- Jul 23, 2025
- 1,089
- Media
- 17
- 873
- Vehicles
- 2025 LC250P WCP, Java, 2020 Alfa Romeo Stelvio Quadrifoglio, 2024 Fiat 500e, 2023 Genesis GV60P, 2018 Alfa Romeo 4C (track toy)
50lbs or more???
I added about 60lbs to my Tacoma, and will likely add about the same to the LC250. This new material is butyl based, and does not weigh nearly as much as the old asphalt based sound deadening material. You could take your spare tire off and that would take off more weight than the sound deadening would be adding.How much weight did it add to the vehicle, and did it alter the handling? I ask because I did this to a sedan once and regretted it, as it negatively affected the handling of the vehicle.
Thanks, I appreciate the reply. Looking at you in the hood and front fenders.I added about 60lbs to my Tacoma, and will likely add about the same to the LC250. This new material is butyl based, and does not weigh nearly as much as the old asphalt based sound deadening material. You could take your spare tire off and that would take off more weight than the sound deadening would be adding.
Ah yes, the good ol’ ‘turn up the stereo and ignore the problem’ approach, what a clever solution, well done.....and to think all I need to do is turn up the stereo when the wife is asleep................just drove it home 375 miles last week and do not see sound as being a big issue................sorry but seems like another You tuber trying to drum up business.![]()
I just know, that if I take MIss Daisy apart to do this project, I will have parts left over once I put her all back together..Thank you! Toyota sparingly uses any sound deadening from the factory. So I'm hoping for even better results when the whole project is complete.
Then the same people will complain the tank is too small after adding a couple hundred pounds of stuff to the vehicle. Crossbar removal alone makes a big difference. Just seems like yet another example of OCD automotive...........What he has done he has done well. but...you wanted it that quiet, should have bought a Range Rover.Ah yes, the good ol’ ‘turn up the stereo and ignore the problem’ approach, what a clever solution, well done.....
I for one appreciate these kind of videos as its something I'm in the process of doing myself and coming from other Euro cars, the LC250 is quite noisy.
You could just not watch this thread.Then the same people will complain the tank is too small after adding a couple hundred pounds of stuff to the vehicle. Crossbar removal alone makes a big difference. Just seems like yet another example of OCD automotive...........What he has done he has done well. but...you wanted it that quiet, should have bought a Range Rover.
Reputable CLD manufacturers like Dynamat, Second Skin, and ResoNix (probably others) offer underhood material with high temp ratings. I would not be too concerned that they're all making false claims.Is there any concern with heat causing the sound deadening product to fall off? I did my taco a number of years ago and avoided the hood for that reason.
Can you share a picture of what the hood under side looks like with the sound deadening?so.... i've completed the underside of the hood, mostly copied your approach, i only bought 1/8" dynamat though and need to drive the same road i took my baseline measurements to get a fair comparison.
but just driving near my home at speed and the averages from the app are lower by ~ 2-3dB
i'll share more updates as i get them, and i'm very curious to see how yours measures up once the doors are done.
it looks nearly identical to the OP's in the video.Can you share a picture of what the hood under side looks like with the sound deadening?
Mostly under the hood cover, but you can see a couple small piecesCan you share a picture of what the hood under side looks like with the sound deadening?
