GVWR - LC 250 limitations
BMFS33
⭐ Supporting Member
Colorado
2026 Land Cruiser, 2023 Audi A6
I've been building out my LC for about a year a little at a time. This past month or so I started looking at bumper and winch combinations and I began to think about weight, because they certainly add weight to the front of the vehicle. Since I was adding an OME BP-51 set up, I easily could have adjusted to handle the additional weight. But it got me thinking further, how much weight can I reasonably add to this vehicle. I already have under armor that I've added, larger 33" tires in E load and Method 703 which also add weight. So I started calculating all of my gear and other items that go into the truck for a weekend in the high country and learned that I run out of available capacity and push the limit of the GVWR pretty easily. To give you an idea of where I am now, without a bumper, winch, rear bumper, roof rack (all items that I would have loved to add but can't), I have this table below to simply illustrate how quickly one runs out of available cargo/additional available weight capacity, You'll note that if I'm traveling with two people instead of just me, that I pull the rear seats to give me more capacity. What I'm packing is not very much and I've utilized extreme lightweight packing gear for things like cots and chairs.
TOYOTA LAND CRUISER 250 OVERLAND BUILD CONFIGURATION SUMMARY
Vehicle Platform: 2026 Toyota Land Cruiser Premium (Hybrid i-FORCE MAX)
Location/Elevation Base: Morrison, CO / 6,000 Feet
Active Build Strategy: Maximum Weight Optimization & Complete Seat Delete
1. PRIMARY VEHICLE BASELINE SPECIFICATIONS
  • Starting Payload Capacity (Factory Max): 1,100 lbs
  • Gross Vehicle Weight Rating (GVWR Target): 6,725 lbs
  • Powertrain Architecture: 2.4L Hybrid 4-Cylinder (6,000 lbs Towing)
  • Primary Suspension Upgrades:
- Old Man Emu (OME) BP-51 Internal Bypass Shock Absorbers
- 2.5-Inch Front Lift / 2-Inch Rear Lift (Stance Leveled)
- OME Upper Control Arms (UCAs) & DuroBumps Progressive Bump Stops
- Current Valving/Clicker Configuration Settings: 1:3 Front / 2:4 Rear
  • Summer Running Gear: Method 703 Wheels (+35 Offset) / Falken Wildpeak AT4 255/80/17 Tires
  • Winter Running Gear: Method 318 Wheels / Nokian Hakkapeliitta LT3 275/70/18 Tires
  • Under-Vehicle Armor: Toyota OEM Upgraded Skid Plates (Engine, Transmission, Rear Differential)
2. COMPONENT WEIGHT REDUCTION METRICS
* Second-Row Seats Deletion (100% Complete): -125.0 lbs SAVED
- Passenger-Side 60% Split Assembly Removed (-75.0 lbs)
- Driver-Side 40% Split Assembly Removed (-50.0 lbs)
  • Factory Emergency Equipment: OEM Mechanical Bottle Jack Removed (-8.0 lbs SAVED)
  • Tool Storage Adaptation: Replaced Rigid Heavy Box with Lightweight Soft Bag (-20.0 lbs SAVED)
  • Roof Configuration Optimization: Factory Crossbars Omitted (Bare Side Roof Rails Kept)
3. FIXED OVERLAND MODIFICATIONS & BASELINE STOWED GEAR MANIFEST
  • Structural Chassis Upgrades: Heavy Steel Slee Rock Sliders (~130 lbs)
  • Exterior Lighting Array: Nacho Quattro Supreme Pods (Ditch Cowl Mounted, Amber DRL, Spot/Flood)
  • Audio Hardware Enclosure: Rear Cargo Hold 10-Inch Subwoofer Enclosure
  • Emergency Safety Apparatus: 2.5-lb Fire Extinguisher & GlueTread Patch Kits (Tread & Sidewall)
  • Integrated Air Management: Morrflate Air Compressor & 4-Hose Set in Soft Storage Config
  • Hydraulic Vehicle Recovery: Safe Jack Sergeant 35-lb Hydraulic Lifting Kit
  • Field Recovery Components: Synthetic Recovery Lines, Kinetic Ropes, & Soft Shackles Only
  • Primary Wilderness Shelter: REI 2-Person Ground Tent & Marmot Sleeping Bag System
  • Baseline Camp Living Gear: Helinox High-Back Chairs (2) & Helinox Cot with Leg Extensions
4. DYNAMIC TRIP CARGO & CONSUMABLES PROFILE
  • Onboard Personnel Load (Two Occupants): 400.0 lbs
  • Potable Trail Fluids: 5 Gallons Wilderness Water (~8.34 lbs/gallon = 41.7 lbs)
  • Base Camp Kitchen Gear: Camp Chef Everest Cooking Stove (12.0 lbs)
  • System Pressurized Fuel: 4 Coleman Propane Canisters (8.0 lbs total loaded)
  • Base Cold Storage System: Yeti 35 Cooler (Fully Provisioned Baseline)
  • Onboard Refreshment Packs: 12-Pack of 12oz Soda Cans (9.8 lbs)
  • Camp Furniture Infrastructure: 4-Foot Folding Utility Camp Table (15.0 lbs)
5. FINAL CHASSIS PAYLOAD & MARGIN ANALYTICS
  • Total Combined Upgrades, Gear, and Occupants: 954.5 lbs
  • Net Safety Cushion Remaining: +145.5 lbs UNDER GVWR
  • Recommended Buffer Allocation: Soft personal apparel duffels, seasonal safety layers, dry rations.
  • Packing Guideline: Position downsized tool bags, water supplies, and heavy cases flat on the cleared
second-row cabin floor footprint to centralize chassis weight over the OME suspension geometry.
CONFIGURATION STATUS: OPTIMIZED | SAFE OPERATING LIMITS MAINTAINED
What all this means, I'm not so sure, other than to state that the LC does not have much available weight to be added to this vehicle to stay under the max capacity rating. You basically can't fully build out one of these completely without sacrificing everything that comes along with running a vehicle over maximum capacity. I will definitely be setting up camp before tackling off-road mountain passes and removing weight from the vehicle. The last thing I need is to exasperate potential brake fade because I'm overloaded coming down Red Cone pass or something similar.
I think that if I would have researched this more on the front end I may have actually waited for the GX550, which gives one about 600 additional available pounds due to some more robust components, which also increase the towing capacity of that vehicle. I have to say that I love this vehicle, it's one of my favorites that I've ever owned. Heck, I find errands to run sometimes just to go for a drive. But I am disappointed that this is an issue and it's certainly not set up to handle a full overland build. At least that will save me some money but damn would I like to have upgraded front/rear bumpers with appropriate lighting. But, I don't have the available weight capacity.
How many of you look at this when doing your builds? I don't think that I am making too much of this.
I owned a Tacoma for a long time as a full Overland Build and now have an F350. That should tell you all you need to know.
That’s not as clear as I think you think it is. Is the point that you decided to move from a midsize pickup to a 2-ton truck? Obviously a massive payload increase, but a 2-ton truck is not at all suitable for the use case that I understand OP has.
I would have a really hard time with a truck that large on most CO trails that I drive. Granted some may be able to do it but it’s too much truck for me for that. I actually got of my really nice F150 Platinum when I bought my LC. But I hear ya.
Fair enough.
My overall point was if you decide to build a HEAVY overland rig you likely need to choose a heavier rig with a larger payload OR if you need a smaller midsize build you need to focus on building it as light weight as possible.
Do you need heavy steel bumpers? A winch? Tire swing out? Full skids? Dual batteries and a full fridge, freezer and ice maker? Maybe you do maybe you don’t but if you’re working up against a 1000lb payload those aren’t really an option.
You buy the vehicle for the mission not the other way around. I have built countless overlanding rigs and there’s a reason that most every vehicle you see at an Overland Expo these days is an HD truck. People want more comfort and heavy things and most full size trucks are only marginally larger than a midsize and can still fit most places.
My F350 has a Supertramp camper on it and rides on 37’s with no lift and even with a 4212lb payload it still needs airbags to ride level despite the camper being sub 2000lbs.
My Landcruiser is only getting wheels and tires and a lightweight drawer/ sleeping platform in it. This is my use case not everyone’s. You can’t increase GVWR regardless of suspension or springs so you need to work within the confines of that platform, or choose a different platform.
Again this is my experience from a couple decades of vehicle travel but this is America and people are free to do what they want. Just be careful exceeding GVWR not only from a liability standpoint but much more importantly the safety of you and your loved ones.
Just my $0.02 and worth exactly what you paid for it.
Final note remember your legal payload includes people so if you have a family of 4 in your LC you may have to settle for a roof top cargo box with a Gazelle tent in it and a pile of sleeping bags. 😉
And yes, I do pay attention to GVWR when completing a build. I have the CAT App on my phone and bring all my rigs over a CAT scale to be sure they are within safe working limits.
Ive been eyeing a Ram powerwagon for years for payload and do-all capability (i know gvwr is reduced compared to the other 2500s) but it is enormous and needs 6 lanes to make a u-turn. On last off road trip (CO) there were a couple tight squeezes in LC, powerwagon would be a nogo.
Do you want a goat or a clydesdale?
I’ve spent a lot of time making sure that what I’ve done and what I pack will not exceed the weight limit. I’m simply curious what others have done. I don’t really need the heavy steel bumpers so those got cut out as a result of the available weight. I do need heavy sliders and full skids. They’re essential on the trails here and were the first things that I purchased. I really wanted to add a roof rack as well as the aux fuel tank but those are out now. Basically, my build is done and it’s pretty stock besides some suspension upgrades, tires and wheels and underbody armor. Thankfully I rarely have 4 in the vehicle and when I do I’m not on a multi day trip and can keep the payload very light. Usually it’s just me or me and my buddy when doing multiple days. I’ve bought almost all lightweight gear and will look to shave even more cargo weight by getting light weight kitchen gear and a lighter weight table.
I’m able to manage it but I am curious how others have attacked the issue because it’s very real how little available additional weight it can handle.
This is why I have both lol.
I actually owned two Powerwagons, a 2013 and a 2015 and while they are actually pretty good offroad and come extremely well equipped from the factory as you said, payload sucks for and HD full size truck. In fact Supertramp doesn’t recommend any 2500 Ram to carry a camper because of the rear coil springs.
My Tremor is not as good offroad but has a much higher payload, interestingly enough the trailturn assist on the Tremor works pretty well and my camper being a pop up makes for a (sort of) compact rig for off-roading.
I’m sure people are aware but the Expo Portal Forum offers a lot of insight on Overlanding builds though the LC250 presence on there is quite small.
Nothing about this rig differs from a Tacoma, 4Runner, or any other midsize rig talked about on there.
Here’s a picture of the big girl, honestly just because I think it’s awesome and wanted to share lol.
It should also go without saying there is a difference in everyone purposes for building out a vehicle. Someone who offroads only, and someone who travels for weeks at a time need different rigs. I admittedly don’t “off road” very hard anymore and my vehicles reflect that. If that was my primary purpose I would have a Wrangler on 37’s.
We travel for 2-6 weeks at a time in the big truck. My new Landcruiser is only going to be built enough for me to sleep for a night or two when on a fishing trip.
It’s very easy to go overboard with accessories that add weight fast.
FWIW nearly all my travel is done with my buddy and his wife and they use a Gladiator with an OVRLND camper. He packs like a backpacker and has less luxury but still spends many weeks straight in the camper.
The LC250 GVWR is limiting what can be added, for sure. I knew this when I purchased mine. A couple of things I did to help mitigate the added weight was going with a C6 roof tent. Not as nice as the full RTT, however, at 25 lbs I can remove it for day excursions and reinstall for overlanding. I'm adding a C4 winch fit with a Warn 10S. This maintains the front looking factory without a lot of additional weight of the full steel bumper...there is the sacrifice of protection for a more aggressive rock crawling/tree dodging experience here in Colorado. With all said....I still miss my F150 super crew and all that interior space! I really do enjoy my Land Cruiser... it has taken me over obstacles that others did not think possible.
This will sound silly and counterintuitive, but realistically the platform can handle it easily. I’ve seen full rear and front metal bumpers with winches and so forth, with full campers and loads in them. It’ll do fine.
The BP-51’s alone will increase your GVR
For reference I’m running the same BPE set up along with a full winch kit and light set up. I still have everything installed (no deletes) drives great, and I’m also getting the metal rear bumper on
I had never really looked at the mechanics and capabilities of the ARB shocks until now, only relied on their reputation. The increased Gross Vehicle Mass goes up noticeably (even though not recognized here in the States). Thanks again for that info.
I definitely think similarly on the weight issue. Not for anything other than less is better in my opinion and it's easy to add so many things you might never really need. The biggest for me is the bumper - I think one day I will change bumpers both F&R but consider the weight along with structural integrity too. Its all a balancing act.
Like in many things "got to know your limits". Like mentioned earlier in this thread. The back packer example. So build out what you need. Yet consider applications and limits. You MPG's and tires will thank you...
This is incorrect and frankly very bad advice. GVWR is set by the factory and does not change because you add heavier springs, air bags, or a big brake kit. GVWR is on the door jamb of your vehicle and is determined at the factory.
You can change GVWR on some vehicles (generally commercial aftermarket RV companies can do this) but adding heavier springs to keep the suspension from sagging is only a very small piece of the legal part of it.
Again I don’t care what you do, and it seems like every Overland Toyota is over GVWR anyway, but I don’t want people to believe that exceeding the design limits on a vehicle is a good idea.
Keep your brakes and stability control in mind, they were designed for gvwr and below. Normal use might not be an issue, however high speed accident avoidence or extreme braking demands could be. Ideally, braking performance needs to be improved when significantly increasing the weight of vehicle.
My rant on the matter: Pork Chop
I’ve kept my 250 close to stock and have enjoyed the simplicity.
I think this view comes with age and experience. People new to off-roading and especially with the rise of overlanding over the past 15 years tend to think more is more…. When anyone with a few trips under their belt and some time offroad realize generally less is more.
I mentioned earlier I have a heavy overland rig but I bought the rig for the mission. And I’m close to a ton under GVWR. This stock LC250 can and will probably go most places my F350 on 37’s would struggle with because it’s lighter, shorter, and lower.
I’ll admit I like the look of bumpers and a swing out but I can’t see the point on this particular vehicle. If you want to rock crawl a stock Jeep Rubicon is going to outperform this platform every time.
Latest Discussions
