🛠️ Member Build New 2026 Land Cruiser - Underground
Member Build
Installed Ancel BS200.
Our LC is daily driver for wife doing home health visits. Know the OE battery has a limited life, so better than calling roadside assistance who probably wouldn’t have a clue how to jump a LC, decided to try the BS200.
Hope we never need find ourselves needing it, but nice insurance. This is how I did the install:
  • LC makes for a very easy install - 1 out of 5
  • Took less than 10 min
  • Removed battery/jack cover in cargo area
  • Pull red positive battery shield off connection
  • Loosened 12mm nut on + battery cable end & installed red positive BS200 lead, retightened
  • Same for negative lead
  • Pulled battery shield/membrane back down & placed BS2000 on top on battery lengthwise, angled front edge up
  • Replaced cargo plastic cover
  • Downloaded app, connected w/ iPhone by BT
  • Got monitored info within seconds.
10.08.26 Update - BS200 monitoring is working great on our LC. Really like keeping an eye on the Toyota OE battery SoC. Like it so much I installed a BS300 on my sister’s new LX600 w/ its 3.4L TT. She lives 5 hours away & this gives peace of mind.
Installed Ancel BS2000.
Our LC is daily driver for wife doing home health visits. Know the OE battery has a limited life, so better than calling roadside assistance who probably wouldn’t have a clue how to jump a LC, decided to try the BS2000.
  • Loosened 12mm nut on + battery cable end & installed red positive BS2000 lead, retightened
Thank you so much . Just what I needed
BS2000 fits well.
Don’t do the BS3000 - I don’t see how it could fit.
Just put BS3000 on a LX600 for family member & it’s much larger.
Thanks for the pics. They motivated me to do this too. I got the BS200 for $140 earlier in the week during the Amazon deals event. Ok.... so I installed this morning. I am glad you mentioned the 12mm nuts because that told me where to do the connections. When you look at the battery from the top, both on the left (negative) side and right (positive) side, there are two set of nuts (upper/lower) and I wasn't sure which to use until I saw your 12 mm nuts comment. The nuts at the top seemed to be 10mm. I believe the recommendation is to use the "auxiliary" studs as opposed to the "primary ports", so wasn't sure if the top connections would have worked or not.
On the positive terminal side, the connection from the BS200 entered a bit at an angle due to the "plastic" surrounding the nut getting in the way a little bit. Did that happen to you too?
Wanted to ask for some feedback on these two screenshots. The first one (SoC 0%) was taken before turning on the vehicle immediately after installation. The second one (1% SoC) was taken immediately after starting the vehicle the first time after installation. Installation was done in the morning after the car was parked overnight.
According to AI, I should not be super concerned (yet) about these numbers until we see "more" data over a few days, even though it's recommending to have the battery checked LOL.... so not sure what to make of it. The LC started up fine as usual, and I've never had any issues with it. I only have 1K miles on it so far though. During the Amazon sale I also got me a NOCO genius5 charger and NOCO gbx45 starter that were discounted, for piece of mind.
Nice job working the sale.
Right hand side of battery is positive (under red cover), left is negative. BS200 cable colors correspond. I used the upper 12mm nuts, just loosened & slid terminals under, retightened. Be cautious on positive side not to contact wrench to any metal as it’ll ground out.
Pop your gas tank lid to force a 12v battery start. Drive for 1/2 hour & monitor SoC readings before after.
Have yet to have a battery or starting issue (but only 3k miles in) but this Ancel just made my upgrade list, thanks
I also went with the BS200 and replaced the factory toyota battery with a AGM that seems to be working way better than the lead acid one.
NOCO Genius 5 Under-Hood Install -
Finally have a 100% SoC on my OE 8 month old battery for the first time! Been monitoring w/ BS200 BT starter capacitor & the vehicles charging system has been keeping the battery SoC stays 62-70% for over a month. Concerning, as the vehicle is a daily driver w/ 50-100 miles weekdays but just didn’t seem to ever charge up completely.
Wanted to document for my memory & help anyone else.
Used the under-hood passenger side power distribution box. Take the cover off w/ 4 detents & remove cover. Locate red (+) point.
Lift up the black cover for the positive lead coming from the battery & you will find 2 continuous 12v power leads.
Power - Used a NOCO GC008 large ring kit. The positive lead closest to the firewall is the direct 12v main (+) power coming from the rear cargo area mounted battery. Loosen nut, slip ring connector under & retighten. Good location if you need constant 12v power under the hood. I already have a power lead in the location from running my CANBUS interrogator that powers our grill light bar.
Ground - Same ring kit & now use (-) ring lead to create a body ground. I loosened the fender bolt mounting @ the inverter coolant tank (on passenger fender located very close to the Power Distribution Box) slipped (-) ring lead under & retightened.
(I have Redline hood lifts & their bracket mounts in same location, so your view may look slightly different.)
It’s now really easy to get to the waterproof NOCO quick disconnect electrical fitting. That will be the lead that plugs into the Genius charger. The plug sits nicely between Power Distribution Cover & passenger front fender inside engine compartment.
For my solution I mounted the Genius 5 on wall in front of where my wife parks her LC. This setup requires the LC hood to be open in order to plug-in & use the charger, hopefully preventing ever driving off w/ trickle charger hooked up.
Only took around 2 hours to get the battery topped off @ 100% SoC.
Power - Used a NOCO battery large ring kit. The positive lead closest to the firewall is the direct 12v main (+) power coming from the rear cargo area mounted battery. Loosen nut, slip ring connector under & retighten. Good location if you need constant 12v power under the hood. I already have a power lead in the location from running my CANBUS interrogator that powers our grill light bar.
Did your battery maintainer came already with the loop connectors for the battery, or did you have to buy them separately.
Good question. Gen5 come w/ alligator clamps & you can unscrew the leads off of them & use the attached rings - just didn’t know if they’d be large enough. I didn’t want to gamble, so I bought a NOCO GC008 kit on Amazon & they worked fine.
I do need to check what power consumption level happens with just the hood being open. Anyone know?
Apparently some battery usage happens with the hood open. Maybe has to do with it is a hybrid vehicle - as Toyota hybrids behave different when hood is popped open. For example when the LC is running, the T24A operates the engine while the hood is open & doesn’t do the Hybrid battery start/stop. My Tundra hybrid does the same thing - start/stop works in driveway until you pop hood open. I also went out of town with the LC hood open in the garage & got ‘Open Hatch’ reminders all weekend on the Toyota app.
