๐Ÿ› ๏ธ What Have You Done To Your LC250 Today?
How have those CNCโ€™d brackets held up? I was waiting for your long-term report to get on a possible bulk supply list.
Working great, not sure if I'll make anymore. Ever since this tarrif war, all manufacturing in America, some how, got more expensive.
Just got back from a 2,600 mile round trip to my mom's and back. Almost all interstate driving at 70 MPH, trip average was 20.4. Clicked over 5,000 on the odometer on the way back, so time to do the tire rotation and oil+filter change (the 3rd - I did one at 1,000 and the second at 2,500) - this got me on the "every 5,000 mile" schedule. I collected a sample for analysis and will compare the results to the previous two.
It seemed premature to me, but just out of curiosity I decided to change the fluids in the axles and the transfer case. The magnetic drain plugs had collected the usual metal dust, but there were no large debris particles. I'd heard comments about metal contamination on other Toyota trucks, particularly in rear axles, and wanted to make sure mine was clean.
The front axle contains a much lower volume of lubricant than the rear, so I expected it to be darker, and it was. The rear axle and transfer case lubricants were visually very clean and while they shifted darker than new, it wasn't by much. Based on my observations, this lubricant change was unnecessary. I'll repeat all this at 30,000 miles and get on the normal schedule.
DanPauls - Nothing wrong w/ fresh fluid! Break in is important.
Everyone continues to focus on mileage & time, but I focus on the how my vehicle was used. We tow & do high speed driving in high heat, so in my mind thatโ€™s severe duty, & correspondingly It changes my service interval. Same for if someone muds, rock climbs or uses 4Lo quite often, you might want to service @ an earlier interval.
The maintenance time & miles is there for a reason for normal driving. Iโ€™d only be guessing that maybe 5-10% of the LC owner universe put their vehicle under conditions as to need to do different service timing than what Toyota suggests.
Clean fresh fluids are cheap insurance for longevity.
I bought one as well. Fits great & looks 1000% better than the OEM covers.
I couldn't justify CA$99.95 + tax for a piece of plastic that should have come standard on an LC. So I did the next best (cheap) thing.
I replaced my spark plugs at 42,000 miles. An easy 30 minute job to replace $28 plugs! The maintenance guide calls for replacement at 40K to meet emissions compliance, but I think they could have gone to 50K+ easily.
Got the missing/defective replacement parts from RCI in the mail yesterday, and installed the full skid package (engine, trans, TC, and fuel tank). Wasnโ€™t too bad using front ramps, a creeper, and a ryobi ratchet wrench. This time, I made sure the bolts actually worked in their threaded holes before starting (2 originals were not threaded correctly at the factory causing me to have to uninstall things last time).
Finally arrived and got these painted mirror covers on. Rave Off Road - factory replacements -OEM fitment . It was a pain taking the factory ones off, def like the look of the painted look and the flow and the wide stance it gives!
Got some Falkens and Trailhunter wheels along with an aluminum RCI skid plate for protection and easy oil changes. Installed the Victory Modular Low Profile roof rack and itโ€™s surprisingly very quiet on the highway.
View attachment 78193Got some Falkens and Trailhunter wheels along with an aluminum RCI skid plate for protection and easy oil changes. Installed the Victory Modular Low Profile roof rack and itโ€™s surprisingly very quiet on the highway.
Really looks nice. How do you like the Falken Wildpeaks?
Swapped out my Method 703 Falken WP AT4 255/80/17s for new Method 318s wrapped in my winter rubber - Nokian Hakkapelita LT3 non-studded 275/70/18s. Have a couple photos that also include the new BP51 suspension but itโ€™s very hard for me to get pictures right now because Iโ€™m in a cast. I liked the OEM wheels I had with the Toyota Heritage center caps but they will not fit with the new OME UCAs with the BP 51s so I got the 318s with the 25 offset and the fit is great.
I really like them, but i kinda messed up and went with 275โ€™s E rated due to less weight compared to 285โ€™s C rated ones, I should of sticked to C rated for a better more complaint ride. They are quiet, and have really good grip
In the rain, but chose to run them at 33psi cold pressure to get a softer ride which works until I wear them and replace them.
After I saw my last post - wasnโ€™t liking my front air damsโ€ฆnow removedโ€ฆdoes look better - there is still a black flap on each side that can still be removed - we will see if those will come off too.
I removed those flaps and reinstalled the clips that held them in.
Latest Discussions
