I recently purchased a 2026 Land Cruiser and overall I’m absolutely loving the vehicle. However, I’ve been dealing with one issue that’s starting to get a little frustrating. Whenever the vehicle slows down below about 20 mph while braking, stronger on the driver side and still noticeable from passenger side. I hear a very faint low screeching/squealing noise. It’s not extremely loud, but it’s noticeable enough that I can hear it even with music playing sometimes.
I’ve notice it only happens when driving forward. Happens while braking below 20 mph. Does not happen in reverse. Usually starts after the car has been driven for a bit, and once it starts it continues for the rest of that drive. It’s a low pitched faint screech, not a grinding or loud brake squeal
I took it to the dealer and they referenced Toyota T-SB-0046-25, which apparently relates to brake squeal when reversing. Even though my noise does not occur in reverse, they still performed the repair. They replaced/installed: Pad kit (disc brake), Shim kit, Anti-squeal kit, Fitting kit, and Brake caliper grease.
Parts took almost two months to arrive. After the repair, the noise seemed gone when I first drove off, but after driving a bit it came back exactly the same. I’ve seen some posts mentioning the Acoustic Vehicle Alert System (AVAS), but I really don’t think that’s it. I own another EV and I’m familiar with what AVAS sounds like. This noise definitely sounds like it’s coming from the brakes, and I can hear it behind the regenerative braking noise.
At this point I’m not sure what to try next. It’s not a major issue, but for a brand new vehicle at this price point, it’s definitely annoying. I’m curious if anyone else with a 2026 Land Cruiser experienced this? Could this still be related to regenerative braking or AVAS somehow? Has anyone had a successful fix for something similar? Any insight would be greatly appreciated. Thanks!
