Had 30k service done at local independent. Transmission, xfer case, diffs and brake fluid change. They did lube prop shafts and tightened bolts among a few other things. I went with dot 5.1 brake fluid and don't notice any difference in feel. Dot 3 is stock fluid btw. Cost was $1900, all oem toyota fluids, minus the brake fluid. Labor rate is $200/hr.
I have always done maintenance and repairs myself over past 30+ years, and now I remember why, expensive!! I want to keep my life time powertrain warranty, so a certified place has to do the work.
Now I'm thinking that cost of having a reputable shop do the maintenance will cost more than an engine or trans replacement in the long run, ive already spent nearly 3k having others do the maintenance (i dont trust the local toyota dealer with anything beyond selling me parts). Might be the last time I pay for service.
Added a DMOS Compact Delta Shovel and Universal Mount on the rear molle panel.
For the full post, click here
Hello everyone,
Yesterday was a rainy day, so I took the opportunity to spend some time with my LC GX at home.😍
I installed the rear bumper guards, as well as the front and rear Starvis 2 dash cam (with GPS) from @Mangoal
I also installed black covers for the taillights.
First impressions are great!😍
Installed A Pillar Ditch Light brackets with Baja Squadron Pro 2.0.
This is next on my list to give me some side splash for switchbacks. I also don’t have anywhere to mount lights in the front because there is no way I’m taking that bumper off to add a light bar and I don’t want to put a bull bar on it or add the weight of a new bumper. I’m hoping that the spots on the lights will give me some forward spot without too much hood glare. You’re look good.
I really like this but it’s a little pricey. I’m going to keep looking but this is the exact type of setup I’m looking for.
Fair. They had a decent sale over the summer. Maybe you could score a deal around the holidays.
You can as there is on the below radiator interior side. I did with Baja Onyx 8, using the Radiator Bolt Mount location, and customised flat alumunium plate as a bar resting mechanism to hold these light bar.
¡Hola a todos!
Hoy intento instalar estas piezas, pero no sé cómo quitar esta pieza del coche, y si es posible quitarla sin desmontar el parachoques delantero…
¿Alguien podría ayudarme?
Thanks for all
Finally pulled the trigger on some new shoes as well. A little Unoriginal…but I love them all the same + Labor Day deals were too good to pass up!
Method 705 +35 offset
Toyo ATIII 285/75/17s
Love it.. looking at the exact same setup. How are you liking it? Any rubbing.. and how is the road noise? TIA!
Latest Discussions
