Confirmed solve for Bike rack sensor nonsense
Happy to report my cheapo solution to the 7 Pin - auto disable backup issue.
I purchased a Electromagnet trailer brake magnet for a 7" hub
One wire to ground the other wire to pin 2 (Blue wire)
Works just like is should, plug in the 7 pin = no issues backing up with my rack installed.
Great work, per usual! Do you know if this options disables Cruise Control? When I was towing a camper a couple of months ago, it was disabled. While towing a camper, I'd probably not want to use Cruise Control but if I'm just hauling my bike around, I'd prefer to have it available as well as having the "backing up issues" resolved.
I used my cruise on my last trip with the bike.
So, I wired something up similar to what you did and the message below popped up. Does this pop up for you as well @EOD Guy? If so, does it go away on it's own eventually or do you have to dismiss it manually every time?
I don't remember if it popped up or not............ I'll have to check on my next trip.
I have a 2025 Landcruiser and the 7-pin plus electric brake set-up does disable cruise control. I will probably pull out the trailer plug on long trips so I can use the cruise control, but it is really nice for around town to avoid the warning chimes every time I back out of a parking spot.
Similar threads
