1958 vs LCLC off-road software (A-TRAC(?) vs MTS)
That is odd.... you would think that the module (if he bought the correct one) would be pre-programed with the right software?????
Our 1958 not having it would prolly need a patch to understand what the new device is telling it. Hopefully I’m wrong and it’s as easy as swapping parts.
The system has to have the module address registered on the vehicles CANBUS network any module that communicates with the required modules to support MTS would need to be verified to have comms setup with that address as well. I highly doubt the DIM is capable of communication with the MTS components.
An end user can’t do software/firmware or module configuration in GTS+, software and module configurations are likely tied to VIN so the only dealer I see being likely to assist would be Ed Martin Toyota.
I’m sure it’s possible but the cost is likely prohibitive.
If I had to guess you need the MTS buttons, 4x4 module, skid control module, body control module and the larger DIM along with configurations on all.
Usually even new replacement modules require software and configuration to work they are almost never just plug and play on a CANBUS network.
If they are from a salvage you may be able to get away with plug and play.
Probably the easiest way to figure out what is required is one vehicle with and one without and begin swapping components until it works.
Could be a costly experiment.
Seems for the gx460 it was as easy as swapping modules (Only for modules 2019 and prior). To be honest, I’m not pressed to make this work as this 1958 is more than capable of meeting my needs. Especially since I never had a 4x4 or AWD vehicle before. If they are able to make it work, it would be a fun weekend project.
I do agree that meeting up and swapping parts till something works is the most logical approach in this.
I was hopeful it would be as simple as the FJ cruiser was with the A-Trac upgrade, it was pre wired for it and if your's didn't come equipped with it, all you needed was the a-trac button to plug into the empty slot and you had it.
Interesting enough just saw that 4th gen taco folks are doing the same thing with success.
It only worked for 1 person out of all that tried it. And even for him, crawl didn’t work and it was questionable if MTS was actually working or if it only showed up the drive mods on the display.
I may be wrong, but I think both MTS and Crawl also need different brake actuators. The fact that crawl doesn’t work may suggest that the module is unable to control traction even if you manage to get it activated. Same would also apply to MTS.
Stand corrected
Curious if any progress has been made on this thread since last year?
