Land Cruiser OEM+ DSP Amplifier Stereo Upgrade (No PAC AmpPRO, No Beat Sonic)
buildxyz
Surrey, BC, Canada
2026 Land Cruiser
I just wrapped up a three-month project researching and upgrading the audio in my Land Cruiser (base "Land Cruiser" trim with the 10-speaker non-JBL system). I have a background in electrical engineering and did all the work myself. A lot of what I learned applies across all LC trims, so I wanted to share it here.
My Requirements​
  • No Beat Sonic or PAC AmpPRO. There is no PAC option for non-JBL systems. I asked and was told the AP4-TY14 is not compatible (as of 01/2026).
  • Fully reversible to stock. No cutting harnesses or trim.
  • Factory speaker locations only. No subwoofer boxes that eat into existing storage.
  • Sound quality (SQ) focused, not SPL. I'm not going for earthquake bass.
The Plan​
The system is built around the Audison M8.14, an 8-channel amplifier with a powerful integrated DSP that handles the OEM integration. The design is split into two phases. I'll likely stop at Phase 1 since I'm very happy with it, but I've included Phase 2 for completeness.
  • Phase 1: Only the Audison M8.14 is added. Channels 7/8 are bridged to deliver 250W @ 4 ohms to the subwoofer, and the OEM amplifier continues to run the rear fill door speakers.
  • Phase 2: The rear fills move to the M8.14, and a dedicated monoblock amplifier drives the subwoofer.
Since I planned for Phase 2 from the start, most of the wiring for it is already in place.
I also did a full sound treatment, which you'll see in the photos I'll be posting over the coming days. I won't go into much detail on that process since [GIO YouTube] covers it well.
Gear (approximate price paid, CAD)​
ItemPrice
Audison M8.14 DSP amplifier$2,000
Audison DRC (remote controller)$250
Audison AP8 drivers$300
Hertz Mille Pro MP 70.3 PRO 3" midrange$300
Hertz Mille Pro MP 28.3 PRO tweeters$260
AudioFrog GS8ND2 shallow woofer$500
Misc Costs​
ItemPrice
miniDSP UMIK-1 calibrated USB measurement mic$170
CarTrimHome A-pillars$230
NVX Stealth Black SDBTK20 sound deadener (91 mil)$260
Soundskins SSK-RINGV3 foam speaker ring kit$75
Carista EVO Bluetooth OBD2 scanner$70
Carista 1-month subscription$30
Speaker wire$38
Speaker harness$38
Amplifier power cable and distribution block$250
Total: ~$4,770 CAD (~$3,380 USD)
Gotchas​
There are two quirks everyone should know about before upgrading their LC's stereo.
1. Disable Active Noise Cancellation (ANC)​
ANC has to be turned off, otherwise the OEM audio signal feeding your DSP will include the noise-cancelling content. You can do this with Carista and a one-month subscription. Flip it off. You won't miss it; I sure don't.
2. The Data Communication Module (DCM) aka Telematics unit uses the front right dash speaker​
The OEM speaker wire running from the amplifier to the front right dash speaker also passes through the TCM. The TCM has its own small amplifier, matched to the OEM dash speaker, that takes over that speaker during emergency (SOS) calls. If you replace or repurpose that speaker, you need to keep this in mind or you could lose emergency call audio.
I didn't want a center channel speaker; I wanted to keep a true stereo image. My solution was to build an extension from the OEM right dash speaker harness to the center speaker location, giving the TCM its own dedicated center speaker. The new Hertz MP 70.3 midranges are fed with separate aftermarket speaker wire.
I tested this by starting an SOS call, confirming the automated voice prompts played through the center speaker, then cancelling the call.
That wraps up the prep and planning phase. To keep things digestible, I'll post the rest in segments in this thread over the next few weeks. I'm still tuning, and I'll finish with my overall impressions and whether I think this design was worth it.
Curious, is that subwoofer a direct fit? Wondering if it would help my LC premium system. I did do the Beatsonic amp, but nothing else other than some sound deadening. Not looking for earth shattering bass either, but the stock sub does not seem to do much at all.
The Audiofrog GS8ND2 is not a direct fit. No subwoofer will be because the OEM subwoofer (and all other speakers) have the mounting adaptor as a single integrated piece.
Stay tuned, more on this to come, I will show you how I mounted everything.
