Regen only works when the battery has available capacity. When this is no longer available the only engine braking is through the automatic transmission gear selection, which may not be enough for a long, steep descent. You could upgrade to a higher T boiling point brake fluid, and definitely change the fluid on a regular basis if steep mountain driving is something commonly done.
