 LC 250
Just installed the Tacoma Trail Hunter CVs.
I wanted to make a post since there isn't a ton of information out there about this upgrade and i personally have searched the internet for answers like the list below:
There are several LC250 owners who have experienced driver-side CV failures. We can reasonably assume that running a lift and larger tires increases the likelihood of CV breakage, but what some owners didn’t anticipate was a cracked upper oil pan as a secondary failure.
My theory is that when the CV joint fails, the front differential can jolt upward and contact the upper oil pan. There is very little clearance between the differential and oil pan, and the factory differential mounts use rubber bushings that allow some movement.
In an effort to reduce the chances of this happening, I addressed both the CV itself and the differential:
1. ICON differential drop
A diff drop has a few potential benefits on a lifted LC250. Most importantly, lowering the differential improves the CV axle operating angle created by the lift. Reducing that angle should reduce stress on the CV joints and potentially reduce the likelihood of failure in the first place.
It also creates additional clearance between the front differential and upper oil pan. If a CV does fail and causes the differential to move violently, that additional space may reduce the chance of the differential contacting and cracking the oil pan.
The ICON diff drop also replaces the factory rubber differential bushings with polyurethane bushings. The stiffer polyurethane should reduce differential movement under load, adding another layer of protection.
So the diff drop potentially addresses the problem three ways: better CV angles, more oil-pan clearance, and less differential movement.
2. Tacoma TRD Pro/Trailhunter CV axles
The Tacoma CVs use a different inner-joint design than the factory LC250 axles. The LC250 uses a tripod-style inner joint, which appears to be the weak point in the failures that have been reported. The Tacoma TRD Pro/Trailhunter axle uses a more robust inner-joint design rather than the LC250-style tripod arrangement.
So the Tacoma CV swap isn't simply replacing the LC250 axle with another Toyota CV. You're upgrading to a different and seemingly stronger inner-joint design, while the diff drop puts that joint at a more favorable operating angle.
One thing worth knowing if you plan to order the Tacoma CVs: you'll need a Tacoma TRD Pro or Trailhunter VIN. Apparently Toyota has flagged these parts and requires a qualifying VIN, presumably to keep replacement inventory available for the vehicles they were originally intended for.
Obviously, none of this guarantees that a CV failure—or resulting damage—can't happen. But for a lifted LC250 running larger tires, this combination makes a lot of sense to me: stronger CVs with a more robust inner-joint design, improved CV angles, additional differential-to-oil-pan clearance, and reduced differential movement.
43410-AK020Axle Assembly$414.221$414.22
43420-AK020Axle Assembly$402.741$402.74
You'll also need to order two axle nuts, the Tacoma and LC use the same nuts and they are staked instead of Pinned. They are a one time use item.
90177-A0023Axle Nut$5.171$5.17
If you are like me and don't inspect your boots before signing for the FedEx delivery then you might need this kit as well...
04427-0C051Boot Kit$54.251$54.25
After my original install i noticed a tiny snake bite on my driver side outer CV boot...:oops: "make sure you inspect your boots before you sign for your package"! I can't say for sure but i believe this happened in shipping. I needed to reboot which also required these special tools:
No real difference in drive feel, just piece of mind.
Didn't do a great job documenting with pics, but here are a few randoms:
Stock CVs
TRD CVs
Installed with pinched boot, and leaking.
Teardown for new boot kit
New boot installed: Unsure if it was necessary but i marked all the joints and axles with a yellow paint pen so i could assemble it in the same indexing as factory.
UPDATE: Here is a confusing diagram of how the inner joint is oriented. The Inner Joint Race and Cage are directional, and you can absolutely install the cage reverse which is no bueno. I'm using Diff as reference point. The cage has a small and large side. The inner race has a flat and taper inner diameter.
Finished product, Driver side. (y)
I'll keep updating as i rack up miles incase i see a shift in MPG or any other changes.
Cheers!
R
Nice. I've been thinking this is something to do in the future - as you said, for peace of mind.
You really needed the VIN from a Taco? That seems strange...
This is awesome! I've been trying to scrape together this info too. I'll probably upgrade soon, but not planning to immediately.
Thank you!
Where did you order from? Were you able to find any deals, or just order from local dealer?
It looks like you just unbolted the lower ball-joint mounts so swing the knuckle out of the way?
Good idea to use a bike stand! (y)
edit: Sorry, I didn't click your links before. That's probably where you ordered each part?
Yep, they called and needed last 9 of Vin inorder to process. Luckily my buddy has a TRD Taco :)
Thank you!
Yessir i included the links to the places i ordered. I would suggest to try and order from a vendor closer to you. Mine shipped acrross the county and it showed on the boxes, "they were a little beat up".
Correct on only unbolting the lower mounts. One thing that made life much easier the second time was loosening the upper control arm pivot. It was much less of a struggle to swing everything out of the way. No need to unbolt the sway bars with this route either.
@ryanbumps
FYI, hope you used the inner and outer axle snap rings from the boot kit? If not I'd go back and change the inside and outside snap rings on the cv shafts (inside, between the boots on the axle since you did a boot change and the one that locks them into the diff), they are designed for single use and quite often prematurely let go when reused. Axles seals are probably fine as well as the cotter pins but the list below is what Toyota calls out as non-reusable parts so everyone is aware. The cotter pins are the item listed as STD Part No Qty. 2 required. Items 4 and 9 not required if not replacing the boots.
Great info none the less, good job!
Toyota CV non-reusable parts list (including boot change out snap rings items 4 & 9).webp
Also, the inner axle snap ring is easy to remove if you put slight pulling pressure on the axle and use a jewelers screwdriver to gently work it down into the groove working your way around it with the pressure applied and then once compressed the axle half shaft will pull out quite easily from the outer joint, works for installing as well.
Another method involves dropping the joint briskly and catching the axle shaft, this is what I use, and have a 2x4 drilled out to accommodate the axle shaft going through it and placing the whole thing on my vice and dropping it, make sure you have a trash can full of rags or similar underneath to catch the axle just in case.
Both methods are shown in this video below, burfield axles but same principle. He doesn't address two key things in the video strangly (not applicable to the 250 series), no use of the special service tool to verify shims are correct for the knuckle bearings and no use of the pull gauge to verify proper tension on the hub bearings (though I'm sure his experience here doesn't require him to do the pull gauge), just struck me as strange for an informative video to not include the factory requirements?
@ryanbumps
View attachment 75749View attachment 75752
Good eye!! annd yes i did use all the new snap rings included in the Boot Kit. One concerning thing was when i removed the Inner Boot, the large inner snap ring seemed to have not been properly seated from the factory. Or maybe it became dislodged during CV removal... Regardless i made certain everything was buttoned up properly so i won't have to pull a CV hopefully for a very long time. Also these axles don't use Cotter Pins, the LC250 and Tacoma TH have the single use Axle Nut you lock on with a punch.
That can happen depending upon the force required to pull it from the diff side. From Toyota EPC data it looks like the internal ring is a rectangle wire type and the external ring (diff side) is circle ring type or are they both circular?
The inner ring on the Tacoma CV is a circular wire ring. The rectangular is probably only for a Tri Pod style joint.
Your Taco may be getting allot of CV axles replaced on it!?
In "La minute culturelle", the word "tacot" (the ending t is silent) is French slang for a beat up old car, the one that's noisy, rickety, and slow.
@ryanbumps
I haven’t dug into this yet personally so thank you for the detailed post. It’s my understanding that the GX550 got these upgraded CV’s. Did you explore the Lexus parts at all when searching for the upgrade? Likely the part numbers are the same so probably a moot point.
Had to stop watching video, machinist in me couldn't bear to see this. That job would take me 8 hours of course, sans steel hammers, which i realize the service guys dont have the luxury of time.
The CV axles are also part of the TRD-OFF Road Pkg, same part number, just ordered a set, you do need a VIN
Just to add another also. Also I heard you get an additional amount of droop travel with the CV’s. Probably too late to measure, but I sure am curious.
The upgraded Taco, etc. CVs can flex farther than LC tripod CVs, but if your CV was limiting travel you would have major problems.
