There is a lot going on in the LC hybrid driveline, & to me it is much more complicated than the normal RWD or P/T 4WD systems. Been digging into the why these make heat & what I cn do to better control it. For less cold markets, the PPEPower Thermal Bypass (Thank You @Bad1975) just might be my ticket for towing w/ the LC AT, along with/ holding gears in Manual mode.
Below is my summary from playing in AI collecting info on how the heat is being made.
The LC hybrid driveline layout order is:
AT Torque Converter: The e-motor's rotor drives the torque converter impeller, so the converter sits after the e-motor & smooths launch & multiplies torque from a stop. It has a 3-disc friction system & lockup clutch that ties input to output mechanically once speeds match. The 3-disc converter has more friction discs to give much higher clutch capacity in a smaller compact package, which matters with the combined engine + e-motor torque. It can lock earlier & hold, or can run a controlled slip to damp vibration, supposedly without overheating the clutch.
Electronics matter. Converter slip is one of the biggest heat sources in a AT. The more time the lockup holds, the less heat goes into the fluid. The transmission ECU is driving most of the AT activities w/ solenoid selections to specific ATF valve circuits. Heat also comes from K0 slip during starts & from lockup slip in controlled-slip mode, which fits with this hybrid driveline running warm even while using a thermostat & coolant-based heat exchanger to control the ATF temperature.
I’m @ 11,700 miles. Changing TC, diffs & AT fluids around 15K. If AT fluid smells burned I’ll add the PPEPower Tacoma bypass.
- T24A Engine
- K0 Clutch
- Hybrid Electric Motor
- Torque Converter
- 8spd AT
- Transfer Case
- F/R Driveshafts
- F/R Differentials
- Closed: engine & e-motor both drive the transmission.
- Open: the engine is disconnected, so the vehicle runs on the e-motor alone (EV mode) & engine doesn't drag during regen braking.
- Engine start: the hybrid e-motor spins the engine by slipping K0 closed, so K0 sees heat during starts.
- Driving: current flows and it adds torque (EV launch, engine assist).
- Generating: it's loaded to charge the battery, such as during regen braking or when the engine is producing extra power.
- Zero torque: the rotor spins along with everything else but the inverter commands no torque, so it's essentially a passenger. The only cost is small losses like bearing drag and some magnetic drag.
