Salt Shift Rust Shield Applied after Fluid Film cleaning
Pazich
San Diego, CA, USA
2025 Toyota Land Cruiser LC
I finally got around to clearing off last year's heavy (and super messy) coating of Fluid Film which did hold up admirably, even though the truck only saw minor salt during a trip to Big Bear, outside of what's kicked up on SoCal's very dusty trails. I coated the entire frame with a healthy layer and after I cleaned it off, I didn't find any corrosion, including places where the factory frame coating had rubbed off (story for another post). The only downside is that Fluid Film is really messy, since its oil based and doesn't harden, picking up dust and debris like it's nobody's business. It normally isn't an issue, but I do find myself covered in dark dirty oil and pebbles every time I get under the car, and it likes to hold debris to just about everywhere it touches.
After my last trail drive, I cleaned the frame with a wheeled frame chassis cleaner attachment using my pressure water and a rust preventative cleaner that Salt Shift also sells. After that, I went under the car with a short nozzle pressure washer handle and blasted the rest of what I could fine, getting soaked in the process. Next was light scrubbing with some car cleaning brushes, and then more pressure washing, rinsing, and air drying. After inspecting my work, I found I had to use clean rags and light all purpose cleaner to wipe up the super thick gunked out spots which was a real pain.
Once it was all said and done, and I gave the car another day to dry, I gave it a coating of Rust Shield, which is supposed to level and try into a hard coating and not pick up any debris or let liquids cling to it. It comes in a regular bottle with a handspray attachment which made application pretty easy. One bottle was more than enough to coat the entire underside and then some. So far I'm very satisfied with how clean it looks and the lack of dust it has picked up. I'll have a better idea of its nonstick properties during my next offroad adventure. Time will tell if it lasts the 6-12 months advertised and how much protection it actually offers, and then I'll decide if I continue using it or go back to Fluid FIlm.
I admire those that live in dry locations that do not have the salt issues we have here in the Midwest! I find that Toyota still does not do a great job of frame coating, in my opinion. Especially with all of the frame rot issues they have had over the years, what I see on my two Land Cruisers, not much has changed.
I have used Fluid Film before, it works great, but like many of the films and coatings, it is just messy to apply, and messy along the way. I wish there was something a bit better. In the meantime, I find myself under the vehicle early spring and then in the fall with my rattle can of satin Black Rustoleum, taking care of all the surface rust spots, weld areas etc. that need touched up. It works, but still a pain. I’m amazed at how much rust I find, and I am a big proponent of undercarriage spray cleaning, especially in the winter months.
Come on Toyota, what gives?
Triple-boiled Linseed oil works fabulous. Difficult to apply, needs to be heated and brushed or sprayed while heated. Messy application but it dries to a semi hard coating and doesn't attract dirt, oil or anything.
We use this at work and it protects raw steel in constant saltwater environments for 30 years without any rust forming. Once it's on it's very difficult to remove so may not be the best in all locations on a vehicle under carriage. I've thought about it putting it on one of my rigs but haven't pulled the trigger, instead I wire brush and use rust converter followed by paint annually on my vehicles and I'm not in the rust belt just a little anal about rust prevention.
Rust oleum Rust Converter is what is used here. With success for years. Its a rattle can flat black spray that coats and not only inhibits but eats oxidation thru a chemical process. So after winter a good undercarriage wash, some wire brush bad areas in reach. Simple spray on and done !!
