YAGI is Japanese for Goat
Well all registered for Moab and vehicle preps and upgrades are finished except new headlights from TEQ Customs
Maintenance items addressed for the trip:
Upgrades done:
Future plans and final build:
- All fluids and filters changed, to include Transmission flush and filter cleaning, Coolant flush, and brake flush.
- All rubber hoses replace (Took two 12 hour days!)
- Radiator replaced with Terrain Tamer HD all aluminium no weld unit (Manufactured by the same company that makes Ferrari Radiators, wasn't cheap) to address 35 year old plastic end tank radiator a ticking time bomb
- Heater control valve replaced, same as above. Replaced with Murray 74642 unit as OEM is NLA, info on Mud. Only difference from mud is the only modification required was to remove the arm from the original and place it onto the replacement vice using the arm it came with (no modification required on new valve to fit the arm in the correct orientation.) All that said this is a RHD drive so this may not be the same on a LHD.
- Drivers window run replaced all others cleaned and greased with Honda white grease, info on Mud.
- Replaced steering stabilizer
- Replaced timing, belt, tensior, front case seals, fan belts, fan clutch and coolant thermostat
- Corrected 13 boost leaks
- Replaced battery terminals on primary (Left side) battery
- Cleaned and flushed intercooler
- Repaired rear hatch door linked power lock function
- Painted undercarriage and removed all surface rust
- Painted axle ends
- Buffed and polished paint X2
- Painted rear tire carrier
- Painted front grill valance with OEM base/clear
- Installed missing transmission temp sender for VDO gauge
- Replaced worn turbo and capacity stickers
- Repaired VX limited trim gouging
- Added additional front fender well splash guards
- Installed OEM power steering box splash guard
- Adjusted transmission line pressure to spec
- Adjusted AC idle up to spec
- Adjusted idle to spec
- Inspected and tuned mechanical injection pump
- Replaced faulty manual boost controller with Turbo Smart unit and changed boost reference lines
- Raptor coated front bumper and frame sliders
- Replaced tires with Milestar Patagonia AT Pros (37 lbs weight reduction)
- Tested winch operation, cleaned winch wiring connections, installed boots over terminals, wrapped wiring in wire mesh sheathing and purchased manual controller in case of remote failure
- Cleaned up bird nested trailer brake controller and trailer 7 pin wiring harness in rear fender well interior storage
- Inspected brakes and axles both will need done within the next year or two
Upgrades done:
- Installed Dakota Digital dash to convert from Metric units to Imperial and gain a host of functions (trip computer to name one)
- Installed Tiny Tach, Pezio Electric Amplifer and Injector tube tach pickup to make tach operator on new gauge cluster
- Escape Gear seat covers, center shift console and window armrest. These are the best fitting and looking seat covers I've ever purchased, absolutely love them!
- Installed fire extinguisher and field first aid kit for safety and TLCA trail compliance
- Converted 99% of the interior (white) and dash backlighting (deeper green to match Dakota digital) to LED
- Added trail bling patches, nothing I've tackled yet but the truck has twice and I'm about to!!
- Installed Well Visors rain guards, OEM NOS Land Cruiser sunroof deflector and rear window dust deflector (Visor)
- Installed a direct to battery plug and play headlight wiring harness to correct dim headlights and to fix an intermittent high beam indicator on the dash from Headlight services LLC out of Abilene, TX
- Installed new Head unit with Navigation and Car Play, tuned Crossover and Amplified sub that came with the vehicle. Sounds pretty good I guess?
- Installed front and rear trail cameras to go with head unit
- Installed Nacho Grande lights and Morimoto fourbanger flush mount (vertical adjustable) fog lights on and in the front bumper.
- Installed black lug nuts
- Modified OEM mud flaps and combined with JAOS large universal flaps
- Installed Delta 3" Panhard correction bracket
- Installed Delta rear view mirror arm with a GM rear view mirror that added homelink, compass and outside temp.
- Installed window rocket to better regulate power to the windows, these things work great now!!
- Installed keyless entry with Hazard answer back harness
- Installed catch can to monitor blow by and gauge engine health
- Installed magback phone charger and four USB fast charge ports
- Installed Bluetti Charger 1 for faster charging of Buletti power stations
- Installed Midland 50 Watt GMRS Radio, antenna and Mic retractable leash
- Installed center console arm rest
- Covered center console lid with Faux leather, not sure I like the look but it does hide the gouges
- Painted center console with interior plastic dye paint
- Still waiting on new headlights
- Replaced rear tail lights to address water ingress into reverse lights
- Rebuild front and rear axles
- Replace brakes
- Larger intercooler with 4" panel style filter box to further reduce EGTs
- New Turbo? Don't need more power or boost just want a known stronger unit
- 170-240 Amp alternator
- Possibly an Australian made metal snorkel for further aide in EGT reduction as needed?
- New grill eventually once I decide on direction?
- Convert rear sway bar to manual disconnect, front already done
- Have tint replaced (some scratches after 35 years of use)
