- Thread starter
- #81
OK, so let's talk a bit about what we know so far about the failing transmissions.
From the reports, it appears that the troublesome part is the transmission electric pump (35300-04010). So far,Toyota has opted for replacing the entire transmission under warranty. Most likely so that they can study the failed transmissions and identify improvements -that's how Kaizen works. Transmission replacement is expensive, hence the $30k figure that has been circulating on some forums.
However, the replacement of this pump is a relatively simple repair that can be done by dropping the transmission pan. The pump is easily accessible from there. The pump MSRP is around $1,300, and labor shouldn't exceed $1,000 including fluid refill. So most likely, in the future these repairs would be somewhere in the $3k range.
While the transmission problem is real, I don't think there is need to panic.
