Fuel Grade?
Really appreciate posting your dyno results which confirm ther tests done on T24A engines. This testing was done on a part time 4WD 4Runner (i.e. not a full time 4WD Limited/Platinumt trim) correct? If not, I wouldn't the actual dyno #s/gains for a LC250 would be somewhat lower due to driveline losses of full time 4WD?
I have dynoed a full time 4wd 4Runner hybrid, which is essentially the same. (same dyno as other graphs, but using both rollers). Custom Tuned (I tuned it) gains on that particular vehicle were unusually high- almost as though the higher trim has a 'comfort' tune. In theory the gains should be similar, but as mentioned the over parasitic loss on both runs would be higher than a 2wd.
I have dynoed a full time 4wd 4Runner hybrid, which is essentially the same. (same dyno as other graphs, but using both rollers). Gains on that particular vehicle were unusually high- almost as though the higher trim has a 'comfort' tune. In theory the gains should be similar, but as mentioned the over parasitic loss on both runs would be higher than a 2wd.
Interesting, looking at about a 23% drivetrain loss from the factory rated 325hp if I can still do math. Sounds about right for full time 4WD! Will be interesting to see if the new GX550h has a somewhat more powerful tune that as you suggest could be available.
No doubt it likes it. I bet it feels equally better in a 4Runner...Those aren't cheap vehicles in that top trim either. They tap $70k also....$70k ain't what it used to be. Thanks Donald.
Regardless of MSRP the turbo and compression ratio will probably appreciate it.
I know there will be a day when I can’t get my preferred fuel (i.e. road trip up north). I have absolute faith the Land Cruiser will compensate for lesser fuel.
I just read it now. Didn't have time earlier. Seems to fall in line with my thoughts.
The guy that said octane doesn't matter on an ECU not calibrated to use it....agree. Not talking about the tune here.
At the same time, on an ECU capable of advancing beyond an 87 octane tune, you confirm my thoughts. It's not like you knock a second of the 0-60. It's the crispness of initial throttle tip in, etc. I have seen those gains via premium v regular in another thread and it makes sense. Won't be exact but 343??347 stick in my head.
You are in New Mexico. To be running 86 octane, you must be at altitude so tuning to optimize the air/fuel mix and turbo are even more critical than at sea level. I can definitely see advantages to a tune for your conditions!!! Would and will love to see what happens with premium stock v premium tuned.
Finally, I suspect the ECU tuning on a hybrid v non hybrid are indeed different. Your information is very helpful, but more ancillary to our discussion of Tacoma/4Runner v Land Cruiser and Premium v Regular, and factory specs..... Just trying to keep the vision clear.
Pretty much all turbos traditionally have run on premium, ........
