I still like this ROX truck prototype:
Finally got around to sorting out the mounting bolt / lug jigsaw to get this rigd swing out installed. Toyota OE lugs dont work, Rigd Lugs don't work, had to buy some off amazon along with some spacers. Annoying, but worked. Hope the wheel doesn't fall off!
View attachment 79317View attachment 79318View attachment 79319
Looking great! I really love the Rig’d wedge mechanism for keeping the mount tight in the hitch receiver.
Yessir, now just trying to figure out fuel storage on this thing. Have a 3 gal rotopax mounted inboard on it, and waiting to see if Gamiviti can fab up something that will fit through the center wheel hole that could store a Nato can + another 1-2 rotopax. :)
Before and after : 1 ReadyLift inch level kit. (For now) before pic and after
You might want to reevaluate carrying fuel inside the cabin!
Not sure if you're set on a hard mount solution. If not, there are kits to strap pair of rotopax to the tire, less weight and quickly removable. Common on wranglers.
By inboard I meant on the inside of the swing out. To the extent I expect needing more than 3 gal I started with the idea of a hard mount, but may be coming around to the strap em on the wheel method.
Hey Prob, I ran into the same thing. I wanted the same size lugnut as my LC lugnuts. So I machined out the slots for the lug bolts and installed them. You could do the same with a dremel or air tool with a carbide router bit. This way a standard lugnut from your rig will fit better.
If I had the tools / confidence to that, new bolts would have been the best path. I did end up with some lugs intended for a highlander then supplemented with 40 OD / 20 ID / 6mm thick washers to sit in the wheel to keep the highlander lugs centered on the rigd bolts. There seems to be plenty of thread engagement so I'm happy for now.
I'm realizing belatedly that I may have space to run 2x 3-gallon rotopax (stacked) on the interior face of the ultraswing, which feels more clean than slapping a ratchet around the tire and adding an expensive jerry can mount for the 3(?) times per year I would desire extra fuel.
Upgraded to the Primoworks arm rests, and dog covers. bigger platform on window edge for paws while hanging out the window and heads to nap on.
organized the internal Molle panels, one side safety gear, one side dog accessories.
wrapped a molle panel with door trim to take away harsh edge, mounted between from seats to keep dogs in the back.
Feel that I have covered every possible piece of plastic to protect against claws and drool.
I bought the side kick with the Rigd and it fits a 5 gallon Jerry can on one side and a 5 gallon Rotopax water or fuel jug on the opposite side. So you could add that to your setup for more fuel. I can get you pics of it if you want.
Appreciate that! Fundamentally, I have the income to do it ,and I actually run in kinda similar circles to one of the founders of rigd but I have a problem spending $350 to be able to attach fuel, which could cost another $200 for a Nato carrier + $100 for each nato can.
Trying to be more practical and dropping $50 for a rotopax mount and $100 for a rotopax, 3gal; especially given the infrequency of use. Rigd's solution ABSOLUTELY is the best integrated / aesthetically pleasing solution. I'm just struggling with $500 to carry a couple gallons of fuel a couple times per year. My use case actually has me removing the swing out to install a 4-bike carrier as well - so all the more reason to not load it up.
That said, I say this in the same breath of getting close to dropping $5K+ on a LH bolt action - hah! I'd just rather spent my money on a nice rifle :)
Ya nothing is cheap. I definitely like this Rigd setup and all its functions. Dropped $6k on my bolt action 2020 last year. So I know what ya mean. I can show you pics in a dm if ya wanna see that rifle?
We continue with some test with lights and bull bar
Got the 5 gallon water Rotopax and Rhino trash bag added. Getting Ready for some snow camping.
Latest Discussions
