Which Differential Oil - 75W-85 or 75W-90? Even Toyota doesn't seem to know.
I went ahead and ordered some Redline 75w-85.
Toyota is the only supplier I can find that I trust for the 75W transfer gear oil, though.
Anyone have the front and rear differential and transfer case drain plug washer part numbers?
Don’t quote me on this but chances are it is this.
Redline Synthetic MT-LV. MT-LV 70W/75W GL-4 Gear Oil is listed as an OEM replacement for the Toyota 75W. I used this in manual transmission Tacomas for the transfer case and transmission without issue and made them smoother shifting too.
There's also the Ravenol option that's to Toyota spec and seems to be a common and good choice for Toyota transfer cases and manual transmissions. 75W Gear Oil - RAVENOL MTF-3
Ravenol also makes 75W-85 to Toyota differential specs. And sell a change kit for the LC250:
I'm going to use Amsoil Sever Gear 75w-85 in the differentials (already bought it). And the Ravenol 75W in the transfer. Going to do the front dif at 15,000 miles (soon) and the front and rear dif and transfer case at 30,000 miles.
I’d like to do the fluid change on my own. Does anyone have a tutorial video to share. I’m planning to change the front, rear and transfercase fluids. I currently have 17k miles
These are pretty universal and easy like changing motor oil, if you look at any Tacoma or 4Runner video on youtube it'll be the same. Basically, just remove the fill plug then remove the drain plug. Once it is done draining put a new crush washer on the drain plug and reinstall. You either need a pump or squeeze bags for the fluid (some oil like Amsoil you can buy in easy fill squeeze bags). You fill them until fluid runs out the fill hole, stop so not to overfill beyond the bottom of the fill hole and put a new crush washer on and reinstall the fill plug. The drain and fill holes are easy to identify looking at the differentials and transfer case. But like I said, should be easy to find a youtube video of a Tacoma or 4Runner if you want to double check.
Thank you for the reply. I’ve been doing my own oil and filter changes on my lc250 and I thought it wouldn’t be difficult do a drain and fill.
It’s not difficult, make sure you can loosen the fill hole bolt before draining. A gear oil pump makes it much easier.
Ozark Trail Marine Gear Lube Pump 11891OT7
Thank you for your quick response.
I believe that for the rear differential the socket size is 24mm, right?
What is the front differential hex/socket size for our lc250? I saw someone posted a video on a 5th gen Tacoma that used a 10mm hex socket.
Rear differential and transfer case are all 24mm.
Affirmative -front differential fill and drain plugs are 10mm hex.
Fill plug torque = 40nm
Drain plug torque = 65nm
Oil capacity = 1.22 litres (unsure in quarts)
Fill plug crush washer 12157-10010
Drain plug copper washer 90430-24017
Affirmative - front differential fill and drain plugs are 10mm hex.
Do you have torque specs for the rear diff and transfer case?
Front Diff:
  • 10mm Hex for both drain and fill plugs
  • Fill plug = 40nm
  • Drain plug = 65nm
  • Fill plug washer = 12157 - 10010
  • Drain plug washer = 90430 - 24017
  • Oil spec LT 75w85 GLS (08885 - 81060) 1 litre bottles
  • Oil Capacity = 1.22 Litres
Rear Diff:
  • 24mm socket for both drain and fill plugs
  • Fill plug = 50nm
  • Drain plug = 50nm
  • Fill & drain plug washers = 12157 - 10010
  • Oil capacity = 5.62 litres
Transfer Case:
  • Fill plug = 37nm
  • Drain plug = 37nm
  • Fill & drain plug washers = 90430 - 18008
  • Oil spec LF 75W (08885 - 81081) 1 litre bottles
  • Oil capacity = 1.40 litres
Front Diff:
  • Fill plug = 40nm
  • Drain plug = 65nm
Rear Diff:
  • Fill plug = 50nm
  • Drain plug = 50nm
Transfer Case:
  • Fill plug = 37nm
  • Drain plug = 37nm
Very much appreciated.
Question: is the oil spec for front and rear LT 75W85 GLS the same if I bought 75W85 GL-5?
Front Diff:
  • Fill plug = 40nm
  • Drain plug = 65nm
Rear Diff:
  • Fill plug = 50nm
  • Drain plug = 50nm
Transfer Case:
  • Fill plug = 37nm
  • Drain plug = 37nm
Where did you get the parts numbers, TIS doesn't seem to list them anywhere in the instructions.
